Question about Cameras
I have the Canon PowerShot SD600 and took pictures and filmed movies on my camera. The pictures and small movies downloaded but the larger ones won't download. Suggestions?
  • Anonymous Sep 02, 2008
    I am having the same problem with my Powershot A560. I have transferred
    several smaller movies to my computer in the past, but I have a large
    one (230MB) that results in the camera disconnecting and giving an I/O
    error, even though I have used a couple different types of software to
    try to download this.
I am having the same problem with my Powershot A560. I have transferred several smaller movies to my computer in the past, but I have a large one (230MB) that results in the camera disconnecting and giving an I/O error, even though I have used a couple different types of software to try to download this.
Posted on Sep 02, 2008
SOURCE:
My SD600 states memory card full when I use the original SD 16M card. There are 6 pictures on it and will not take more. What settings should I use to correct that issue?
The original card that came with your camera was very low capacity. As you've discovered, it can only hold a few pictures, and was only included with the camera to show that the camera works. You really should purchase a new SD memory card. These are very inexpensive (here's some from Amazon) and will literally hold hundreds of pictures. BUT make sure that you purchase a 2GB or small SD card, and NOT a 4GB or larger SDHC card. Newer SDHC cards were designed after your camera, and although they look exactly the same, they will not work with your camera.
Jul 17, 2011 | Canon PowerShot SD600 Digital Camera
I have a new sd600 canon powershot.It doesn't have the software.Do i need software to upload pics in my pc with windows xp? I tried without the software but i didn't get any connection.
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Jul 09, 2011 | Canon PowerShot SD600 Digital Camera
I need to download pictures from Canon SD600 and lost printer cd
Connect the Camera to PC using the supplied USB cable, for windows XP and later versions the pc will identify the camera device and pop-up a window asking for "what to do next?"
Select copy pictures from camera from the displayed list.
Dec 17, 2008 | Canon PowerShot SD600 Digital Camera
Switching to movie mode automatically even when on camera setting
ok. I took off the 6 small screws holding it together, inspected it to see if it was anything obvious and easy and but no. I seen the small switch inside and figured it was at fault and needed to be replaced. (yeah right! like that could be done) then put it back together and so far the problem is gone. now i just have to wait and see if it stays that way. so far so good.
Dec 02, 2008 | Canon PowerShot SD600 Digital Camera
My canon powershot sd600 is not downloading to my iphotos
iPhoto deals with still photographs. For videos, try using iMovie or some other video management program.
Sep 22, 2008 | Canon PowerShot SD600 Digital Camera
Sd600
press the function button and change the picture size to postcard-there is only one setting that allows you to do date and time stamp-once you have rigth pic size setting-pretty sure it says postcard-go back to menu and you will see date and time highlighted on menu
Sep 06, 2008 | Canon PowerShot SD600 Digital Camera
Stuck in movie mode, but won't record
internal microswitch connector has been damaged.so it has been stuck at movie mode ,it can be replaced.
Mar 06, 2008 | Canon PowerShot SD600 Digital Camera
Unable to download pictures from canon powershot SD600
Could you see your pictures on camera's screen? Did you changed your computer's operation system? Try to see your pictures on your computer while using a card reader. Let me know if you will need for any further assistance. Good luck!
Sep 13, 2007 | Canon PowerShot SD600 Digital Camera
Cameras Logo
87 people viewed this question
Top Cameras Experts
Ekse
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
