Question about LG DLE2516 Electric Dryer
Runs but will not heat. Power outages in area over last few weeks.
    Problem Solver:
  • 11 Answers
If the dryer was running during an outage, even with a very brief flash there usually is a power surge when it comes back on. If everything else seems to work okay it's possible that the heating elements got fried. You can check them with a voltmeter. Also check to seek if the dryer has overlaod protection. Most have a reset. One other thing that could happen, the breaker is defective. That you can check at the back of the dryer where the plug cable attaches to the dryer.
Posted on Apr 09, 2011
After a short power outage, I have clock issues.
this a problem with the clock , but the microcontroller can be defective by the power outage, see the diagram . how the microncontroller has the control for any equipment.
IN SHTE M.CONTROL BOARD CAN BE DEFECTIVE. go to the repair shop Tv FOR FIX IT. God bless you
Jul 19, 2012 | Microwave Ovens
Our refrigerator started not being cold
your rtc or contactor on the compressor body needs replacement
Jan 01, 2010 | Maytag Performa PAV2200
Totaline Thermostat either P/N 474-0100 or -0220
The power outage probably caused the thermostat to go back to factory default settings. You need to go through the advanced setup procedures in the owners manual on page 6. This will allow you to turn the heat pump back on.
Oct 05, 2009 | Heating & Cooling
Whirlpool Dryer not heating
first check the circuit breaker in the house, turn it off then back on. if that does not do it then let me know so we can go to the next step. Mike
Jul 14, 2008 | Whirlpool LER4634J Electric Dryer
If it was taking longer to heat it probably has a restricted vent. Check for lint build-up. May also have blower cage full of lint.
UNPLUG UNIT FIRST!!
To access blower cage, remove rear panel. Remove four screws holding duct on left side in place at bottom. Remove two screws at filter area on top. Pull duct out at bottom and reach inside and remove lint.
Also ohm out all thermos. Check thermos on side of heater. Check white one to right of duct you cleaned. Check between larger two wires on four wire thermo. All should show zero resistance.
Check between two outside blades of plug. Should have about 220 volts. Pull plug out slightly and carefully check for power between outside blades. Then check for 110 volts from center to either outside blade. It only requires one 11o volt circuit to run, but both to heat.
Nov 08, 2007 | Whirlpool Estate TAWS750PQ 27-Inch Washer
This can be due to malfunctioning of any of these 4 devices..
1)Heating element
2)Thermal fuse
3)Thermostat
4)Timer motor
For more info and troubleshooting checkout this link..
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Oct 22, 2007 | Whirlpool LER4634J Electric Dryer
Microwave runs but does not heat.
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
For more help from Emerson http://www.emersonradio.com ; Get help using your appliance 1-800-898-9020 ; Get help locating a servicer or parts 1-800-695-0098.
Aug 12, 2007 | Emerson MW8107WA Microwave Oven
LG DLE2516 Electric Dryer Logo
152 people viewed this question
Top LG Dryers Experts
Tim Whalen
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
