Question about GE (PSS26MSRSS) Side by Side Refrigerator
How do i remove the drain pan to clean and where is it located?
  • 4,070 Answers
It's much easier to clean in place since they are not usually designed to be removed. It's underneath the freezer/fridge and is accessed at the back behind the cardboard cover.
Posted on Apr 09, 2011
How do I check/add trans. fluid?
on these models, it is not necessary to check the fluid at regular intervals. (with no dip stick ). unless there is a leak or shifting problem. Here is how you would go to change the fluid! heres how to check it! Raise and support the car with jack stands, put drain pan in place under tranny, remove the front and side transaxle pan bolts. loosen the rear pan bolts one turn. carefully pry pan loose with a screwdriver, to drain the fluid. When drained, remove remaining bolts on pan. use a new gasket on pan if needed to put back on.(( FLUID LEVEL CHECK: vehicle has to be level! start vehicle let run for 3-5 minutes, shift through all the gears, locate fill plug on top of transaxle. it is on the drivers side ( look and you shall find it.) the check plug is located near the pan. adjacent to the drain plug. remove the plug, when fluid drips out of drain hole. fluid level is ok. the fluid level should be at the bottom of the drain plug. The reason I know, is because my 2000 Malibu was the same! When replacing the pan put in bolts . working around pan tighten each bolt a little at a time. until the final torque is reached. God -_Bless! if pan was removed.
Apr 21, 2015 | 2004 Pontiac Grand Am
How do you empty the drip pan located under freezer side of side by side
Older side by sides had a removal drain pan behind the grill located under the doors in front. Remove grill and just pull out the pan carefully to empty. But the newer refrigerators have the drain pan built into part of the compressor mount and are not removable. You can't empty or clean them without removing the back cover at the bottom back of the cabinet. You would need a sponge or towel to dry up the water.
Mar 21, 2015 | Refrigerators
I have a Samsung model RF4287HA French door refrigerator. Has anyone had success cleaning the drip pan located at the bottom rear of the refrigerator? I know that this pan can't be removed, but I can'
Hello Derek;
My name is Peter. I am a retired field service refrigeration technician.
In answer to your question, the drain pan is removable. This drain pan is available for purchase. The problem is both Samsung and LG are not service friendly. The drain pan is not secured with fasteners and just lifts up.
However, There is the interference from the seal system (refrigerant) tubing and compressor which prevents you from pulling the drain pan out.
On my service calls with drain pan leakage, I just repaired the drain pan with duct tape an silicone adhesive. Because I could not get the drain pan out with out moving the compressor.
Both, Samsung and LG are the worst service friendly and highest cost for repair.
Jan 19, 2015 | Samsung RF4287HA 28 cu. ft. French Door...
Change oil pan
drain oil by removing the drain bolt from the oil pan. then remove oil pan bolts around edges of pan located under car at bottom of motor. my hav to remove a brace or two if the pan will not come out freely. clean all surfaces no oil or gasket material, add rtv silicone sealant and reinstall pan
Oct 20, 2012 | 2002 Chevrolet Cavalier Coupe
Water leaking on floor
The drain pan should be removed and cleaned at least once a year. The drain pan is located at the bottom of the refrigerator behind the front grill. Remove the grill, which snaps into place. Grasp the drain pan while pulling slightly upward and forward.
Clean the pan with warm soapy water or warm water and baking soda.
If the pan rattles when it is replaced, it is too close to the compressor. Simply reposition the tray.
If you have an ice-maker, check the water supply hose going into and coming out of the water inlet valve. The hoses may be loose here.
Jan 21, 2010 | GE Refrigerators
Leaking water outside of fridge every couple of days
Hi. The drain pan should be removed and cleaned at least once a year. The drain pan is located at the bottom of the refrigerator behind the front grill. Remove the grill, which snaps into place. Grasp the drain pan while pulling slightly upward and forward.
Jan 19, 2010 | Amana Refrigerators
My refrigerator is leaving a puddle on the floor
If you have an ice-maker/dispenser, check the water supply hose going into and coming out of the water inlet valve. The hoses may be loose here, in return, causing the puddle you have discovered.
Nov 21, 2009 | GE Refrigerators
Water on floor
Nov 14, 2009 | Frigidaire FRT18G5A Top Freezer...
REFRIDGERATOR LEAKING WATER ON THE FLOOR
HI. This may be a drain pan issue.
Jun 30, 2009 | Maytag MSD2454G Side by Side Refrigerator
How to remove drain pan from compressor
the drain pan removal requires a sealed system repair to modify the type and new location of the replacement drain pan. this should get repaired by a certified refrigeration service technician.
Sep 18, 2017 | Kenmore Freezers
GE (PSS26MSRSS) Side by Side Refrigerator Logo
137 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
