Question about Miele 24 in. G665 Built-in Dishwasher
Miele dishwasher not working
The dial on the right of the turn on dial keeps on turning and not stopping
Your timer is shorted out. probably caused by a cockroch
Posted on Jan 20, 2009
Miele dishwasher G1040 stop starting then all three lights start flashing
Sounds like bad control board. Try calling the guys from the service, I don't think you'll be able to fix this by yourself. Source: PDF Keep
Dec 27, 2015 | Miele Dishwashers
Dishwasher runs and never stops
hi,
Sounds like you would need a new timer which can be purchased from Miele directly or through a authorzised service agent
Jun 30, 2010 | Miele 24 in. G870 Built-in Dishwasher
Our Miele DW just keeps going through cycles constantly and will not shut off on its own. It has gone all day. When we turned the dial manually to "OFF", the water keeps filling until it overflows the...
hi,
sounds like a faulty electronic unit as i have seen this before where the unit continously fills with water.
you will probably need a service call to repair the unit unless you are happy to fix it yourselves. have a chat with Miele directly as they are very helpful
Hope this helps.
Jun 20, 2010 | Miele 24 in. G865 Built-in Dishwasher
I have a Miele G641 dishwasher and it wont drain and it is coming up with red lights saying inlet/outlet, salt intake
One thing these guys did not point out is to turn the knob to STOP before starting this procedure (otherwise you will be ignored) Once done this works fine.
-- from the manual ----------------
Before rectifying the problem you must:
- Turn the programme selector to the "Stop" position.
- Switch the dishwasher off using the "On/Off" button.
Nov 15, 2009 | Miele 24 in. Novotronic G641 Plus Built-In...
Water inlet
It sounds like there is either a kink in your drain hose or your garbage disposal is blocked up where the dishwasher drain is connected
Sep 06, 2009 | Dishwashers
I have a Miele G841 SC Plus Novotronic Dishwasher. The Intake/Drain light is blinking and it won't work. What do I do?
I had a problem where my G842Plus dishwasher would run through the prewash and then the intake/drain light would start blinking and it wouldn't work. There would be water in the bottom of the dishwasher. After cleaning out various items to no avail, we called Miele technical support and they told us to reset the codes and then keep trying it over and over until it worked.
Here is how we reset the codes:
  • Turn dial to stop/off
  • Turn dial to Normal Plus
  • Press Start
  • Press power
  • Then press the start button for one second and let go
Sep 15, 2008 | Miele 24 in. Novotronic G842 Plus Built-in...
Miele intake/drain flashes, no drain
this can happen after inactivity. the circulation pump seal sticks and wont turn . when the dishwasher starts to fill the circulation pump is pulsed on to see if the preasure switch switches over (to see if water is getting into the dishwasher) if the pump does not turn there is no preasure and the machine stops thinking no water has entered. turn pump by hand to cure.
Jul 18, 2008 | Miele 24 in. Touchtronic Platinum Built-in...
Miele g 646 sc (not plus)
check the inlet where it joins onto the tap as mine has a fine filter and debris from the fresh water builds up. Simply remove the pipe from the tap and **** ,this should remove /dislodge any scale etc that could be causing the inlet light to come on. Make sure you spit out the water that comes back from the machine!
Apr 20, 2008 | Miele 24 in. G646SC Plus Free-Standing...
Miele 24 in. G665 Built-in Dishwasher Logo
183 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
