Question about Kenmore 15516 Mechanical Sewing Machine
How do you put the shuttle hook back in the machine? I took it out to clean behind it and can't figure how to put it back in. The way I put it in keeps cuting the thread.
  • 399 Answers
SOURCE: I have a Brother SE-270D
its the problem of the timing belt in your machine its extra loosen or extra tightned or is slightly came out of its position or finally broken.
as the machine is proper just missing the proper speed as it should be .
it is running continuosly as you stated.
check the timing belt and make it proper if its worn out and needs replacement this is how its done
There is an adjusting screw on the right side of the machine head. Follow the motor bracket to the machine head and loosen that big old screw or bolt which will raise or lower the motor giving you slack to remove or replace the belt.
feel free for further queries
thanks
Posted on Sep 19, 2008
  • 155 Answers
SOURCE: Installing the hook and bobbin assembly.
Needle Faces Where?
I Need to Tighten the Tension....
Changing a Needle
Need Help
Basic Questions-
Bobbin Assembly Popped Out!
Do You Think My Machine is Fixable?
How to Change a Broken Needle
Needle Bar Adjustment
Oiling an Elna 3007
Getting the Timing Belt Off?
What Size Needles for My Machine?
How to Oil my Machine?
Where to Oil??
Stitch Length Knob Woes
Can't Seem to Put the Bobbin in Correctly
Timing Belt Tension
Adjustments
Running Very Slow-
Oiling Points on Singer 257
Oiling My Singer Touch & Sew
Singer 457
Featherweight Case Odor
Brother XL2010 Q's
Does My Machine Have More Than One Belt?
Cannot Seem To Adjust the Tension
What to Do About a Gumming Up Needle
How Tighten My Bobbin Tension, Please
Is it Covered Under Warranty?
Proper Threading Instructions?
Just a Foot Pedal?
Simple Threading Instructions for a 1036
Threading a Singer 600
Replacing a Blade on a Johnson Ruffler
Changing the Needle
Lubricating a Singer 1036
Thread Balling Underneath
Warranty Info
Machine Covered in Hardened Oil
Spindle Stuck?
Do Motors Die?
Singer 457
Brother Sewing Machine
Servicing My Machine-
Belt Replacement
Lubricating My Sewing Machine
check out this  good luck  thanks.
Posted on Oct 26, 2008
kent581
  • 87 Answers
SOURCE: Can't reassemble shuttle hook and shuttle race
the hook driver (still in machine) is 1/2 moon shape. The hook is also 1/2 moon shape. If you set the machine on its back, it's easier. Set the hook 1/2 into the other 1/2 of the hook driver to make a circle. Then put the hook cover on (machine still on its back) with the tabs for the twist locks pointed out. Needle gaurd to the top of the machine. Snap the twist locks in place and viola!
Kent
Posted on Mar 18, 2009
  • 980 Answers
The plastic bobbin case should sit on top of the raceway, it should slot in quite easily, once the bobbin case is in put the small metal clip at the top over to hold it in place.
Posted on May 28, 2009
  • 128 Answers
SOURCE: Thread jamming under fabric
bobbins in backwards
flip it over
Posted on Dec 18, 2009
MY BOBBIN CASE HAS FALLEN APART AND I'M NOT SURE HOW TO PUT THE PIECES BACK TOGETHER.
Sounds like you are describing the hook. Perhaps the owner's manual would be assistance. We don't know the make/model of your machine so are really unable to help. There are some videos on YouTube that show how to install a shuttle and bobbin case, but machines differ.
Set up the shuttle race for RS2000 Series
Brother LS30 Inserting Bobbin Vertical Shuttle Hook
How to Clean and Maintain your Sewing Machine at Home Front Loading Bobbin
Mar 14, 2016 | Sewing Machines
How do I time a bobbin hook on a 153W Singer
all sewing machines are basically the same, the hook that rotates to pick the cotton up off the needle must just enter behind the needle when it's on it's way back up which then grabs the cotton to form the stitch, so you must remove the sole plate to expose the shuttle case remove the shuttle and put to one side, now rotate the hand wheel on the sewing machine in the correct rotation and watch the hook rotate round until it goes behind the needle, just as the needle is starting back up from it's lowest position the hook should just be going behind the needle to pick up the cotton, if this is not the case then loosen the screws that clamp the hook assembly to the shaft and rotate the hook assembly gently until the hook is just going behind the needle and make sure the hook is close to the needle before retightening the clamping crews , and final give it a few turns by hand to make sure the hook locates the same all the time and the hook is not catching the needle, when your happy, then reassemble.
