Question about Apple iPhone Smartphone
I was fiddling with settings and went into tri-press setting and was curious about different options. Clicked on first option and now the phone is on talk mode, which has a voice over on everthing you navigate to. Worst part is my touch pad is comparmised and I can't scoll through setting and more?
Bluetooth on nikon d3400 greyed out how do I get it on
From this forum:
https://www.nikonforums.com/forums/topic/7492-bluetooth-this-option-is-not-available-at-current-settings-or-in-the-cameras-current-state/
I had this exact problem with my new d3400 as well. My settings originally showed Bluetooth ON and when I clicked on it, it showed a couple options: Network Connection-ON, Paired Devices, Send while off-"ON". I clicked on Paired Devices and it showed that it had connected to my phone today (even though my connection to snapbridge was unsuccessful) - so in an effort to retry my snapbridge connection I deleted my phone from the paired devices and this caused the Bluetooth on the camera to completely turn OFF and grey out. Same problem everyone here seems to be having where I couldn't even re-enable the bluetooth again and just saw an error message saying "option unavailable in current setting".
Alas, I found a solution - I have an iPhone 6 so for me at least this worked:
I went to bluetooth settings on my phone and went to the camera name and said "forget this device". I then deleted the snapbridge app and redownloaded it.
Then I went on the camera and tried to do the "connect to smart device". Instead of going to snapbridge, I went to my phone's bluetooth settings and chose the camera once the name popped up again. It prompted a pair message and I had to confirm the # on the camera matched the # on my phone. It then paired successfully and the bluetooth on my camera was back on! -- (disclaimer.. while this was great to see that at least the bluetooth was on again, this did not resolve the issues I was having with snapbridge - I still can't seem to get it to connect through the app, but perhaps it will work out for others..)
Jul 02, 2017 | Nikon Cameras
Samsung n130 lost the audio
I assume you went to control panel, clicked the speaker icon, and went through all the different options (it is sometimes complicated, with different volume settings for different file types depending on the audio driver/soundcard). Sometimes (like in Vista) you have to select the default audio source, sometimes some are hidden unless you ask it to show disabled devices.
Apr 18, 2014 | Samsung N150 (36725723009) Netbook
I want change language
Turn your cell phone on, and press the menu button to begin viewing the menu options of your phone.
Scroll through the menu options of your phone until you come to a settings option. Every cell phone has a different basic set up, but they all have "settings" areas, where the basic phone settings are located. One you have found the settings option, select it. The settings option will open a list of basic cell phone functions. Some cell phones have larger groups that are then broken further into smaller ones, and other phones have a bunch of small individual settings options.
Look for the option under settings that says system, display, display info, or language, and choose it. Whichever of these options your cell phone has, the outcome will be the same, so don't be discouraged if your cell phone has a slightly different set up than other cell phones.
Choose your desired cell phone language from the list and choose it, if your cell phone had a language option directly under settings. If not, then look for the language option under the system, display, or display/info options, and then choose your language from the list it provides.
Turn your phone off and then back on again, just to ensure that the new language change did take effect, and will remain. Your language settings should now be changed, and you should be viewing all functions of your cell phone in your newly chosen language
Sep 02, 2011 | Nokia 3410 Cellular Phone
How to change a language in i mate ultimate 8150
Hi
1. Turn your cell phone on, and press the menu button to begin viewing the menu options of your phone.
2. Scroll through the menu options of your phone until you come to a settings option. Every cell phone has different basic set up, but they all have "settings" areas, where the basic phone settings are located. One you have found the settings option, select it. The settings option will open a list of basic cell phone functions. Some cell phones have larger groups that are then broken further into smaller ones, and other phones have a bunch of small individual settings options.
3. Look for the option under settings that says system, display, display info, or language, and choose it. Whichever of these options your cell phone has, the outcome will be the same, so don't be discouraged if your cell phone has a slightly different set up than other cell phones.
4. Choose your desired cell phone language from the list and choose it, if your cell phone had a language option directly under settings. If not, then look for the language option under the system, display, or display/info options, and then chooses your language from the list it provides
5. Turn your phone off and then back on again, just to ensure that the new language change did take effect, and will remain. your language settings should now be changed, and you should be viewing all functions of your cell phone in your newly chosen language.
