Question about Saeco Vienna Digital Coffee Maker, Espresso Machine
Hi! One of my friends has an old Vienna Digital coffee maker (Saeco). It works fine. The only problem she has is that her coffee is never hot enough. She has to put her cup into the microwave if she wants her it to her taste. I tried to rince my cup with very hot water beforehand, but to no avail. It was still not hot enough. Is there any way we can increase the heat of the water, so that our coffee is just right? Thank you in advance
    Problem Solver:
  • 13 Answers
There is a thermostat that is stuck on the boiler. I would suspect that this thermostat has either:
1- A bad contact with the boiler. Contact is assured by thermal paste
2- The thermostat is faulty and gives false readings, thus preventing the boiler to heat the water enough.
Hope this helps
Posted on Apr 19, 2011
I have Saeco Vienna digital coffee machine already for 7 years. It was working fine but now I have problems. Only small amount of water/coffee goes to the cup and rest (clear water) goes to the tray and...
Hi
You boiler is leaking. You need to replace the boiler. sorry. Your water hardness might be set to low if you have been descaling when it tells you to. Boilers usually last 7 to 10 years, but need to be replaced. If you need one let me know. I have some new and rebuilt boilers for that machine.
Mar 08, 2010 | Saeco Vienna Digital Coffee Maker,...
Weak coffee saeco vienna "not digital "
Hi
Has the size of you ground coffee changed? If it is not the size of granulated sugar then its your grinder. Check ebay completed listings. Saw one there couple weeks ago.
Nov 24, 2009 | Saeco Vienna Digital Coffee Maker,...
Only hot water comes out of the steam wand
Hi
Sounds like you might need a new steam boiler, or you may have a fuse that is blown for the steam boiler.
Oct 06, 2009 | Saeco Vienna Digital Coffee Maker,...
My Vienna Digital suddenly makes weak coffee and it not hot
Try resetting the maching to factory settings.
Here is another question, bear with me, what do you brew the coffee into? And is it pre-warmed?
Jun 08, 2009 | Saeco Vienna Digital Coffee Maker,...
Saeco vienna saying brewunit blocked !
Hi There is a test mode for the Digital and we can see if you have a bad power board. Turn the machine off in back. Push and hold the small coffee button and the menu button (top left) at the same time and while you are holding the buttons turn the machine on. Release the buttons and you should have numbers in the display. If you can push the bottom left button and the machine makes a sound like the motor is moving, turn it off and then back on. If you don't get the message now you should really clean and lube your brew unit.
Jun 05, 2009 | Saeco Vienna SuperAutomatica Coffee...
Hot water
Grinds are too fine and or the coffee chute is clogged.
Feb 19, 2009 | Saeco Vienna SuperAutomatica Coffee...
Vienna Digital Hot water problem
How old are the machine?
Do you have a mod.no?
There are two type of boiler to the machine. If you give me the mod.no then can i give you a spare part number.
Where are you from?
Jul 20, 2008 | Saeco Vienna SuperAutomatica Coffee...
I had this problem on my Saeco Vienna Digital a while back. I read somewhere just to keep on ventilating, even if it took 20 hoppers of water. Sure enough after about 16 cycles, I heard a change in the noise and looked to see the ventilate sign was gone.
Oct 24, 2007 | Saeco Vienna Digital Coffee Maker,...
The water does not heat up
my sugestion is that you buy a new heater cost less than to repair the old one.goodluck.
Mar 29, 2007 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna Digital Coffee Maker, Espresso Machine Logo
183 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
