Question about Cuisinart Coffee Makers & Espresso Machines
How do you get the coffee grinder out of the DGB-475Bk model to clean it.
Brewed coffee overflowed on to warmer plate. Now water does not heat and flow and warmer plate does not heat up.
Unless it is an expensive brewer, get a new one. The brewer needs the bottom plate to heat in order for it to work at all. Should be imune getting wet though, but sounds like bad heating element.
If you need further help, reach me via phone at https://www.6ya.com/expert/steve_24d988f3507f7480
Oct 11, 2013 | Cuisinart Model DGB-550 Coffeemaker...
While the coffee is brewing without using the grinder feature, coffee overflows onto the counter. About 1/2 of the coffee goes into the pot while the rest spills over. I have cleaned residue from the lid...
overflow problem possible causes: 1) water is over the "10" marker, 2) no filter in basket 3) too much (or too fine) of coffee in the basket -- does not drain. Also make sure the "spring" on the bottom of the basket is not stuck (the one that lets you remove coffee carafe without dripping coffee.
Jan 17, 2011 | Cuisinart Thermal DGB-600 Grinder
Need instructions to operate DGB-600BC
Thanks for the reply. Got rid of the coffee maker. Its a dud. No more information required.
Jun 18, 2009 | Cuisinart Thermal DGB-600 Grinder
DGB 500 Grinder
You may try opening the front cover first and removing the filter then after opening the top lid, remove the clear grinder cover and lift the grinder from the rear. After you get it out be sure to clean the motor drive shaft and the bottom of the grinder. then use a trace of vegetable oil to lubricate the motor shaft where is attaches to the grinder.
We are on our second coffee maker and it makes great coffee.
Jan 19, 2009 | Cuisinart DGB-500 Coffee Maker
Coffee grinder on brew and grind won't work
Make sure the slot between the grind basket and filter basket is clean and free of grounds - then inspect the area near the grinder motor - use the brush that came supplied with the Cuisinart to clean that area out. Once thoroughly cleaned, try one more time to Grind. Let me know if it works.
-Tha Mp3 Doctor
Jan 06, 2009 | Cuisinart Thermal DGB-600 Grinder
Need schematic to reassemble...
The filter basket is orderable from Cuisinart and costs somewhere in the neighborhood of $5 to $6 - there is no service manual for that particular part of the coffee maker.
-Tha Mp3 Doctor
Dec 05, 2008 | Cuisinart Thermal DGB-600 Grinder
Grinder hard (impossible) to remove
I had the same problem and used a little grease and it worked fine. Take out the bean cup and grease the male and female parts and it should work fine.
Jul 18, 2008 | Cuisinart Thermal DGB-600 Grinder
Grinder basket removal
Vinegar instead of WD40 - I am pretty sure a good portion of the DGB-600's have this problem, but that is hearsay.
May 31, 2008 | Cuisinart Thermal DGB-600 Grinder
Cuisinart Coffeemaker DGB 500
I had the problem also.  First, I cleaned the area very well of the caramelized coffee gunk. where the grinder goes.  I also filed away a few degraded areas on the grinder's plastic housing.  Haven't had the problem since.
Oct 17, 2007 | Cuisinart DGB-500 Coffee Maker
Coffee Makers & Espresso Machines Logo
353 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
