Question about HP iPAQ H5550 Pocket PC
Remove Program but can't remove icon on Programs Screen
I accidentally installed a program a couple of times (I know, not a bright idea), and I was given several icons on the programs screen for each time I loaded the software. I have multiple icons for the same program. How do I remove the extra icons? They are all named software(#). I just need the one.
  • 36 Answers
Probably need to use file explorer - find folder in windows for the desktop. Open it and you should see icons. Delete extra ones.
Posted on Oct 07, 2008
Removal of Produtools
You should always remove and uninstall programs from your PC that you are not using. It could be beneficial to your computer's productivity and functioning to free up space. You run the risk of running out of space on your computer if you add too many programs without uninstalling some. It is a relatively easy process, but you should be sure you are not removing a program that is necessary to the operation of your computer.
Click "Start" and select "Programs." Click "Control Panel" and "Programs" and "Programs and Features." Browse the list of programs on your computer and select one that you want to remove. Click "Uninstall." You may be prompted for permission from the administrator to remove the program. Enter the administrator password or confirmation if necessary. Check the properties of the program if it is not listed in "Programs." You can do this by right-clicking on the program desktop icon and selecting "Properties." Check to see if the program is compatible with the version of Windows that you are using. Click "Start" and "Run," to manually remove the programs if the uninstall option does not completely uninstall the program. Type "Regedt32" in the box and click "OK." Locate the "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall" registry key and click "Export" under the "File" tab. Click "Desktop" on the "Export Registry File" dialog box. Type "Uninstall" in the "File Name" box and select "Save." The left panel of the Registry Editor will display the programs that are currently installed. Right-click the key in the left panel of the Registry Editor window. Click "Delete." Click "Yes" when you are asked to confirm deletion of the program. Click the "File" menu and select "Exit." This will exit the Registry Editor. Click "Start" and "Control Panel" and click "Add or Remove Programs." Confirm that the program is no longer listed here. Hope this helps.
Jan 03, 2013 | Computers & Internet
Tip
How to uninstall program from my DELL computer
Questions people asked:
1 How to uninstall program that’s not showing up?
2 I go to add/remove programs and want to uninstall program. It says “error, can not delete the program”, how can I remove it from my DELL computer?
3 I recently install McAfee and my computer gets a Blue Screen, Should I uninstall it? How to remove it from Control Panel?
You may face stubborn program of uninstalling an unwanted program especially it is an anti-virus.
How to remove corrupt programs from your computer in one minute? You can get the best solution to remove a program completely from your PC.
Add/ Remove Programs utility usually helps you remove programs from your computer. Unfortunately, it can only find common program install on your computer. It can not show hidden programs and some malicious programs such like windows messenger, vista protector, Norton anti-virus 2006, etc.
You can not remove anything if you uninstall using Control Panel. Every time you install a program, your registry entries will be modified. The residue can be the causes of Blue Screen, computer freezing, DLL error and computer slow. If you want to remove programs completely, you should also remove associated registry entries. It is also the best solution to remove corrupt programs.
Get rid of programs which combine well with the operating system:
Troubled with uninstalling programs? Don’t worry! You can solve it in one minute. ErrorFix integrate with Windows registry fix tool, uninstaller, invalid file removal and IE restore program.
Download this excellent uninstaller now.
With this software, you can forcibly remove a program even it is running. Why not experience this wonderful software? You don’t have to get more computer savvy.
on May 26, 2010 | Microwave Ovens
Dell program 924plc32 4095Mb installed
What is the program associated to ?
It is up to you to determine if you the program installed was it installed on your computer as an accessory or at the time of the operating system installation ?'Is the program needed by any other programs to run ?
Dec 20, 2012 | Dell Dimension 1100 PC Desktop
Removing fliptoast from the program list doesn't get rid of it. It continues to appear on the top of most programs I run. How can I totally shred this little ******?
Hi Llewellyn,
Did you delete the program from your programs folder or did you uninstall it through 'add/remove programs' in your control panel. Simply deleting it from your list of program files will not uninstall the program.
Deleting installed programs could also corrupt your windows installation.
Best wishes,
Graemevm
Jan 12, 2012 | HP Computers & Internet
I want to remove the icons from the computer
You can remove icons by right-clicking and deleting them. If it is in the "All Users" profile, it will probably come back. Also, this will not remove the underlying program.
If you want to uninstall the program. Go to Start -> Control Panel -> Add and Remove Programs, and choose the program, and click remove. Follow the prompts for removal. Most programs clean up the icons installed. If not you may have to right-click and delete after installation.
Please let me know if you need further assistance.
Thanks
Mar 12, 2010 | Acer Aspire 3610 Notebook
How do you uninstall a program from a palm treo 750?
