Question about Kenmore Washing Machines
Washer wont spin or empty I think the switch is broken how do i get the top off?
  • Kenmore Master
  • 8,220 Answers
Flip up the controls, pop the S clips, unplug the lid switch connect. Tip the case toward yo and lift it out the way,
washer wont spin or empty - themobilian_2187.jpgthemobilian_2188.jpgthemobilian_2189.jpgthemobilian_51.gif
Jump the 2 hot wires to check switchwasher wont spin or empty - themobilian_2191.jpgfor leaks and noises while the case is off.
themobilian_2191.jpgthemobilian_2192.jpgVideos and more HERE
Posted on Apr 09, 2011
Washers empties water but wont ring out clothes
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design. Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Transmission or clutch assembly not engaging due to going out or slipping.
Sep 28, 2014 | Maytag Neptune Washing Machines
Machine only puts out water.wont spin.
This is a typical problem. If the machine fills up and stops and makes absolutely no noise whatsoever, what you have here is a broken lid switch. The machine simply thinks the lid is open, and therefore does nothing. For your washer, you need a lid switch with a part number of 3949247. Naturally after cracking a machine open you may find uncommon things such as broken and/or burnt wires, but these are unpredictable and highly unlikely.
May 28, 2010 | Whirlpool LSB6200KQ Top Load Washer
Washer will fill with water, but will not spin or empty water
What you have there is a broken lid switch I would be willing to bet. I have 2 videos here one shows how to access the lid switch and the other shows how to replace it.
Apr 19, 2010 | Whirlpool LSR5132PQ Top Load Washer
Matag top load washer wont spin or empty
Set the timer for manually for the spin cycle and trun it on.
If it does not spin replace the lid switch.
Mar 14, 2009 | Maytag Washing Machines
Washer won't spin and drain
Sounds like your drain poump is failing. It's spinning lighter loads but not able to take a full load. I woule definately replace the drain pump,
Feb 28, 2009 | Frigidaire Washing Machines
I OVERLOADED THE WASHER AND NOW IT WILL NOT DRAIN OR SPIN
your washer doesnt have a belt, it is a direct drive with a coupling on the motor, so that is not likely your problem.
i would look to see if the lid switch is broken, when the switch wont work it wont spin or drain. if the coupling is broken it wont agitate or spin, but will drain the water.
just look under the top and see if the switch is just hanging loose. it has 2 screws holding it to the cabinet and a wiring harness that goes to the control panel.
Jan 08, 2009 | Roper RAS8445KQ Top Load Washer
Kitchenaid top load washer wont agitate or spin
you have a direct drive washer with a coupling broke.Here is a good article on it http://repair2000.com/coupling.html
Dec 11, 2008 | KitchenAid KAWS700L Top Load Washer
Kirkland Signature by Whirlpool Washer
There could be 2 possible issues, one, the simplest is the switch activated by the lid, look for a plastic "prong" sticking out from the lid, see where it goes and find a switch, use sometime of similar size and see if you can activate it. If that is eliminated then it is a plastic coupling broken, quite involve, need to remove the back lower section and inspect for this, Had both these issues myself.
Apr 01, 2008 | Washing Machines
Washer troobleshooting
will not empty??? TOP loading washer???? sounds like a bad lid switch, agitates but doenst advance to rinse, remains full of water?? if so lift the lid up and downa few times hear a "clicking" noise??machine doesnt think lid is closed so for safety reasnos wont spin/drain replace the door latch
Mar 12, 2008 | Washing Machines
Washing Machines Logo
24 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