Happy sewing
Feb 16, 2015 | Singer Sewing Machines
Should the machine have some oil? Where? It is a Bernina Activa 130
The Activa range is fitted with a light-weight part-plastic hook/shuttle that Bernina claims does not require oiling. However, this does not mean it shouldn't be regularly cleaned and I'd recommend that it is also lightly oiled at the same time. Remove the bobbin case, press the metal lever to the top left of the bobbin door and the black plastic hook/shuttle retainer should pop open so that the hook/shuttle can be removed, or it will just drop out anyway. Use a cotton bud to firmly clean around the inside edge of the hook race (the round piece that the hook/shuttle sits in. Give the whole thing a good clean to make sure any surface grime/fluff is removed. Put a small drop of oil on the running surface of the hook race - the recessed groove around the inside edge, before replacing the hook/shuttle and holding in place by pressing the hook/shuttle retainer back until the securing lever clicks back into place. Rotate the handwheel once to distribute the oil and off you go. Dont overoil but do this regularly and your machine will run much quieter and produce a consistent stitch formation.
Jul 07, 2011 | Bernina Activa 130
I took out the bobbin case and then the shuttle race. Now I can't remember which one I should put back in first.
Clean the shuttle area, the hook and the cover with a toothbrush, removing all lint and debris. Place one small drop of sewing machine oil on the rim of the hook. Place the hook back in the raceway and replace the cover. Snap the two retaining levers back to hold the cover in place.
Jun 02, 2011 | White Sewing Sewing Machines
Machine is very loud and jumpy
Usually this problem occurs on machines with a front load bobbin case. If so, remove the bobbin case, the shuttle hook cover (two levers to the sides of the bobbin case area cover and shuttle hook (part the bobbin case goes on and it is ½ mooned shaped). Then clean and oil (with Q-tips and sewing machine oil NOT 3 n1 oil) the round outer area where the hook rides. No lint at all and squeaky clean. Then 3 drops of sewing machine oil in rounded groove where the shuttle hook rides. Then replace the pieces:
Replace hook:
Identify the the hook driver (still in machine), it is 1/2 moon shape. The hook is also 1/2 moon shape. If you lay the machine on its back,( it's easier). Set the hook 1/2 into the other 1/2 of the hook driver to make a circle. Then put the hook cover on (machine still on its back) with the tabs for the twist locks pointed to you. Needle gaurd on hook cover to the top of the machine. Snap the twist locks in place, replace the bobbin case and viola!
Mar 20, 2009 | Simplicity Denim Star SW210
Kent
Mar 16, 2009 | Baby Lock BL1556
Pfaff creative 7570 shuttle assembly
Have a look at www.sewusa.com they have a "repair & threading page" this may help you re-assemble your machine. It is impossible to explain how to put the thing back together and re-time it, it is something you need to be shown how to do. Other alternative is to take it to a sewing machine tech.
May 02, 2008 | PfaFF Creative 7570
Putting back the pieces of bobbin case on Kenmore Mini Handi
This is for front loading bobbin..........
The Shuttle hook will look very much like this, and marries this to the "half moon" of the fixed shuttle.
The retaining collar ring that holds it all together has a plate like protrusion (like bull horns), this faces to the top and to the back.......there should be a small lug (or two) with corresponding small hole or slot on the fixed housing (hook race) that locates the ring tightly in the correct position.
There should be 2 swivel arms (black plastic at 4 o'clock & 8 o'clock)) that move to hold the whole thing together by clipping onto a small lug on each side of the ring.
If you tip the machine 30 degrees on its back while you do all this, it makes the process easier, as things are less likely to fall out.........support the back with a soft object for convenience (tissue box, pillow etc)
The bobbin case goes in after the housing is assembled, if you try to do it first, it will prove more difficult.
If this is not quite accurate for your model a photo of the bits would be helpful
Feb 27, 2008 | Kenmore 11206 / 11306 / 11506 / 11606
Kenmore 15516 Mechanical Sewing Machine Logo
127 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