You need activesync
http://www.microsoft.com/windowsmobile/en-us/downloads/microsoft/activesync-download.mspx
ActiveSync’s Tools >Add/Remove Programs screen lists all the programs that have been installed on your device. To uninstall a program, uncheck the box next to it and click on OK. To reinstall a program, click on the empty box next to it and click on OK. Do not click on the Remove button. Here's how to do it: If you used ActiveSync to install a third-party program to your Windows Mobile device, you can uninstall the program quickly from your PC.
  1. Make sure your Windows Mobile device is connected to your PC and ActiveSync is running.
  2. From the PC’s ActiveSync Window, click on Tools >Add/Remove Programs. This opens the “Add/Remove Programs” dialog box, which displays a list of third-party programs you have installed on your device.
  3. To uninstall any of the checked programs, click on the box to uncheck it and hit OK—ActiveSync will do the rest.
Reinstalling programs you’ve uninstalled Once you’ve installed a program using ActiveSync, the necessary installation files are saved on your PC. If you uninstall the program as described above, you can use the Add/Remove Programs menu to reinstall it at a later time. Uninstalled programs appear in the Add/Remove Programs list as items with unchecked boxes. To reinstall it, click on the check box next to it and hit OK. ActiveSync will reinstall the program automatically. Note that files in CAB format can be downloaded directly to a device and installed, so they will not appear in the Add/Remove Programs list. In addition, some freeware programs are installed by using ActiveSync’s Explorer to copy the program file to your device. Those also do not appear in the Add/Remove list. WARNING: Do not click on the “Remove” button at the bottom of the Add/Remove Programs screen unless you never again plan on using the program. This completely removes the necessary installation files from your PC and you won’t be able to reinstall the program by checking the box.
Jan 08, 2010 | Palm Treo 750 Smartphone
Roxio Media Manager program installation will not complete. How do I uninstall.
Posted all operatings systems...
In Windows, how do I uninstall programs? Using the Add/Remove Programs control panel The Add/Remove Programs control panel in Windows makes it easier to uninstall programs. Follow the appropriate instructions below to use this control panel.
Windows 7
  1. From the Start menu, select Control Panel.
  2. In Large or Small icon view, click Programs and Features. If you're using Category view, under "Programs", click Uninstall a program.
  3. Select the program you want to remove, and click Uninstall. Alternatively, right-click the program and select Uninstall.
Windows Vista
  2. In Classic View, double-click Programs and Features. If using the Control Panel Home view, under "Programs", click Uninstall a program.
Windows XP in the default XP view
  1. From the Start Menu, select Control Panel.
  2. Click the Add or Remove Programs icon.
  3. Select the program you wish to remove and click Remove.
Windows XP in Classic View and 2000
  1. From the Start menu, select Settings, and then Control Panel.
  2. Double-click the Add/Remove Programs icon.
  3. Select the program you wish to remove and click Add/Remove.
Using the Uninstall program from the Start menu If the program you wish to uninstall is not listed among the installed programs, an uninstall program for that item might be available on the Start menu. To look for such an option:
  1. From the Start menu, select Programs or All Programs.
  2. Find the folder for the program you wish to uninstall and highlight it.
  3. In many cases, on the menu that appears, you will see an uninstall option.
Please let me know how this works out for you...
Thank you
Jon
Aug 12, 2009 | Computers & Internet
Sound
hi dear
Through the All Programs menu:
1.
Click Start.
2.
Point to All Programs.
3.
Point to Accessories.
4.
Point to System Tools.
5.
Click System Restore.
6.
Follow the instructions on the wizard.
Creating a restore point can be useful any time you anticipate making changes to your computer that are risky or might make your computer unstable. If something goes wrong, you select the restore point you just created and Windows XP undoes any system changes made since that time.
Create a Restore Point
1.
Open System Restore. (See step-by-step instructions above.)
2.
Click Create a restore point, and then click Next.
3.
In the Restore point description box, type a name to identify this restore point as seen in Figure 1 below. System Restore automatically adds the date and time that this Restore Point is created.
Figure 1. Creating a restore point
• To finish creating this restore point, click Create.
• To cancel restore point creation and return to the Welcome to System Restore screen, click Back.
• To cancel restore point creation and exit the System Restore Wizard, click Cancel.
To view or to return to this restore point, from the Welcome to System Restore screen of the System Restore Wizard select Restore my computer to an earlier time. Then select the date you created the restore point from the calendar in the Select a Restore Point screen. All of the restore points you created and you computer created on the selected date are listed by name in the list box to the right of the calendar.
Note System Restore does not replace the process of uninstalling a program. To completely remove the files installed by a program, you must remove the program using Add or Remove Programs in Control Panel or the program's own uninstall program. To open Add or Remove Programs, click Start, click Control Panel, and then click Add or Remove Programs.
oke
cropp
Mar 25, 2008 | Microsoft Windows XP Home Edition
Lost sound
hi dear
1.
Click Start.
2.
3.
4.
5.
6.
1.
2.
3.
oke
cropp
HP iPAQ H5550 Pocket PC Logo
149 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
