Question about Kenmore Side by Side Refrigerator
The fridge is not cooling and the freeze is working. There is ice on back of the refrigerator and frosting up in the freeze on the back panel. The fan is running. Model number is 363.9527710 side by side
  • Kenmore Master
  • 2,128 Answers
If there's ice on the back wall of the freezer you have a defrost problem,bad thermostat,heater,timer.the machine isn't defrosting and ice is building up on the evap coil behind the freezer panel.inside the fridge section up on the top right side you'll see a hole where you can stick a screw driver into and turn the timer slowly until it clicks,now it will be in defrost.you'll know if you have it in defrost the fan will shut down in the freezer.now pull off the back inside wall in the freezer,if the heater is on then you'll know you have a bad timer,it's not going into defrost.if the heater isn't on you'll have to check with a meter to check the heater and the thermostat,the thermostat is on top of the coil.you'll have to melt out all the ice with a hair dryer to remove the heater to check it with your meter,also you can look at it,if it looks all black inside the glass change it out,it's a good idea to change the thermostat out to so this way you won't have any more problems with the heater or the t-stat,if you're gonna change the t-stat out anyway an easy way to check the heater is to melt the ice off of the t-stat,cut the two wires going to it,and put the wires together bypassing the t-stat,if the heater comes on then you'll know the heater is good and the t-stat was your problem,melt out all the ice annd install the new t-stat.when you go to cut the wires on the t-stat shut the control off or unplug the fridge so no power is going to the t-stat,after you connect the wires bypassing the t-stat turn it back on so if the heater is good it will help you melt out the ice,if the heater doesn't come on then change out the heater and thermostat,also if after like 20 minutes the fan comes back on the machine came out of defrost and you'll have to turn the timer again into defrost or just unplug the fridge,change out your part and when you're down plug it back in,however you feel comfortable.call your parts store,give them the model number and they will sell you the parts you need.good luck,if you have any more questions or something you don't understand let me know,i'll be happy to help you.i don't know if there's one heating element in there but the new one is a double element,it's easy to hook up.
Posted on Apr 09, 2011
  • Kenmore Master
  • 3,740 Answers
This refrigerator was made by GE for Kenmore.
The frost in the back of the freezer is telling you that you have and automatic defrosting problem.
This can be caused by the defrost timer:
http://www.appliancepartspros.com/part_details.aspx?part_id=2061695
or
The defrost heating element:
http://www.appliancepartspros.com/part_details.aspx?part_id=2635762
or wiring.
Most of the time the defrost control stops advancing so the unit never defrosts. This is what causes the ice to build up. There are 2 tabs on the defrost control face. Find the defrost control and the rotate the dial with a flat blade until the compressor shuts off. This is the defrost cycle. You should notice that it may start making weird noises in the defrost cycle. Pop Bang... etc.
What you can do to get about 3 good days of use out of it is to unplug the unit.. direct a fan into the freezer compartment with the contents removed for just over 2 hours. (makes a water mess!)
After the 2 hour period, re-load freezer contents and return the unit to normal use. It will work fine for up to 3 days and then start freezing up again.
Thanks for choosing FixYa,
Kelly
Lg Icebeam Door Cooling fridge/freezer top of freezer not freezing
is the fan not working in it..may be jammed up..we had an old unit that did this all the time.. the door seal was bad allowing house humidity inside and it wpuld frost up so bad the fan got stuck..we eventually bought another used unit..
Jan 20, 2014 | LG Refrigerators
Fridge warm, freezer has frost on back panel & is defrosting, fans work, just changed defrost thermostat, no air is moving from freezer side to fridge side, drain pan under fridge is dry
this fan needs to run when the compressor runs,check fan blade for being jammed by ice if you have this much ice on back wall as ice will stall motor,if no fan there will be no cool air to refrige compartment also the defrost drain tray will fill with water then freeze over which in turn floods the freezer floor and refrige compartments cause it cannot drain to the pan in the bottom
May 11, 2012 | Kenmore Side by Side Refrigerator
Freezer not freezing but cools like the refrigerator would. Refrigerator not cooling enough. the cover in the back of the refrigerator was off. I reconnected but the freezer still won't freeze
is the freezer fan running? is there frost on the rear freezer wall if so it would be a defrost issue. if no frost on freezer rear panel it would sound like a bad compressor or sealedsystem leak.
Jun 06, 2011 | Kenmore Top Freezer Refrigerator
Kelvinator no frost KBNT23AS back plate in the freezing compartment is icing up but the ice trays are not freezing. The lower compartment is not getting cool enough.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 05, 2011 | Frigidaire Freezers
The freezer works, but the ice cube maker gets frosted up, and the refrigerator barely gets cool
Make sure the fan is running in the fzr the fridge side steals air from the fzr via a small duct to the fridge. If there is a lot of frost you may have an ice block on the cooling coils in the fzr usually behind a back panel. If you have an ice block your defrost timer,heating element, defrost limit one of these could be bad. Let me know if you find an ice block or a lot of frost. good luck
Aug 16, 2010 | Kenmore 50522 / 50524 Side by Side...
The fridge compartment of fridge freezer has stopped working.the freezer doesn't seem to be freezing correctly and frost/ice is building up around the insulated pipe where it enters the freezer at the...
I removed the freezer drawers removed back panel inside the freezer,and discovered that ice had built up around the vent which cools the fridge compartment once I melted this using a hair dryer put it back together and the fridge compartment works fine.
Dec 29, 2009 | Refrigerators
GE Refrigerator Not Cooling (TFX27ZPBGWW)
The unit isnt defrosting hence the ice on the back panel. Either your bimetal thermostat is open or the heating element is shot. Most GEs they come together so happy hunting. Those parts are behind the frosting panel
May 28, 2009 | GE J Series 18.2 cu. ft. Top Freezer...
We have a bosch air flow fridge freezer
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
Mar 14, 2009 | Bosch Refrigerators
Refrigerator and freezer not cooling
the relay on your compressor is more then likely the problem it is on the left of the compressor
Jan 07, 2009 | Whirlpool ED2FHEXN Side by Side...
I've got an electrolux frost free fridge freezer and it is not freezing. The fridge is cool and cold air is entering the freezer compartment but it is not cold enough to freeze the food. I've removed all...
remove the back panel inside the freezer and check for ice build up on the evaporator pipework. if ice build up, this prevents air flow and hence temp rises.
remove ice carefully with a hair dryer and it should work. if problem comes back, you have a problem with the defrost system and get back to me if you want
Aug 05, 2008 | Electrolux Refrigerators
Kenmore Side by Side Refrigerator Logo
163 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
