Question about Brother DCP 165C Compact Color Inkjet Multifunction Printer
I HAVE PROBLEM WITH DCP165C INIT UNABLE 5A - Brother DCP 165C Compact Color Inkjet Multifunction Printer
Troubleshooting and routine maintenance troubleshoot init unable 5A
Call On Given Number: 1-888-508-8524
Their Technical Expert may troubleshoot the issue Over The Phone.
Hope this may be helpful for you !!!
Feb 28, 2016 | Office Equipment & Supplies
Unable to Lnit.5a
Go To Below official Brother Printer Video For Your problem, How to Clear the Unable to Init Message from the Brother Printer Display
Still having Problem Then follow Us For
Brother Printer Support
Feb 22, 2014 | Brother DCP-110C All-In-One InkJet Printer
Unable to clean 5a
Sir/Madam
If one of the following messages is displayed on Your Printer,I suggest You Go To Below Official Brother Website For Troubleshooting,
  • Unable to Clean (Clean Unable)
  • Unable to Init. (Init Unable)
  • Unable to Print (Print Unable)
  • Unable to Scan (Scan Unable)
http://welcome.solutions.brother.com/BSC/public/as/sg/en/faq/faq/000000/000500/000065/faq000565_012.html?reg=as&c=sg&lang=en&prod=mfc290c_all
Or If You FaceProble Then Follows Us On For Online
Jan 08, 2014 | Brother MFC-465CN InkJet Printer
Init unable 5a
Fault is not mentioned and details are required for any solution.
If the printer is showing errors, please uninstall and reinstall the drivers before the printer can be connected once again.
Oct 24, 2011 | Brother DCP 165C Compact Color Inkjet...
INIT UNABLE 5A , brother DCP-195C
How can i fix brother printer dcp-195c error Init unable 5A
Oct 22, 2010 | Brother Office Equipment & Supplies
It says init unable 40 or init unable 43. it
Brother warranties for one year, you can call
1-800-276-7746 and they can give you the nearest service center.
Nov 24, 2009 | Brother Multi-Function Center MFC-240C...
Brother mfc240c init 4F & init 5A
Hi there
With some Brother printers you can try this.
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, and then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
Some times this happens because of using cheap compatible ink cartridges if this is the case change the ink cartridges.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jul 18, 2009 | Brother Multi-Function Center MFC-240C...
Brother DCP 165C Compact Color Inkjet Multifunction Printer Logo
532 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
