Question about ViewSonic Computers & Internet
The 19 inch model no vs11369 (vg930m)moniter is showing no signal on screen .please help detect the problem
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 332 Answers
Usually when you get that message it can be one of two things.
1st Check the cable that hooks to the monitor side. Then check it at the computer side. By check I mean to disconnect it an rehook it up again so you no it is seated correctly. On some monitors its hard wired so you cant check the monitor side.
2nd if you have access to a second monitor (after checking the cables on your monitor first). Disconnect your current monitor and hook up the test monitor. If you continue to get the no signal message then you have a defective video (graphics) card and you will need to replace it.
I hope this helps you out, if it does please give me a YES that I did assist you. Thank you.
Posted on Apr 09, 2011
The moniter blacked out, blue light is saying the moniter is still on, but screen looks like there is no power. When you turn on the moniter, the screen shows up for a few seconds, then blacks out again!...
Unplug power. Unplug VGA cable. Remove back of monitor. (four small Philips headed screws along the bottom rear. Remove screws attaching Monitor to it's base. Carefully, lean the screen away from back of case. Gently unplug 25 pin cable from the screen.
Connect AC power.
Screen should power on Gray to White. Ble light comes on Blue.Flickers then changes to Amber.
Reconnect VGA cable. Monitor should work.
Close up the monitor in reverse order to opening it.
If these steps don't solve your monitor, consider replacing as cost of repairs may shock you.
Sep 09, 2010 | Proview PL926WBi 19" LCD Monitor
19 inch Dell Moniter Screen turns blank
i think may be its monitor problem or may be the wire problem that are attached with ur CPU...... change it and then see its again wrking??????
Mar 23, 2009 | Hitachi CM721F 19 in.CRT Conventional...
Screen black
Take the post (power on self test) disconnect vga cable and connect power cable if monitor shows no signal check signal cable massage then monitor is ok fault is in cpu. open it and clean the dust
by vaccum cleaner you will get the display again
Oct 17, 2008 | X2Gen MG19MY 19" LCD Monitor
I NEED HELP PLEASE!!!!!!! PROVIEW 19" MONITER.
Does the led on front of the monitor stay blue or does it become amber ?
If it becomes amber, then you are not getting a signal.
No harm in trying this : You can try to see if it is a contact problem.
With the monitor unplugged.
Use a small paper clip to run in and out of the blue vga plug holes a few times each to make sure they are not plugged or gummed up.
If that doesn't help and you know that your video cord is good, then I am afraid to say that more than likely there is a problem with yor video card.
If it stays blue then the signal is there but the screen isn't fully lighting up, leading to a failing power-inverter board or a bad bulb.
powerseller
bammbammfran
Oct 12, 2008 | Proview PL926WBi 19" LCD Monitor
VG930M-3 Taking base of this monitor...
After a chat with a Viewsonic tech and pulling out a lot of screws, this is what I discovered you have to do;
Find a secure place to turn your VG930M upside down, like on an armchair.
Undo the central screw on the base and remove the rotating black plastic plate.  Make sure you know which way it goes back on again.
Remove all the screws on the metal plate, something like eight around the circumference and another two which attach to the LCD support column. (You were never just going to pull that base off!).
Now for the tricky bit! The support column has two extensions that extend down into the base and click into position.  You have to get a flat blade screwdriver and push one of them towards the centre while trying to lift the base just a little away from the support column, so that it is unclipped.
Then you have to do the same with the other extension, while lifting the base a little. The base should now pop off.
Not as straight forward as some screens but achievable!
Good Luck!
Aug 25, 2008 | ViewSonic VP920b 19" LCD Monitor
Dell Flat Screen 19"
it sound like you eather need a new video card or there is something wrong with your moniter.
thanks
hope this help you
Aug 18, 2008 | Dell Dimension 4600 PC Desktop
PICTURE TUBE
32 inch Albatran Monivision Moniter, when plugging the VGA in the tower thers no picture. the moniter comes on saying " No Signal No AV Box Action
Dec 16, 2007 | Albatron Monivision 29" Picture Tube...
Pl916s proview 19 inch flat screen moniter
Hi, I, too, was given one of these monitors. Using a flashlight shine it at an angle to the screen and see if you see a computer screen showing under the beam of the flashlight. If you see a picture then the backlight or its circuit is not working. Check to see that the 4 cables going to the LCD display are plugged in all of the way. There are plugs on each of the cables with 2 wires to each plug.
Aug 22, 2006 | Proview PL913S 19" Flat Panel LCD Monitor
Computers & Internet Logo
174 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
