Question about HP Computers & Internet
I accidently dropped my HP G71-340US notebook laptop approximately 2 feet hitting the hardwood floor. It was closed and hit the front corner. It sill works fine except all pictures have a grainy, swirling look. For example, watching a You Tube video is nearly impossible to see. We took apart to make sure video cable was not loose and it was fine. Any idea how to fix?
    President:
  • 1,623 Answers
You have probably damaged the screen itself, try using it connected to an external monitor, if you have a good picture then your screen needs replacing
Posted on Apr 09, 2011
SOURCE:
My Samsung refrigerator door swings open an hits the counter. The model number is: RB2155SH.
possible unit settled on floor raise front and unscrew feet so when you let door go it closes
Aug 25, 2018 | Samsung Refrigerators
Dropped my HP D7 laptop. It slid out of my backpack from about 2 feet onto hardwood floor. On bootup, lights turn on for the keys and around the touchpad perimeter, and everything works fine with an HDMI...
You possibly cracked your screen or caused the ribbon cable to disconnect when you dropped it and just can't see what the error codes are saying. Is probably asking you if you'd like to start in safe mode with the beeps but you can't see it with a cracked screen or disconnected ribbon cable. Take it to a repair shop for a diagnosis.
Aug 29, 2014 | Computers & Internet
Door opens beyond horizontal hitting floor
There may be a second mounting hole on the hinge to reposition the spring but more than likley you have broken door cables
Mar 05, 2014 | Jenn-Air JDB1095AW Built-in Dishwasher
WHEN MY WASHER SPINS THE BOWL HITS THE SIDE OF WASHER MACHINE SO HOW DO I STOP IT FROM HITTING THE SIDES
Start off by following my guidance notes on balance/leveling-
It is necessary to ensure absolutely that the machine has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
(If this has not cured the problem it is possible that the internal suspension is malfunctioning.)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 12, 2011 | Washing Machines
Dropped on hardwood floor can still make and receive calls but external scrren pure white and internal black
Hi there
Your screen hit the wood badly that is why you have a black and white screen..
The solution to this problem is to fix a new screen for your phone .
Cheers!
Jul 03, 2010 | Cell Phones
My Compaq Presario F700 dropped approximately 2 feet to the floor from on top of a suitcase at the airport. It was in a case, but not a thickly padded one. When I tried to use the laptop after the fall,...
Try reseating the hard drive and the RAM modules, the fall may have slightly loosen these components.
The error message "Operating System not found" means the laptop could not find the hard disk, this problem could be the hard drive needs reseating, a faulty hard drive (they don't like being dropped), or a faulty disk controller.
Apr 28, 2009 | Compaq Presario 1692 Notebook
The nails aren't going in far enough using a air cleat nailer
I just finished 800 square feet of oak flooring with this nailer. You might have to increase the psi at the gun and make sure it gets a good square firm hit to set the nail. You can swing and hit the thing pretty hard, I hit it hard to set warped boards in place. I used 120 psi for best results, I tried 90 psi but had more misfires. The nail head only needs to set in far enough so the head is touching the tongue and so the next board will fit. The nail won't be buried into the tongue like you might think. If the occasional nail protrudes from the board you can use a nail set to drive the nail the rest of the way in, but I found that most of the nails didn't want to set by hand. I either clipped off the head with side cutters and folded over the remaining tab or did my best to set the nail if it wasn't long enough to clip. If it bends over really ugly, just carve a little wood from the groove lands on the next board to clear the nail stub. Removing the nails is difficult, it's best to let them be rather than risk damaging the flooring. Also, don't let the gun get down to the last nail. Sometimes if you try to fire the last nail on a strip it will twist and damage the flooring. Always keep a few nails in the gun just to be safe. Hope this helps.
Nov 23, 2008 | Porter Cable 2" Flooring Cleat Nailer...
Toshiba satellite a75-s209
Probably not. Not only could the motherboard could be damaged but so could the keyboard, hard drive, CD/DVD, the cabinet, and possibly the screen.
It would take several hours of repair work and if you notebook hasn't been made in a few years it may be hard to get a mother board.
Jul 17, 2008 | Computers & Internet
Camera fell off TV tray; lens bent and won't retract
i had the same problem. just force the lens back into place. I did that and it worked perfectly!
May 15, 2008 | HP Photosmart R927 Digital Camera
Open Questions:
Computers & Internet Logo
166 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
