Question about Vacuums
Is it possable to fix conair steam machine? - Vacuums
  • 2 more comments
  • Darren Lindstrom Apr 09, 2011
    I have a conair steam machine model #GS10RH that leaks. Can it be fixed and where can I get parts.
    It is a garment steam machine, or fabric steamer, model GS10RH
    It looks like it is coming from the heating tank.
    I had a bad feeling about the outcome, but thanks for verifing my thoughts.
  • 43,501 Answers
Exactly what do you mean by "Conair Steam machine" There are a number of things that could be refered too by that...
Do you have a model for your unit....
That aside.... Yes most anything can be fixed but often it is not economically feasable...often the repair and the time involved will be more then the cost to replace the unit. Of course this will depend on the replacement cost of the machine.....
Anything under $200. replacement cost is usually not worth even looking to repair.
heatman101
Posted on Apr 09, 2011
  • D. Floyd Kolb
    D. Floyd Kolb Apr 09, 2011
    Can you tell if the tank is leaking or if the leak is coming from where the tank seals into the machine???
    Or... does the water come from the machine tank???
    The first thing will be to identify exactly where the water is coming from...
  • D. Floyd Kolb
    That is not good news....
    That tank would be the hardest part to fix....often the seams of the tank come apart and cause the leak...
    Till you would get the unit apart and then get the tank fixed you will be better off to get a new unit...
  • 844 Answers
Welcome to FixYa!
It depends on the gravity of the problem and the model of your steam machine.
Thanks for using FixYa.
Jas247
H o w to clean a ball tip bristles on a Conair hair brush?
with a comb . or throw it in the washing machine once in a while .
Sep 15, 2015 | Conair Vacuums
The steam comes out of the water reservoir cap instead of the steam Jet Nozzle.
I can only guess since I have never worked on one of these units, but I think you lost a gasket on the cap. Pressure must build in the reservoir before being forced out the nozzle.
Jul 13, 2015 | Tristar SB Steam Buggy Vacuum
Steam cleaner sc20
It works like a squirt gun, submerge complete unit into water to add water. After it fills pull out and ready to use.
Jul 28, 2014 | Conair SC20 Handheld Steam Cleaner
Why no steam on polti 715 no steam
I had this problem, that is, my Polti 715 would not create an steam at all. It turned out that the boiler/steamer unit inside the Polti was badly corroded. So the only way to fix it was to replace the boiler/steamer unit inside. I had to send my Polti to an authorized repairer to have it fixed. The reason for the corrosion was that I did not follow the manufacturers instructions fo run the Kalstop solution through the machine every few months to stop calcification in the boiler.
May 03, 2014 | Polti AS700 Canister Steam Vacuum
Shark steam mop,s3501,small plastic steam valve from the machine to head is broken,
depend if the parts is plastic or metal. You can use gum for to fix it. If Not possible you must order the new ones. Specially if the parts is working hard. God bless you
May 16, 2012 | Vacuums
I have a Pro Steam Scunci Model PS-3888, Portable household steam
I own the PS 3888 and am just about to sell the entire unit at a yard sale. I would be glad to help you out but I think the mailing cost of the machine would be prohibitive.
Mar 07, 2009 | Scunci 52067 Handheld Steam Vacuum
POLTI VAPORETTO PROBLEMS
Hi, It is the solenoid that is sticking, It there fore needs opening up, the solenoid valve stripping and cleaning, or replace at a cost of about £12 then putting back together. they don,t like being left and not used. It is possable if you keep clicking for it to start working again.
Dec 09, 2008 | Polti Vaporetto 2400 Canister Steam Vacuum
Brushes won't turn
this would be a bad turbine and is fairly simple to replace. first take all the screws from the base of your steam vac. then look toward the top under the dirty water tank there will be a black tube with 4 screws that also need to be removed. i believe after this you should be able to remove the hood assy. if not there may be one more screw on the hood, if so remove. at this point you should see the bad part.take 2 more screws and hoses from it and install the good part. hope this helps, this machine is fairly new to me also.
Sep 29, 2008 | Hoover F6212-900 / F6215-900 SteamVac...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
