Question about Compaq Visual Fortran Professional Edition 6.6 (QB-5UDAB-PA) for PC
Problem with Compaq Fortran & Vista
Hello, I have a problem installing Compaq Fortran 6.6 on Windows Vista. I installed it under administrator account, but when I tried to open the Developer Studio, a windows popped up with the following message:
"A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available" and it does nothing and the program can't be opened. I would appreciate any ideas or suggestion on how to fix the problem.
Thank you,
Sanaz
  • 4 more comments
  • hamid_msli Sep 04, 2008
    As a matter of fact, I have the same problem. Any guidance is appreciated.
    Thanks,
    Hamid.
  • jori2008 Jan 11, 2009
    me too
  • sturbock Feb 16, 2009
    I have the same problem, and notify you when a new solution is offered. thank you
  • Anonymous Mar 07, 2009
    I could start CVF, but not to debug the code, then I uninstalled and reinstalled the program, CVF could not start normally.
    VISTA sucks
  • Anonymous Mar 14, 2009
    me too
  • Anonymous Apr 28, 2009
    Running as an adminstrator allows the program to open, but I still can not compile any files. As a note, I installed the program in compatibility mode for XP SP2. When I run the program, I also run it in compatibility mode to no avail.
I found the solution fortunately:
It's enough to do a right click on the bottom: "Developer Studio" instead of double click, and select: "Run as Administrator" , then select: "Allow" and so on..
Try it, it works!
Posted on Sep 05, 2008
Hello ,i try to install visual studio 2008 .iam get error message say that
Posted on Jan 04, 2010
  • Phelippe Pereira Jan 05, 2011
    hello, I found the solution!!!
    I use windows 7, and I found the problem when I used my compaq visual fortran. I just to do a right click on the bottom: Developer Studio and click in Properties icon and to go to Compatibility bar, so I check the option "Run this program in compatibility mode for:" and put it in "Windows Vista (Service Pack 2)".
    Try it, it work with my problem and now I can use the Compaq Visual Fortran!!!!
I have the same kind problem with Compaq fortran 6.5 on windows vista. "windows cann't find the file ****", and then stop! it is used well last month!
Posted on Aug 24, 2008
  • rementhe
    rementhe Sep 11, 2012
    I've installed CFV 6.6 onto a Vista Laptop, and it works well.
I tried to run it as administrator, tried all the compatibility modes and it still doesn't work! Any ideas? I'm using vista and I'm hating it!
Posted on Feb 26, 2010
I am trying to install fortran 6.5, but appears the message..."C:/windows/system32/*,* is ready only....but when I try to unread at this folder is not possible. I really would appreciate any help with...
If you are running windows vista or 7, try to launch installer as administrator. to do this right click on installation .exe file and select "Run as administrator".
Mar 23, 2011 | Compaq Visual Fortran Professional Edition...
I have installed compaq visual fortran 6.6 on my Laptop with the OS Win7 64bit Ultimate, but it doesnt work properly. The error message is: Microsoft (R) Developer Studio has stopped working.
I have successfully installed PGI visual fortran on my Laptop with the OS Win7 64bit Ultimate,and finally I have found how to build and execute programe on it.You can try PGI visual fortran. v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} p\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} v\:textbox {display:none;}
Aug 16, 2010 | Compaq Visual Fortran Professional Edition...
Visual fortran 6.0 won't work in windows xp sp2
whe runnig the setup right click on setup.exe >properties >select compatblitiy >select windows 2000 and install the fortan
or if you have allready installes
and righ click on FORTRAN shortcut set the compatibility mode same as above for windows 2000 good luck
please rate this solution...big help
Apr 08, 2010 | HP Compaq Visual Fortran Standard Edition...
I have compaq visual fortran professional edition 6.6 for win32x86 systems (year 2001). I am trying to install it on my new windows 64 bit Dell desktop. It does not install. When I click the setup.exe, I...
Click Start
Click All Programs
Click Accessories
Click Program Compatibility Wizard
Tell Windows (64-bit) that you are trying to install a 32-bit application.
Or, upgrade to the latest version of Compaq's Fortran system.
Jan 08, 2010 | Compaq Visual Fortran Professional Edition...
How to run digital fortran 6 on windows vista
Here is what I did. Open the DVD (right click and select Open), and then open the X86 folder. Run the Setup.exe file from there and it should install and work fine. I had an error during install near the end, but it seems to have done no harm. I compiled one of my old Fortran apps and it works fine.
Dec 15, 2009 | Compaq Digital Visual Fortran Professional...
96% setup was unable to create the program folder
I had the same problem, to solve it I repeat the installation and when the message "Setup was unable to create the program folder" I went to installation directory "C:\Program Files\Microsoft Visual Studio" and I made a copy of the whole directory to another location in my hard drive. Then I back to installation screen and I accepted the message box. As it was expected original installation folder disappeared. I restored installation folder from the copy I had made previously. At last I created a short cut to "C:\Program Files\Microsoft Visual Studio\Common\MSDEV98\BIN\DFDEV.EXE" and started Visual Fortran from this shell without any problem. I hope this tip could be useful, regards. tbeltran
nd search for the
Sep 21, 2009 | Compaq Visual Fortran Professional Edition...
Compatibility issues between Compaq Fortran and Vista
hi,
i ill ask u to simply use a xp os, so that u wil not have such a problem occurring again. or partition you hard drive so as to install both xp and vista os.
Sep 20, 2009 | Compaq Visual Fortran Professional Edition...
Reinstallation problem
Same error here. Compaq Visual Fortran 6.5/6.6.
I think is a problem related to Windows XP SP3.
- Solution:
Re-install Windows XP SP3 (integrated).
Right after installation (no reboot) run the CVF installer. It will work.
Then do normall installation stuff.
If you have Windows XP SP2 you won't have any problem.
Hope it helps.
Couldn't find ANY solution with SP3 installed before CVF installation.
Mar 21, 2009 | Compaq Visual Fortran Professional Edition...
Compiling and linking in vista
Vista's not my favorite yet, either.
There could be a million reasons why it won't run, many of which you won't be able to do anything about.
That said, perhaps turning off the UAC security, defining another user as an administrator, and trying to run Fortran might help. At least you won't be running into the whole "run as administrator" nightmare.
But, here's another thought...
If you're machine is powerful enough, maybe you could use Virtual PC or VMWare to build an XP machine where it will run.
(I cut my programming teeth on Fortran, a looong time ago!)
Jun 05, 2008 | Compaq Visual Fortran Professional Edition...
Compaq Visual Fortran Professional Edition 6.6 (QB-5UDAB-PA) for PC Logo
6,732 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
