Question about Maytag Kitchen Ranges
Model number CHG9800BAE Maytag slide in gas range has the 2 burners on the right will not ignite with the iigniter. Left burners are fine. Right side burners will turn the ignite on for the left side only and the gas flow is fine. I have already switched the burners from side to side and the same results apply so the burner elements are functioning fine. What might be my issue and what parts may be required to repair. Thank You
  • 146 Answers
SOURCE: maytag range shows fault code F14
You have a problem with your oven temp. sensor. Remove it and check it at room temp. It should meter out at 1 to 1.1K ohms. If it doesn't replace it.
Posted on Dec 29, 2007
SOURCE: gas range top burners too hot
Get the installation manual for your range, and find the part on adjusting the low heat for the burners. On my Whirlpool, I found there is an adjustment screw inside the control knob shaft of each burner. The manual says turn the burner on low, remove the knob, then turn this screw until the flames are 1/4" high. Super-easy, it took me 5 minutes to do. I am sure all ranges have similar adjustments, might be in different locations - check the manual.
Posted on Feb 19, 2008
SOURCE: Help in Removing Frigidaire Smooth Cooktop Burner
What holds the spring assembly onto the bar assembly is just two small prongs. Use a pliers on the end that protrudes through the bar, squeezing the prongs together, and it should come out fairly easily.
Posted on Mar 02, 2008
aborcass
  • 2651 Answers
SOURCE: Burner no longer functions
two thiongs, you might have a bad switch( under control knob), or before you try that ck the old elemnt that you replaced, on the back of the limiter( the glass rod that goes through elemnt itlself), you'll see little letters 1a,2a,1b,2b.--- new replacemnets depending on age are wired differently, they too will have 1a2a1b2b but in different position. id check that first
Posted on Mar 03, 2008
freetek
  • 5568 Answers
SOURCE: Electric spark for gas range burner is non stop
Turning any knob starts the spark via a switch behind each which should disengage when the (any) knob is turn further.
One of your switches is stuck.
I think you should be able to remove the range-top for access and find the offending switch.
It is probably gummy from a spill and is no longer in solid contact with the cam that operates it.
A solvent/lubricant such as WD-40 sprayed on the plunger of the switch once you can see it and operating the knob back and forth should free it up.
It might be wise to turn off the gas supply while tinkering with the range - blow your house away and the range won't matter. :-(
Posted on Jun 19, 2008
All 4 Igniters keep firing after the burner is lit.
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
ghhdf
May 02, 2010 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Tappan MGF500PBWH right side won't ignite
Helpful when people chime back in once a solution is achieved.
"bad igniter" above was incorrect terminology. "spark module" would be correct.
Problem was the 3 wires on the spark module. They all look the same, but must be seated correctly onto the proper connection. Failure to do so will result in the issue I first described. Seated all 3 correctly and now all burners (and oven) have spark.
Aug 27, 2009 | Tappan MGF500PBW Gas Kitchen Range
No spark to ignite stoves
Igniter will need to be replaced. You can go to repairclinic.com and type in your make and model and you will find it there!
Aug 18, 2009 | Maytag MGS5770 Gas Kitchen Range
REAR RIGHT AND LEFT FRONTBURNER WON'T IGNITE
The most common problem for gas surface burners is that they get gas but don't light. This is generally caused by dirt or grease splatters on the burner itself. Residential-grade range/stove burners are round and have small holes around their perimeter to allow gas to flow out and create a round flame. The gas coming from these holes is often ignited by a small vertical row of holes on the side of the burner. If these vertical holes are clogged or obstructed, the gas can't ignite.
The solution is to clean the burners thoroughly. Use a toothpick to clear the small vertical holes, then allow the burner to dry completely and try lighting it again. If it doesn't light immediately, repeat the procedure
May 12, 2009 | Magic Chef CGR3742 Gas Kitchen Range
36 inch range gas not flowing to both burners
I am having the same problem with my oven. One burner comes lights on just one side. Then the second one comes on. Just one side. After a while both side get lit. My concern is unburnt fuel coming out of the oven. Going to trying taking the burner out and cleaning the ports
Sep 18, 2008 | Viking VDSC365-6B Dual Fuel (Electric and...
Igniters do not spark on one side of cooktop
Is the gas able to flow freely through and out of the bad burners? Sounds like they may be clogged somehow
Jul 11, 2008 | Jenn-Air JDS8850AAS Dual Fuel (Electric...
Ge spectra gas stove top not lighting
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Nov 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Sealed Burner
Ralph, you need to look at the electrodes at the burners. They might be cracked or dirty. It's very hard to tell sometimes when they are cracked. The burner cap itself has to have a good ground and the wires going to the electrode should be on tight. You can eliminate the spark module by switching the right and left side burner wires at the module. Once you do that, if the right side works ok, but now the left doesn't, you can be pretty sure it's the module...Catriver..post back.
Mar 03, 2007 | Maytag MGR4451ADS Stainless Steel Gas...
Kitchen Ranges Logo
53 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
