OC fail, please enter setup to change OC Fail settings
4 Suggested Answers
  • 135 Answers
SOURCE: oc failed
Could you please give us more details such as which computer (model number) and motherboard you're using? Do you know how to overclock and that's what you were doing? If so, you didn't overclock correctly and you need to change the settings back to the normal settings for your computer to boot up properly. You can change the settings in the BIOS, or "setup".
Posted on Jan 09, 2008
DickCanFixIt
  • 948 Answers
SOURCE: PM800-8237
If you have correctly set the CPU in the BIOS, and saved the settings and still get the error, the CPU is not compatible with your system.
Most likely you have not set the BIOS right or have not saved it.
Posted on Jul 02, 2009
herminio_hal
  • 210 Answers
SOURCE: OC fail warning comes.pc does
Hi, As I understand, you may have dead cmos battery or is not seated properly. I hope this this will you to solve the problem... Have a Happy New Year...
Posted on Dec 30, 2010
Asus701 bios setup utility dose the onboard LAN boot rom need to be enabled or disabled to set factory settings
Load Fail Safe defaults
F6 key? Check the navigation guide.
Press the Enter key. Save Changes
(If you don't save changes it will be like you have done nothing at all)
Regards,
joecoolvette
Dec 26, 2012 | Computers & Internet
DNS lookup fail at random times
I can suggest you a solution. I am not sure whether it will work or not but you can try this and see if that works.
Open the setup page of Linksys router using 192.168.1.1.
On the setup page you will see Static DNS 1. Enter 4.2.2.2 in Static DNS1. And Enter 4.2.2.3 in static DNS 2 option. Save the settings.
See if this works.
Also make sure that firmware on your router is upgraded.
Jun 05, 2012 | Cisco Linksys Wireless N Home Router...
OC fail warning comes.pc does not switch on at 1st time.next time it asks to do setting in setup. my config is hp dx2280mt, 945 mb, core2 d, win 07 os.
Dec 30, 2010 | Computers & Internet
Reset the BIOS on a Compaq server 740 jumpers settings
Don,t do that insatead:
Entering the BIOS Setup menu Entering the BIOS Setup menu requires pressing a specific key at a specific time. If you fail to enter the Setup menu on your first try, repeat the following steps until you are successful:
  1. Close all applications that are currently running and restart the computer by clicking Start , Shut Down , Restart the Computer , and then OK .
  2. When the red Compaq logo or blue HP logo screen appears, press the F10 key on the keyboard to enter the Setup menu.
NOTE: An alternate to the above steps, especially if the logo screen disappears too quickly to enter BIOS, is to shut down (turn off) the computer. Wait 30 seconds, turn the power on and press F10 or F1 at the logo screen. Reloading the default settings Complete the following steps to reload the factory installed BIOS Setup settings:
  1. In the BIOS Setup utility, select the Exit tab.
  2. Select Load Setup Defaults .
  3. Select Save Changes and Exit (pressing F5 and the Enter key will also load the Setup Defaults).
  4. Press Esc and then Enter to exit Setup.
Nov 13, 2010 | Computers & Internet
Hi, im installing my operating system but the pc always turns off in the middle of installation(after loading setup files and displays the press enter to install windows xp). i alraedy set the bios to fail...
Dear,
First you have to see the CDROM wthere its reading correct or not? before that you have to change once RAM and try again. It will work. okey. Due to frequency mismatch it will occur.
Cheers
Jaggu
Sep 28, 2009 | EliteGroup KM400-M2 Motherboard
Whenever I boot I get the followoing msgs- pri master atapi cd rom primary slave ide hdd primary salave hd smart command failed no 1de master hdddetected press f1 to continue-- then okay But sometimes...
please change the wire connection in your pc from CD rom to HDD so that HDD become primary master and cd rom become primary slave, check after this, and if still get error check your IDE cable, and for the smart command fail may be your HDD didnt support smart feature, so disable this from advance setup
Aug 21, 2009 | ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7...
PM800-8237-6A7L2B0DC-00 WARNING! CPU has been changed or CPU Ratio changed fail. Please re-enter CPU Setting in the CMOS setup and remember to save before quit! press F10 and Y for save. Re-start, and the...
Jul 02, 2009 | Computers & Internet
I tried to add memory ram to my computer, but it was not compatible and now my computer does not start. the monitor only shows me a "CMOS ERROR" AND warn me that my CPU has been changed or the...
if you put your old memory in and boot into bios setup and go to default or fail safe settings that should work then get the right memory that u need and install as usual
Aug 20, 2008 | Systemax Computers & Internet
Oc failed enter setup to chwck oc settings
Jan 09, 2008 | Computers & Internet
Oc failed
in this case i assume the 'OC' is refering to the overclocking facility in your bios, so firstly press F2 or Del when your pc is booting up and, unless you have changed any settings to cause the fault, look in the cmos settings for 'Load Default Settings', save settings and exit for a reboot and see if the same message pops up. If so you may need to check the memory is seated correctly and any other peripheral connected to your motherboard, assuming it is a desktop pc. Isf still no change try resetting the bios by way of a terminal called CLRCMOS or CLR CLK or JBAT1, but you will have to refer to yourmotherboard manula or post the board details back here.
Aug 14, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
370 people viewed this question
David Payne
David Payne
