Question about Biostar T5 XE CFX-SLI LGA 1156 Intel P55 ATX Intel Motherboard (TP55)
Computer works great for about 3 days. Then freezes. After I do a hard shutdown it freezes just after the bios logo. The only way to get it back on is to pull the bios battery. Sometime it doesn't show the hdd in the bios. He'd is good. Had it checked and both beds do the same for about 3 days
    President:
  • 1,623 Answers
It could be a number of things, i would try pulling ram chips and using one at a time to see if it crashes, or any pci cards you have installed, pull them out and do the same, see if it crashes, i would also check to see if you have the latest bios installed
Posted on Apr 09, 2011
Hello, when i start my computer it freezes at the acer logo screen that says press f2 for setup when i press f2 it says please wait and freezes when i take out the hard drive it enters Bios. any ideas?
The hard disk could be faulty or the Windows operating system is corrupted and in this case Windows need to be reinstalled on the hard disk.
When the hard disk is in the computer and when you go into the BIOS and if the BIOS cannot detect the hard disk then most likely the hard disk is faulty.
Aug 29, 2011 | Acer Computers & Internet
Hi. i have a dell optiplex gx620 with boot broblem, the computer just stop when start it , the dell logo appear and freez, the indicator reach 30%. even i can not enter to the bios (f2) or do any thing, i...
Freezing during the Power On Self Test (POST) is typically due to hardware problems. You can narrow down the culprit by disconnecting devices one by one until it boots clean. Start with the CDROM, then the floppy, then any cards.
Apr 30, 2011 | Dell OptiPlex GX620 PC Desktop
Pc freezes, says no operating system installed, keyboard freezes in bios,says no hard drives intalled...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps
Mar 23, 2011 | Evga P55 Classified 200 (160LFE659KR)...
White screen with black vertical hypen lines???
Hi, you should get an update for your graphics driver and the Bios update. After the updates for the driver. Do a hard reset. To do a hard reset. We need to shutdown the notebook. Remove the battery. Remove the power cord. Press and hold the power button for 30 seconds. Do not expect the turn on. That would be weird. Actually we are trying to reset something internally. After this. Test if the issue goes away. Hope this helps!
Mar 04, 2010 | Compaq Presario M2000 Notebook
I have hp dv9700, after improper shutdown kept rebooting
What happened is that you interrupted the disk write on 'saving settings'. Very BAD. You may be able to start in safe mode, by pressing F8 while windows is starting, then selecting options to attempt to repair. The alternative, is to boot from the windows CD and select 'repair'.
Feb 09, 2010 | HP Pavilion dv9500 dv9600 and dv9700 FF...
Windows xp home will freeze on the compaq logo when hd 640gb
leave the drive disconnected until you have booted up.
You could change the BIOS to tell it not to look for external boot devices to overcome this also.
All it is, is that the computer can see files on the drive that it thinks may be an operating system and it is trying to boot from that drive until it fails and then loads windows normally.
Sep 07, 2009 | Western Digital My Book Essential Edition...
I have an acer aspire one aoa150 that starts to boot and shuts down afer about 10 seconds
Sounds like a corrput hard drive or motherboard. Get it checked out or replace both and it will fix it. Its a expensive solution.
Jul 06, 2009 | Acer Aspire One PC Notebook
Bios screen freezes at startup
go to bios/set up and check in advanced set up and select the first boot device as HDD 0 or HDD 1 (hard disk 0 or 1) and also you need to see that the hard disk is seen in the bios, save and qite. if it is the same reinstall the operating system
May 23, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Dfi infinity freeze at logo screen
there is a jumper on the motherboard for that perpose, should reset on it 3 jumper it is alway on pins 1-2 move it to 2-3 for a few secound and than move it back and reboot system
rod
Feb 04, 2009 | DFI INFINITY NF4X Motherboard
HDD Has been stop be detected in my computer,PLZ HELP!!!Somebody!
try plugging the hard drive into the other ide port on the motherboard
Oct 27, 2008 | Seagate Internal Hard Drives: ST3160021A...
Biostar T5 XE CFX-SLI LGA 1156 Intel P55 ATX Intel Motherboard (TP55) Logo
73 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Martin Murray
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
