Question about Kodak EASYSHARE V1253 Digital Camera
My on/off button no longer works. I can turn on using any other button, but to turn off I have to pop the battery out. It's fully charged and all other features work. Is there anything I can do to fix this?
Just give it to a service shop they can do it with a very low cost.
Or shke the camera very hardly then try pressing (shaking and pressing together)
Posted on Apr 09, 2011
Should my jvc videomovie gr-ax7 work on a half charged battery or do the battery's have to be charged up to there maximum?
I have always understood that it is 'best practice' to fully charge the batteries for electronic equipment. If they are continually only half charged, they can develop a 'memory' and no longer take a full charge.
The other criterion, of course, is that a fully-charged battery will last longer in use, and not let you down at a crucial point when filming.
May 19, 2016 | JVC Video Cameras
St-99 bluetooth headphones wont turn on after charging
The headphones may have been delivered with defective batteries that are unable to charge after initial use. Also, the charger could be defective.
Jan 20, 2014 | Audio Players & Recorders
Nikon s9300 - When I turn it on, the lense fully extends, but the screen stays black. I have to pop the battery out, then put back in for the lense to retract. Battery is fully charged and even tried
When the battery is fully charged, please put it in again. That means, if it is still in, remove it once again.
Switch it on, and even if you don't see a thing try to make a picture.
Then press the display button several times, to see if anything comes on the screen again.
If the camera does not respond after that, you should go back to the dealer, of contact Nikon.
Dec 21, 2013 | Nikon COOLPIX Cameras
How do you charge your wii console
The Nintendo Wii is an innovative video game system and much like other video game systems within the Wii's generation, the controllers are all wireless. Because of the wireless technology, the controls must function on batteries in order to operate. Instead of having the game pause in the middle of the action, there are plenty of methods you can test to make sure your Wii remotes are fully charged.
instructions:
  • Charge you're the batteries to your Wii remote by opening the back clip and pulling out both AA batteries. If the batteries are the standard set that came with the Wii, you should upgrade them to rechargeable batteries to save time, money, and garbage waste.
  • 2
    Let the batteries charge for as long as the charger says. In most cases a full charge could take 6 to 12 hours, but fast chargers can fully charge batteries for an hour. Check the charger's manual detailed times.
  • 3
    Use a Wii Charging station for easier charging access. These stations avoid the process of opening and closing the Wii remote every time you need to charge the batteries and they work as a Wii remote stand as well.
  • 4
    Place the batteries back into the Wii remote once the charging has completed. With both the charging stations and rechargeable batteries, lights should indicate when the charging has completed.
  • 5
    Power up the Wii and press any button on the Wii Remote in order to turn it on and connect with the Wii.
  • 6
    Press the "Home" button the Wii Remote control. This button is in the center of the controller and features a small picture of a house on it. A pop-up menu will appear over the screen.
  • 7
    Look at the menu and find your controller number. Right next to the assigned number is a remote battery meter. It will feature 1 through 3 bars to indicate battery level. If it has 3 bars, then the Wii remote is fully charged and ready for use. If it has any less bars then the remote can be used, but is not fully charged. If the battery meter is in red, the remote will shut off soon because there is not enough battery power.
  • Dec 06, 2011 | Nintendo Wii Console
    My headset will not turn on
    Hello
    Your bluetooth headset is powered by an internal battery. If the battery is not charged,it just won't turn on. Fully charge your battery before use.
    Make sure that the power outlet you're using is working and that the cord is fitted correctly into the wall, PC or Car outlet and the Jabra Bluetooth device.
    Try unplugging the Jabra Bluetooth device and see if it turns on. If so, use the Jabra Bluetooth device until the battery is completely exhausted. The next time you charge it, check that it is charging properly
    If the Jabra Bluetooth device is still not charging, check what happens when you initially plug the Bluetooth device into its charger. If the light on the Bluetooth device flashes on and then off again quickly, it is likely that the battery is no longer working. Batteries cannot be replaced or covered warranty
    Dec 30, 2010 | Jabra BT150 Wireless Headset
    Does my phone have to fully charge before i can use it again?
    No, try and remove the battery again. wait a few minutes.
    Now replace the battery, plug the phone in, now press and hold the call button which is the on button for 10 seconds and see if it powers up.
    Any more questions just ask.
    Feb 07, 2010 | Motorola Mobility RAZR V3
    All of a sudden it will not turn on....nothing...when plugged into the usb...it say fully charged....but if you disconnect..and try to turn it on.....nothing happens..
    If you can turn your player on while being plugged to your PC/Laptop or USB charger, then your internal Lion battery is most likely gone past its useful life (some 500 charges or 18 months usage) and may need replacing. Most MP3 player may show 'fully charged' when plugged in either when the battery is truly fully charge or defective battery is no longer taking a charge: e.g. minimum or no current flow situation.
    Dec 20, 2009 | RCA M4204 MP3 Player
    Creative ZEN (4GB) not turning on (battery fully charged)
    I had the same problem but it powered up after I removed the cover and wiggled the battery.
    I hope this helps.
    Martin
    May 28, 2009 | Creative Labs Nomad Jukebox Zen Xtra MP3...
    My unit just shuts off and will not turn on again until I plug it in as if to recharge the battery. I checked the battery when I first turned it on and it said the battery was fully charged.
    Hi there!
    It probably does need a battery replacement.
    Even though it may show fully charged, and even test as fully charged, it may no longer have the capacity to deliver it for any sustained period.
    If you think of a comparison between a 12V car battery, and a 12V alarm battery. Both show full charge, and the same output voltage, the difference is the available plate area. This is reduced due to degredation, and will no longer provide the same output.
    Hope this helps.
    If you want to make the battery last longer, charge for the recommended time (as was the first charge), then run the battery right down before charging.
    If this solves the issue, Please rate as Fixya! thanks.
    Jun 20, 2008 | Magellan GPS
    My samsung blackjack 2 will not charge. the battery is now totally dead, will not turn on and will not charge even with the wall outlet charger or the computer usb charger. when the phone still had some...
    If the Red Led stays turned on it is as simple as this.....the solder connecting your power on button to the system board in your phone has worn off..... you must pop the power button at the top of your phone off and you will be able to see where the soldering paste has simply worn off. At my job I have a soldering machine so it was not problem for me. I simply took pasted it back to the board with tin.....now this may require some work. just pop off the top section of you phone with a flathead screw driver and pop out the power button. look closely and you should be able to see where the botton has lifted from the little greenish system board..... Find someone to solder it, put it back together and it works like new.........SEE YA
    Jun 09, 2008 | Samsung BlackJack II Smartphone
    Kodak EASYSHARE V1253 Digital Camera Logo
    Top Kodak Cameras Experts
    Jerry Greenberg
    Jerry Greenberg
    Computer Links
    Are you a Kodak Camera Expert? Answer questions, earn points and help others
