Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Just replaced lamp, when we try to turn it back on the tirmer light flashes green and then the lamp light flashes orange continuously and the tv will not turn back on. We have tried plugging and unplugging the tv and the reset button nuerous times and the tv will not turn back on.
  • 1,476 Answers
Ljanicke,
From your description of the lamps and after looking at the error chart for the unit I believe that you have a problem with the lamp door. There is a switch on the cover which can get moved or misadjusted while replacing the lamp. Sometimes the door is just not closed properly. I have a tip at
http://www.fixya.com/support/r5207658-dlp_tv_run_after_replacing_lamp which should help you solve the problem.
Thanks for using FixYa and for the great rating.
hardrocko
Posted on Apr 09, 2011
My panasonic pt-521cx16 starts, green light flashes, then shuts itself off again
Have you even replaced the bulb / lamp on this TV - other than the green light - did they turn solid red / orange at any point? My initial thought is you need to replace the bulb.
Jan 22, 2018 | Panasonic PT-52LCX66 Projection Television
Replaced lamp but lamp light still blinks orange
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
Nov 22, 2011 | Mitsubishi WD-57731 57" Projection HDTV
When you turn of the TV the POWER indicator flashes green for several minutes. The TV never comes on. After the several minutes of the POWER indicator flashing green, it stops, I hear a click and the...
A continuous flashing red light with the word LAMP on it would definitely mean you're going to need to spend a few bucks on a new lamp....or for a few more, upgrade to a TV from this century that doesn't require lamp changes :)
May 11, 2011 | Panasonic PT-52LCX66 Projection Television
Suddenly turned off without warning Sony KDS-50A2000
All you need is to open the back cover of the television and check on for dry soldering at the power stage of the printed circuit board, also check for bulged capacitors, if found replace with same rating of voltages , but if otherwise Ur power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get ur tv power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this helout, Good luck....
Jul 11, 2010 | Sony KDS-50A2000 50" HDTV
I have replaced the TYLA-1000K lamp and housing, plugged the TV back in, turned TV on, pressed vol- & mute and nothing happens. The flashing green light comes on for about 3 to 4 seconds and then it...
amber is the colour...remove LAMP assembly...properly re-insert LAMP assembly back into TV...make sure it looks secure....close door and tighten screw.....door MUST be shut properly or TV will not operate correctly..it sounds too easy i understand TRY it you might be surprised!!!
May 19, 2010 | Televison & Video
The tv will turn on but no the screen wont. and
Replace the lamp would be the first thing to try. Lamp door switch on this model is notorious for going bad. If you replace lamp and still won't turn on jumper door switch. If you take off back you can see switch board.
Nov 21, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Panasonic PT-LB10SVU green light flashing,then orange,lamp light
i just replace the lamp, and don't have any light coming from lens,starting green (after a few seconds,green become to flash2_bing.gif), then turning on orange and lamp light flashing...please i need help, fan working perfect...i don't have a remote,is a problem, or not
Feb 25, 2009 | Panasonic PT-LB10SVU Multimedia Projector
Sony Projector
Ok we're back to the flashing lamp cover LED. The green flashes you are seeing is the TV trying to start up. After it tries for awhile, it will eventually shut down and display an error code, in this case, the lamp cover LED flashing which means either the lamp cover, filter cover or main cabinet sensing switches are not closed, are intermittent or have some kind of wiring issue. A solid lamp cover light (no flashing) would point to the lamp and lamp drive, but the flashing light points to the switches. Give me an email address and I'll send you the training and troubleshooting manual so you can see for yourself. Any ther help needed, please don't hesitate to ask.
Nov 01, 2008 | Sony VPL-VW100 (Ruby) Multimedia Projector
Sony Grand WEGA KDF-60XBR950 60 green orange green red flashing light
3 blinks is a lamp cover error, did you make sure that the lamp cover is screwed in tight? Also check the lamp cover for deformity, there is a problem with your model where the set over heats and melts the lamp cover a little causing it not to make connection with the lamp cover switch. Let me know if you find either of these problems? If not we can troubleshoot a little further.
Tim Nolan
Sep 14, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
46 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
