Question about Dell Inspiron Mini 10 Notebook
My microphone is not working. i have tried to adjust the settings for the mic but it didn't help. also, the bottom of the netbook gets really hot. i never noticed this before. does that mean it's overheating?
It could mean thats its overheating or has in the past,but it also could mean that you possibly have blown the speakers and microphone without playing music that loud.It happened to me.
Posted on Apr 09, 2011
I get ALOT of feed back, why? I can't use it like that. I've talk with the a Tech and he said I needed to stand further away from the amp, which I am.
This sounds like your gain is too high. Adjust it down. Every mic has different gain settings so you can't just blanket this with the other one works fine. Is this wired or wireless?
Dec 24, 2014 | Shure SM58 Professional Microphone
My external mic wont work! Please help.
If the mic is working on other camera's, what about the adaptor ? If there is a possiblity of checking the mic and the adaptor together on other equipment ? Use another mic with the same plug as the camera, ie. PC microphone (you can even test by using an earphone, the earphone can be used as mic) If it works then the XLR mic with adaptor is the problem. If ther other mic (used for testing) also did not work then the microphone jack (socket) in the camera is defective or the gain setting of the camera is set to minimum.
Jun 05, 2007 | Panasonic Proline AG-DVC7 Mini DV Digital...
Hi my mic is not working I've tried adjusting it to the control panel and sound device still it doesnt work, netbook is Hanspree. Thanks
If the microphone is not working but you are getting sound from the computer, check microphone in sound properties to see if it is muted or disabled. If it is not, just install an updated driver for your audio device and it should work.
Hope this helps.
Jun 06, 2011 | Hannspree HannsBook SN10E22BU3221 Netbook
My built-in mic does not work at all....even recording videos, i can't hear myself talking....
Maybe if you right click on the loudspeaker in the task tray, (bottom right), and click on recording devices, see if the microphone is there. You may have a driver issue. Then click on external microphone and try one.
Hope this helps
Nov 03, 2010 | Lenovo IdeaPad S10-3 Netbook
So basically, i tried webcamming my friend thats in Germany, and she couldnt hear me, and i tried testing on my skype test call thing, and they said that my microphone on my laptop might be muted. I have...
go to Tools => Options => Audio Settings, see Microphone Volume, uncheck Automatically adjust microphone settings, adjust volume manually, test mic if green line showing up. To check if mic is muted, when calling contact in the calling window point on mic if it says Unmute microphone click on it, if it says Mute microphone it's already unmuted.
Oct 21, 2009 | HP Mini 1000 Notebook
Internal Microphone not working
This is not a problem with mic. Settings in System was changed so that mic has been muted. To enable goto contol pannel and Select Sound & Devices and Select Advanced in Device Volume there you will get Master Volume Settings Menu So that uncheck the Mic option and check for Mic Setting in that.
hope this will be helpful.
Thanks & Regards Nanda Kishore.
Apr 10, 2009 | Acer Aspire One Netbook 8.9" Notebook
Cannot get laptop microphone working
Double click on the little speaker icon on the Desktop toolbar at the bottom right of your screen. The volume control window will open. Click on options then properties. Next check the small round recording button. Now make sure he microphone box is checked then click ok. Now a window will open that will show your microphone recording level. Move the slider up about half way and make sure to check the small "Select" box near the bottom of the slider. Open up sound recorder or whatever application you are using and try to record. If this does not work I would get an external microphone plug it into your laptop and try recording again. If the external mic works then I would think that you internal microphone is not working. There are some very cheap external mics on the market that sound very good. If you are doing any serius recording you may want to invest in a USB microphone. The USB mic should come with it's own software and setup should be pretty simple. I hope I have been helpful.
Mar 16, 2009 | Compaq PC Microphone (Black or Beige)...
My micriphone attached to headphone seems not to work.
First, make certain that the mic is really broken, by testing it in another application or devise. Sometimes you cannot hear your own voice unless you are in recording mode! If the mic is found to be working, then try to reconfigure the software, or the Yahoo connection. Good Luck!
Dec 06, 2008 | ASUS Computers & Internet
Logitech microphone stuffed up my Computer Speakers!
go to sound icon in bottom task bar, double click on it,go to options,then properties,then click RECORDING,make sure you have a tick in MIC,then go to back to sound icon in bottom task bar,and adjust mic settings to suit
Rod
Sep 19, 2008 | Logitech (980240-0403) Microphone
My microphone on my acer aspire one isnt working
This solution works for the Windows XP version. Go to msconfig.exe, then the Startup tab. UNCHECK rthdcpl and restart. Realtek driver doesn't load, but who cares...the microphone works now.
Aug 09, 2008 | Computers & Internet
Dell Inspiron Mini 10 Notebook Logo
50 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
