Question about Fedders A7DH45B2A Dehumidifier
Unit indicated that the tank was full, it was empty, I open and close tank , then the unit blew my circut breaker. please note the full indicator light did go out.
  • Fedders Master
  • 43,501 Answers
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Posted on May 27, 2011
Does not shut off when tank full, water leaks all over the floor if I don't watch it constantly
Sounds like the float valve inside tank may be stuck in closed position. Calcium buildup is very common. Good luck Juliana. Unplug and empty tank of any water and look for the float valve it should be near top of tank. Use a small bucket and mix vinegar and water and brush. Scrub that valve. Clean it up
Jul 13, 2016 | Windchaser Dehumidifiers
Model# a6dh50b2a. Bucket empty. Why does full bucket indicator light up and unit turns on and right off?
This can be a fault of the internal interlock (switch) that is closed when the bucket is in place. Normally, the purpose of the interlock is to prevent the dehumidifier from mindlessly dumping condensate into a missing bucket.
Sep 21, 2015 | Fedders Dehumidifiers
Dehumidifier will not start
You emptied the tank, right?
Sep 02, 2014 | Maytag Dehumidifiers
Why is the empty bucket signaling full bucket
See if there is a float switch in the unit that may be stuck.
Aug 31, 2014 | Zenith 30 Pint Dehumidifier ZD300
Full light stays on always
Don't know your model specifically, but most dehumidifiers have a float that shuts the system down when the tank is full. Maybe the float is not going up and down like it should. With the power off and the tank out, see if the float is descending like it should when the tank is out. Popping it up and down a few times might solve the problem.
Apr 13, 2014 | Comfort-Aire Dehumidifiers
I have a code on the screen CH 01... What do i need to do to get it to run again???
CH 01 Indicates that water collection tank is full and needs to be removed & emptied. Turn the unit OFF and unplug it, before removing the bucket.
Sep 21, 2011 | LG LHD45EL Dehumidifier
I have a slow blinking red light - not working
Normally, the slow blinking red light, indicates that the water collection tank/bucket is full and needs to be emptied. If the bucket is NOT full, it indicates that the tank/bucket was not installed or reinstalled properly, because it did not make secure contact with the bucket removal safety switch. Removing the bucket and reinstalling it properly will normally resolve the problem. Make sure the bucket fits squarely into it's holder from top to bottom.
In case you have misplaced your Owner's Manual, I have included a link to it, that you can download and print for future reference. http://www.appliancefactoryparts.com/content/pdfs/117029-1.pdf
I hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 13, 2011 | Comfort-Aire BHD-301 Dehumidifier
Has power but full light tank light is on but the tank is empty although it does sometimes start for a few seconds . have purchased 2 of same model at same time (june 2010) and the other one is fine,please...
Wayne, the condensation collection bucket may not be seated properly in the unit. Therefor, it does not make proper contact with the safety switch. Try reinstalling the bucket while the unit is ON.This will give you an indication if the safety switch is being triggered. The over all problem is in the safety switch. Also, make sure the unit is sitting level.
Hope this helped you solve the problem. Please be kind enough to take a moment and rate my response. Thanks!
Mar 24, 2011 | Dehumidifiers
Polar wind dehumidifier: p1 or p2 code after emptying tank.
P1 error indicates that:
  1. The water tank on the side of the unit is full.
  2. The water tank in not properly seated in the housing.
  3. The switch at the back of the water tank housing is not engaged or is loose
Jul 24, 2009 | Kenmore 54501 Dehumidifier
Dehumidifier
See if you have a grounded circut in the appliance. Check 1 flat to your volt ohm meter. Connect the other probe from meter to the other flat. And you should get a reading of resistance. Next connect 1 probe to the flat then the other to ground. A reading - indicates nothing until the next step. Now try the other flat to the ground?
1 Of these flats are connected to the nutural and possible feed through or back to ground in the appliance. The other one though should not read to ground. If you get a ground reading on both flat of the plug in someting is together that should not be.
If you dont get a readign try plugging in at a different outlet. A circut that has too much load will cause circut breakes to over heat and trip.
If it runs at a different outlet make sure its on a different breaker. If its on the same breaker it will probably start acting up again.
DOes this help? If so please rate me as high as possible If not please restate your problem to help me understand it better. Thnaks for using Fixya and Good Luck.
Aug 31, 2008 | Whirlpool AD70USS Dehumidifier
Fedders A7DH45B2A Dehumidifier Logo
260 people viewed this question
Top Fedders Dehumidifiers Experts
Bill Long
jasbo
jasbo
Steve
Are you a Fedders Dehumidifier Expert? Answer questions, earn points and help others
