Hi, I need help to change the IP address to a docucolor 250 Thanks.
eng_darwish1
  • 233 Answers
SOURCE: default hp 2015 password so I can change the IP address
make a cold reset or NVRAM reset
To do a cold reset you power on the printer while holding down the go button for about 5 seconds and then release the button. If the button is held for more then 15 seconds it may do a NVRAM reset
Posted on Jul 07, 2008
SOURCE: Bizhub 250 scan to email error
Change your account information from external to internal, i.e. yourmaildomain.com to yourADdomain.local. Change on the scan account as well as the email addresses.
Posted on Dec 22, 2008
kakee
  • 1269 Answers
SOURCE: dell 5100cn change ip address
Changing Printer's IP Address isn't that complicated. There are two ways on how to change the printer's IP Address.
If you know the old printer's IP address, you can simply type that old IP address on the Address Bar of your Internet Explorer or any other browser (ex: http://192.168.1.101). It should redirect you to the printer's User Interface. From there you can go to Network then TCP/IP settings. You can change the IP address of the printer. Make sure to use an IP address within the same range of your network.
The other way to change the printer's IP address is by its own Menu/Settings on the printer's LCD panel.
On your printer, press Menu then got Settings. Look for Network or LAN settings and click on Advance. Select TCP/IP and click on Edit. You can now change the IP address of the printer from there. Click on Done or Save after that.
Note: Make sure the use the correct IP address within the network's range.
Posted on Jul 16, 2009
Bizhubman
  • 108 Answers
SOURCE: I have changed my Internet provider and it has a
Press Utility/Counter
Press Administrator
Input code 12345678 or 00000000
Select admin 2
Select Network
Here you can change the network settings to match you new Network scheme. You will have to reinstall the print drivers after you correct the network settings. If you have the driver disk it will auto run and find the machine, if you don't have the disk you can download the drivers at kmbs.konicaminolta.com where you can also download the user manuals in PDF format that will go into more detail on changing the network settings.
Posted on May 15, 2010
SOURCE: Docucolor 250 paper jam over and over and over and over....
contact me on mcjfrance@hotmail.com. I need more information about your problem.
Posted on Sep 16, 2010
I need to change my ip addres, i have an acer aspire with linux
This computer as any once assigned a IP address is locked to it
Jul 19, 2011 | Acer Aspire One PC Notebook
4300 laserjet wont print docs. IP address is same as a network computer, cannot change IP address? Configuration page prints and I check ports etc but will not print. cannot change IP address. Help....
Have you tried changing the IP address from within the driver's properties? Go into the print driver properties, and under the Ports tab, edit the 4300's port and change the IP address that it is associated with. You may need to reboot the printer once you make the change and save it, but that should allow you to change its IP address.
Jun 13, 2011 | HP LaserJet 4300 Printer
Hi, my computer cannot connect printer cause the ip address change. i set it back and swith off and on the ip address change to other ip again please help me thanks
maybe your network have DHCP server. WHen you set the IP on your printer, please select "specified the IP address, not select use DHCP.
Mar 18, 2011 | Epson 4880 Stylus Pro InkJet Printer
How change ip address of epson epl n2500
Hi, i know its been months already but i have a solution to your problem, we have same problem and i solved it already..First, you have to get the ip address of your printer,..Then, open command prompt..
At command prompt, Try this command;
telnet ip address (this is your ip address)
Then, as you can see, their is a lot of instructions there..
So, you must follow it..
Take note: It automatically saved the changes.
Second options:
Type the ip address of your printer at web browser, it looks like this:
http:/192.168.1.100/ (this must be your ip address)
Then, as you can see, there is a lot of choices there.
So, you have to choose the configuration to change your old ip address.
I hope it can help you..
Thanks
May 13, 2009 | Epson EPL N2050 Laser Printer
Netgear WGR614 v6 I would like to host Nascar races & need to open TCP Port 8590 to allow this to happen . Can anyone help me ? Thanks Lenny
You need about 3 pieces of information to make this work; the machine that's going to serve's IP address, the password to your router, and a machine on the network.
You can let the serving machine obtain an IP address automatically, but if it changes you will have to reset your server IP address all the time. So, for fun, give it an address in your IP range, generally 192.168.1.x. Pick a number like maybe 250. Then, log into your Netgear (192.168.1.1) and use admin and the password to get to the router web page. On the left tab, go to port forwarding, create a new custom service, and put in 8590 and the IP address of the server.
Once you apply it, it will show up in the table and you'll see what port, a name, and the internal IP address 8590 goes to.
Carl
Mar 01, 2009 | NetGear WGR614 Wireless Router
IP Address
To check your IP you need to Go To Start Rum and type cmd and enter
You will find a DOS screen poped up . you need to type Ipconfig . It list you your IP. You need to have a local admin to change your IP
Dec 20, 2008 | Computers & Internet
Printing to a Xerox DC12/DCS50
you can't print via serial to it. You will have to check the settings in your rip to see what the ip address is. Lights will blink all the time to indicate it is on a network, its just not talking to it. Then you go into your add printers section click the + sign and it should come up in there if the ip address is in line with your mac ip
Dec 16, 2008 | Xerox DocuColor 12 Printer
Konica Minolta Bizhub c252 network problem
firqst: DHCP disabled
copier IP adress should be 192.168.x.y
IP Pc must be 192.168.x .z (169.254.xx.xxx is a bad address!! = No-IP address !!)
see my recommendation for the scan on a previous post (http://www.fixya.com/support/t1395654-konica_c252_scanning_address_book_job)
Oct 09, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
387 people viewed this question
jasbo
jasbo