Regards
Jul 05, 2011 | i-mate Ultimate 8150 Smartphone
Change language from german to english
    • 1 Turn your cell phone on, and press the menu button to begin viewing the menu options of your phone.
    • 2 Scroll through the menu options of your phone until you come to a settings option. Every cell phone has a different basic set up, but they all have "settings" areas, where the basic phone settings are located. One you have found the settings option, select it. The settings option will open a list of basic cell phone functions. Some cell phones have larger groups that are then broken further into smaller ones, and other phones have a bunch of small individual settings options.
    • 3 Look for the option under settings that says system, display, display info, or language, and choose it. Whichever of these options your cell phone has, the outcome will be the same, so don't be discouraged if your cell phone has a slightly different set up than other cell phones.
    • 4 Choose your desired cell phone language from the list and choose it, if your cell phone had a language option directly under settings. If not, then look for the language option under the system, display, or display/info options, and then choose your language from the list it provides.
    • 5 Turn your phone off and then back on again, just to ensure that the new language change did take effect, and will remain. Your language settings should now be changed, and you should be viewing all functions of your cell phone in your newly chosen language.
May 14, 2011 | Alcatel Cell Phones
How to change the language into english pl answer me?
Apr 24, 2011 | Cell Phones
Langue change options
Take the following steps to change your language to English. 1. Turn your cell phone on, and press the menu button to begin viewing the menu options of your phone. 2. Scroll through the menu options of your phone until you come to a settings option. Every cell phone has a different basic set up, but they all have "settings" areas, where the basic phone settings are located. One you have found the settings option,select it. The settings option will open a list of basic cell phone functions.Some cell phones have larger groups that are then broken further into smaller ones, and other phones have a bunch of small individual settings options. 3. Look for the option under settings that says system, display, display info, or language, and choose it.Whichever of these options your cell phone has, the outcome will be the same,so don't be discouraged if your cell phone has a slightly different set up than other cell phones. 4. Choose your desired cell phone language from the list and choose it, if your cell phone had a language option directly under settings. If not, then look for the language option under the system,display, or display/info options, and then choose your language from the list it provides 5. Turn your phone off and then back on again, just to ensure that the new language change did take effect, and will remain. Your language settings should now be changed, and you should be viewing all functions of your cell phone in your newly chosen language.
OR BETTER STILL
YOU Switch-off your phone.
1. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to switch on the phone.
Remember, do not let go the 3 press and hold keys until you see a formatting word screen show!
2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory setting.
I HOPE THIS HELPS?
Mar 07, 2011 | Cell Phones
HOW DO I CHANGE TELEPHONE LANGUAGE TO ENGLISH?
2. Scroll through the menu options of your phone until you come to a settings option. Every cell phone has a different basic set up, but they all have "settings" areas, where the basic phone settings are located. One you have found the settings option, select it. The settings option will open a list of basic cell phone functions. Some cell phones have larger groups that are then broken further into smaller ones, and other phones have a bunch of small individual settings options.
4. Choose your desired cell phone language from the list and choose it, if your cell phone had a language option directly under settings. If not, then look for the language option under the system, display, or display/info options, and then choose your language from the list it provides
Feb 17, 2011 | Lands Phones
Remove demos
you can connect to pc and in the pc suite there will be option to delete the unwanted games/apps....
Feb 23, 2008 | Motorola Mobility MOTORAZR2 V9 Cellular...
Progressive Scan Mode
Check for video out in the dvd setup menu, and set it for composite,
It may be set for component.
another thing to try is setting the the progressive scan option off in the setup menu, you wont benefit from it, but at least it might work.
if you already tried using the prog scan and your T.V isnt compatible, you'll need to reset. press stop to stop any playing disc, and press stop again holding it for 5 seconds to reset the system.
good luck!
Jan 29, 2008 | Zenith XBS344 System
Apple iPhone Smartphone Logo
19 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
David
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
