Question about Car Audio & Video
I don"t know how to
  • Car Audio & ... Master
  • 4,876 Answers
Select your solution from this free list
CLICK HERE
Posted on Apr 09, 2011
Upper wash arms of dishwasher don't get water
I know this will sound funny but, you will have to trust me on this one. Try running some orange tang juice crystals through it. Your machine will sparkle after words. Hope this helps!
May 09, 2013 | Frigidaire Dishwashers
My shredder jammed so I took the top off of unit in order to clean. When I pulled the top back it pulled all of the wires loose. Being inexperienced I should have made a "diagram" of where the...
I'm afraid i cannot help you to tell you where each specific wire goes first because the wire colors mean nothing without sources and destinations but i can tell you this:Each wire has an elastic memory so that the shape it had before you opened it should remain the same. This means that you can deduce where each wire goes. Also you should have an electrician do the connections as there could be some voltage/amperage issues.
Jan 01, 2012 | Office Equipment & Supplies
Turning on unit, display of "cannot start the correct hard disk was not found" I tried reseting it by holding the pwr button for ten seconds, didn't work. What can I do?
The only thing I can think of is if you know anyone else who has a ps3, try using your hard drive in their ps3 to see if it works, if not you may have to buy a new hard drive. I don't have a ps3 so I am not sure if the hard drives are removable or not, but I do have an Xbox 360, and the hard drives are removable, and are very easy to remove.
Sep 18, 2011 | Sony Playstation 3 (PS3) Console
Where exactly is the waste toner located?? I don't know where to find the "drum unit"
This indicates that the drum unit is full.You need to remove the developer unit from the front of the machine and the drum unit can then be removed,You will need to replace the drum unit.Non genuine toner can result in the drum unit filling up faster than normal.
Aug 10, 2011 | Kyocera FS-1118MFP Laser Printer
Hi, I hope both of my problems are related. The chisel is "stuck" and won't release. Also, the unit does not "hammer". The motor runs and when I select drill the unit spins. I...
you need to get that chisel out. If it was hammering with it before the end of the chisel might have broken and not coming into contact with the striker, if it did not then the end of the chisel might be damaged not allowing it to seat fully, either way get the chisel out and put in a regular bit and it will probably work.
Aug 01, 2011 | Bosch 11247 1916" Spline Combination...
"Check Filter" light is on.
If you look thru the front panel just behind it you will see a spong filter. you will need to access it either by removing the front cover or removing the whole front of the unit . wash it in warm soapy water and replace it . let me know
Jul 21, 2011 | Frigidaire FAA065M7A Air Conditioner
Vhs tape is stuck and message reads "tape
Unplug the TV/VCR/DVD Combo from the main power for a couple of minutes, the unit may eject the tape at the power ON.
You can also try openening the unit, reset the loading posts and eject the tape by manually turning gears, motors etc..You have to know what you're doing otherwise, you will do more damage or get injured and don't forget HIGH VOLTAGE CAN KILL.
Best of lock
www.aaatvservice.com
Jul 15, 2011 | Polaroid TBX-2000AF 20 in. TV/VCR/DVD...
The unit is showing "full
Two things generally cause this problem. If your unit has a Float Valve inside the bucket, it's stuck in the 'Up' position, which under normal conditions, indicates to the unit, that the bucket is FULL. If you don't have that, then when the bucket was last inserted into the bucket holder, it did not trip the bucket removal safety switch. Remove the bucket and reinstall it, making sure that it fits squarely into the hole from top to bottom. Leave the unit ON when you do this, because if you do it correctly, the unit will automatically start and run. Also, be sure that humidity extraction level is set on 32 - 35 %.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 13, 2011 | Comfort-Aire BHD-651 Dehumidifier
It runs but " OPERATION
When you turn on the unit by pressing the power button on the unit instead of the remote. the operation light will stay on because it is being operated without the remote control. there is nothing wrong with the unit. if you have the manual you can confirm on page E-25. best of luck.
May 29, 2011 | Sharp CV10NH Air Conditioner
Car Audio & Video Logo
13 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
