Question about AOC Monitor
Hi, I have my macbook connected to aoc wide screen (23"?) monitor the display on my monitor is letterboxed even though I have clicked mirror monitors. the resolution of my mac screen is 1280 x 800 please help me get the correct picture on my aoc monitor
  • 1 more comment
  • claremorton Apr 09, 2011
    hi, what should I set the monitor's resolution to?
    no this isn't possible -
    my mac is set up as 1280 x 800 but the only resolution options my monitor is giving me are
    1280 x 1024
    or 1280 x 960
    both of which result in a distorted or blurred image.
    Is there a way that I can over ride these settings so that the image on the monitor is clear and undistorted? I don't mind having black space down the sides of the screen is that mean the macbook screen is replicated. at the moment, I have black bars top and bottom
    thank you
    hi, thanks,
    can you recommend which monitor I should try? I am assuming a mac monitor would work perfectly although much more expensive!
  • 384 Answers
Hi There and Welcome to Fixya.
Connecting a monitor to your MBP gives you more space to work on. You may want to check on the following and see if it was done properly :
  • Ensure physical connection - either mini DVI or mini DVI-VGA will work
  • Turn on the mirror mode by pressing "F7" or "Fn+F7"
  • Adjust the resolution of the monitor through the system preferences or the "Display status" in the menu bar
  • Put the macbook into "Sleep mode" to obtain the full (optimum) resolution on the AOC monitor
  • Keep the lid of the laptop open to access kybd and track pad
  • To boot the computer using the AOC monitor, turn on the computer and close the lid of the laptop at once.
Please let me know if this wont work.
Thank you for using Fixya.
Posted on Apr 09, 2011
  • 1 more comment
  • Arvin Antonio Mercado
    Arvin Antonio Mercado Apr 09, 2011
    Hi There and Thanks for responding,
    You can go ahead and try the 1280 x 800 resolution.
    Please do get back to me.
    Thanks again.
    I assume that you already tried any of the font smoothing options under appearance in system preferences. Anyways, this issue has been rolling out for quite a long time with Mac OSX and external display, either in VGA or DVI mode. To give you a straight answer, there are no options to override the ext display resolution. OSx 'makes' the external display fit it's resolution of 1280x800 - hence, the blurred fonts/texts/images. For more information, here is a discussion surrounding the same :
    http://forums.whirlpool.net.au/archive/9...
    My best recommendation is to try out a different monitor with different resolution aspects.
    Thanks.
    Apple LCD/LED monitors are highly recommended, though you can consider those "non-glossy" DELL LCD monitors as well - I would prefer if you can bring the macbook with you to ultimately try those potential LCD's while in the store.
    Thank you.
How can i change AOC monitor to wide screen, menu bar does not highlight. I have three monitors and the one on display port is wide screen by itself.
go into the computer , control panel find the appearance and personalization section ans change the aspect ration of the screen there. don't forget to apply and save(ok) before leaving
Feb 13, 2015 | AOC Computers & Internet
Screen+ application that came with my AOC monitor isnt working when I try to change the configuration to multiple on display 1 or display 2. What happens is "AOC grid screen executable file has...
This sounds like a computer problem and not really a television problem. Check your driver files.
Try removing your driver files. Then disconnect your AOC monitor. Reboot the computer and login. Shut down the computer and reconnect the AOC monitor. Start the computer. Now install the monitor drivers.
Jun 27, 2011 | AOC 23 E2343fk 23 LCD TV
I have a 24" aoc 2436Vh display and a new 15"
I purchased the AOC 2436Vh display yesterday. To get my MacBook Pro to work with it I purchased Apple's Mini DisplayPort to VGA Adapter. Since the monitor comes with the VGA cable, all you need is the adapter to plug it into your MacBook Pro. It works beautifully and set up is easy if you know your way around the Mac. Although the HDMI works perfectly with my PS3, I strongly recommend the Apple Mini DisplayPort to VGA adapter. I hope this helps.
Nov 11, 2010 | Computers & Internet
My aoc tv / monitor will not connect properly to my macbook as a monitot. ive tried vga and hdmi. i don't know if there is something i need to do on the computot to have it recognize the display or if the...
is your tv function will? there's menu tab to switch from tv to monitor is that visible on the screen, need that feedback or else will trouble shoot monitor area.
Mar 02, 2010 | AOC CRT Monitor
AOC 16" monitor is wide screen and stretches the display - how to fix?
Some where on you screen is a menu button that allows you to access teh screens utilities. One of teh utilities is the screen's geometry. Iti is here that you can adjust the length, width, position, etc.
You may want to access the vendors web site and sownload the user manual.
Oct 06, 2009 | AOC LM729 17" LCD Monitor
AOC 1" - Monitor Says "no signal"
Sounds like a connection problem. Make sure BOTH plugs are securely located. Ian.
Sep 20, 2009 | AOC LM729 17" LCD Monitor
Help me fix to the set up of my monitir AOC 7f 17''
Good morning! kindly try the following:
-mouse pointer on the screen, right click the mouse, then click the Properties, then click Settings tab, then click Troubleshoot or Advance which will guide you in setting your screen display. best regards.
May 04, 2009 | MPC Computers AOC 7F 17" CRT Monitor
Screen resolution.
Hello there!
It's fortunately quite easy to adjust the resolution your MacBook Pro sends over to your external display.  Try this:
  1. Click the blue Apple icon, at the top-left of your display (while connected to your 23" external monitor).
  2. Click on "System Preferences".
  3. Click on "Displays" in the "Hardware" row.
  4. A display preferences window should now open on each display... one on your laptop, and one on the 23".
  5. In the "Display" tab of this preference window, specifically the one located on your 23" display, should be a list of resolutions available.  Scroll down and select the highest resolution, which for a 23" should be 1920x1200.
This should adjust your resolution to the maximum.  To make these settings easier to get to in the future, check the box in the display preferences labeled "Show displays in menu bar".  You'll see a small icon, meant to look like a display, appear in your menu bar.  Going forward, you can click on this to set/change resolution settings without going through all the above steps.
Hope this helps!
Oct 10, 2006 | Apple Cinema Display 23" HD Monitor
Computers & Internet Logo
125 people viewed this question
Top AOC Computers & Internet Experts
Raj Patel
Mohammed Ebrahim M
Mohammed Ebrahim M
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
