Question about Sony Cyber-Shot DSC-S40 Digital Camera
I have Sony DSC-S40 camera with MS 1Gb, when i switch it on i have "access" then error message says" Memory stick error" and flashing "C:13:01" and I can't take photoes or enter the memory what can i do.... any advice
    President:
  • 287 Answers
Hello and Welcome to Fixya!
C:13:01 memory stick error message indicates a Self diagnostic message.In C:13:01 the issue may be with the Internal Memory or with the Memory Stick.
To solve it try the following solutions
Format error with the Internal Memory which can be corrected by formatting the Internal Memory.
If it is issue with memory stick then turning the power off and on again or taking out and inserting the "Memory Stick" several times may help in resolving the issue. Error may be because of Unformatted "Memory Stick" which can be resolved by formatting the Memory Stick in the Camera If it not remove by formatting in the camera then connect it to PC and tried to format it again but either FAT instead of FAT32 which is the regular format and then reinserted the memory stick and formatted it with the camara. Now it will be solved if it still exist then it means Memory Stick is broken or not compatible which can be resolved by inserting a new compatible Memory stick
I hope this solution helps you
Your token of appreciation in the form of four thumbs and testimonial will be esteemed.
THANK YOU and Keep Visiting FixYa
Posted on Apr 09, 2011
I have format error on my cybershot camera. I need to access photoc on camera
The Camera may display the FORMAT Error if the inserted media is not formatted or if the media was formatted on a computer. This error may also display if the inserted media is not supported by the Camera. The maximum supported capacity and media used is Memory Stick Pro Duo with 1 or 2 GB.
If you've already captured the images in the Camera and the error message displays, then try to open different images captured in the Camera and check if the message appears for all the images.
If this happens with all the images, then remove and reinsert the MS (Memory Stick) in the Camera and check if it works. You may also try cleaning the MS terminals and also check if the Internal Memory of the Camera displays the error. If the issue persists, then insert the MS in the Computer slot and transfer all the images to the Computer. If the images appear normally in the Computer, then Format the media in the Camera. To Format the Memory Stick, select the Format option in the Memory Stick Tool Menu of the Camera. (Menu-->Setup-->Memory Stick Tool-->Format)
Formatting the MS will delete all the files saved.
Formatting the MS should resolve the issue.
Thanks for using FixYa.
Jan 18, 2011 | Sony Cyber-shot DSC-S700 Digital Camera
Internal memory formatting error to sony DSC-T2 camera error c:13:01
In DSCT2 Camera, the C:13:01 error message indicates a Self diagnostic message. This message can be clearly identified by the help of a Sony Authorized service technician. Each of these codes indicates the symptoms and resolutions of the Camera. In C:13:01, the issue is with the Internal Memory or with the Memory Stick.
The Symptoms are:
1. Format error with the Internal Memory which can be corrected by formatting the Internal Memory.
2. Unformatted "Memory Stick Duo" which can be resolved by formatting the MS in the Camera.
3. "Memory Stick Duo" is broken or not compatible which can be resolved by inserting a new compatible MS.
4. There may be an issue with the Hardware part also, which can be resolved by the technicians.
Try turning the power off and on again, or taking out and inserting the "Memory Stick Duo" several times may also help in resolving the issue.
Thanks.
Oct 21, 2010 | Sony Cyber-Shot DSC-T5 Digital Camera
Have Sony CyberShot DSC-F707 Sony Memory Stick Duo Adaptor and Sony Memory Stick Pro Duo 4gb When installed get C:1301 error
In DSCT1 Camera, the C:13:01 error message indicates a Self diagnostic message. Each of these codes indicates the symptoms and resolutions of the Camera. In C:13:01, the issue is with the Memory Stick being used in the Camera.
The Symptoms are:
Memory Stick Pro Duo 4GB is not compatible with the DSCF707 Camera. Maximum capacity supported by the Camera is up to 128MB. Please try using a MS with 128 MB and check if it works. A dedicated adapter (MSAC-M2) must be attached to use Memory Stick Duo or MagicGate Memory Stick Duo media.
Thanks.
KenSolutions
FixYa
Dec 24, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Memory stick is blank
Can you still see them on the tv? If so, you could get a card reader and download the pics to your computer. Then, you could format the card in the camera to get it working again.
Nov 17, 2009 | Sony Cyber-Shot DSC-S40 Digital Camera
When i switch on my sony cybershot DSC-S30 camera
A letter and number error code of C:13:xx is an indication the recording media (floppy disk or Memory Stick® media) you are using is either not supported for use with the camera, not formatted properly, or is damaged or faulty.
Refer the links:
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C356202&sliceId=1&docTypeID=DT_KNOWLEDGEARTICLES_1_1&dialogID=76702925&stateId=0%200%20180284222
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C186797
Oct 15, 2009 | Sony Cyber-Shot DSC-S40 Digital Camera
Memory Stick error c:13:01 My old 512 MB memory stick is working fine. However, recently I brought a 2 GB memory stick and when I put it inside, the camera (Sony DSC S40 cyber shot) shows: MEMORY STICK...
Is your new 2GB memory stick is original from Sony or after market? some of them will not detect in CAM because the contact on MS were not touched iside the slot of CAM
Reinsert your 512 MB MS if it work fine then change your 2MB MS
Good luck
Nov 30, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
User manual for digital camera
Hello, Try this link and select download on top of page. Hope this helps. http://www.retrevo.com/search?q=Sony+DSC-S40&terms=review+manual
May 02, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
Format Error in Sony DSC-650
Please try with new memory stick. If it does not help please claim for an in warranty repair. If you need more info please advice.
Apr 12, 2007 | Sony Cyber-shot DSC-S600 Digital Camera
Memory Stick Pro Duo 1GB
First try and clean the card slot. If this does not solve the problem, replace the memory card and try.
Dec 28, 2006 | Sony Cyber-shot DSC-S600 Digital Camera
Sony Cyber-Shot DSC-S40 Digital Camera Logo
429 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
