Question about Honda Gxv160 55hp 55 Hp 25mm Dia Lawn Mower Engine
My Honda GXV 160 is very hard to start. I pulled about 20 or more pulls before its engine will start (until I am tired). Once it started, and warmed up, it will be easy to start next and subsequent pulls. Please help.
Before you spend time and money on Buds solution I had exactly the same symptom .If it starts first pull when the engine is warm it is not a fuel or spark problem ,it will be the choke,on mine when the choke lever was full on it did not opperate the choke enough as the cable goes to choke it turns the metal bit clock wise but the metal choke will bend over time and will not be opening the choke just carefully bend the metal bit with some pliers so when the cable is on choke it now actuly opens the choke,it will now start first time when cold ,try this first before you strip apart the carburetor,I liked buds solution may be you might like mine ! www.distinctivehomeimprovements.co.uk
Posted on Jan 22, 2012
  • Honda Master
  • 7,482 Answers
Sounds like you have a fuel problem...
Check your fuel filter if you have one, normally they will be located in the fuel tank.
If the mower/weedeater is over a year old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Apr 09, 2011
I have a new, first s ason and broken in 20'hp honda outboard. Full choke fine starts first pull. After warm up and leaving at dock for 20 minutes it restarts hard with and without choke
Hi Ira:
Honda's are notoriously reliable, so, since it is a new engine, I'd be heading straight for the shop where I purchased it.
From personal experience, every one of the different pieces of equipment that I own has slightly different starting characteristics.
Once you determine the "routine" for your outboard, it should work the same way, every time.
Jul 15, 2016 | Honda 20 HP Engine - GX630RQXF6
I have a honda pressure with a honda 160 motor.ran great yesterday but today will not stay running and very hard too pull almost pulled my arm off from back pressure.replaced plug checked oil also checked...
did you forget to shut off the fuel before moving your pressure washer? It sounds like the engine is flooded. Honda GX engines are famous for flooding with the fuel valve left on when moving. Or did you store it in a tilted position? Take the spark plug back out and pull the pull rope a few times...you should see the gas that flooded ejected from the plug hole. Once you feel you got all the gas out, replace the plug. You may want to check your oil and make sure it isn't full of gas now also. If it is good, or you have changed your oil then start it up....It should not have the resistance anymore and should start just fine. Good luck
Sep 12, 2017 | Karcher 2500 PSI Pressure Washer
GXV 160 Honda, spark plug very sooty, when pulling to start it fires back through carb, have reset valve clearances which were near good enough but wondered about timing or poorly seating valves
you need to do a cylinder leak down test. That will tell you if it is a valve, which one or if it is rings. Try a compression test too. 5 pulls should be 160 to 190 ish. If all that is ok check the carb to see why it is causing a rich running scenario
Jan 10, 2013 | Honda Gxv160 55hp 55 Hp 25mm Dia Lawn...
HOW DO I FIX THE OIL LEAK COMING FROM UNDER MY GXV 120 LAWN MOWER ENGINE?
Depends where it is leaking from, wash it off to see where it is coming from, it may well be the bottom crankcase seal, once the blade and carrier are removed you should gain acess to this, if it is leaking you will need to remove the seal and replace.
Oct 07, 2012 | Garden
Honda GC190 can't pull starter cord
This is a problem with GC-160 and GC-190 engines on pressure washers, tillers, etc. Once they get some hours on them and as things seat in-wear in, they get to a point you can not pull the start cord. If you remove the spark plug, the engine turns easily then the valves need adjusted. The valves are set .005" to .006" off the seat. This allows enough compression release but the engine runs. I find the valves need adjusted every 25 hours, not the 100 hours Honda states.
Aug 29, 2012 | Honda Garden
Excell vr2522 pull cord jammed
Is the garden hose connected and turned on?If so make sure that the trigger on the gun is being pulled while your trying to start the engine! The backed up pressure in the high pressure hose can mimic a blown or seized engine in this situation.
Apr 15, 2012 | Garden
I have a 5.5 hp gx 160 honda engine. i had to replace the pull rope & now it will not recoil after starting. what did i miss?
re -do it and make sure it's on properly , do not let it snap back hard...that will screw it up every time. Pull it and slowly let it slide beck in. hope that helps
Sep 18, 2010 | Honda 8 HP Engine
2007 honda crf 250 r hard starting when cold ,
There is a proper way to start an engine. Most bikes have four controls to assist in starting.
  • The choke, used when the engine is cold. Pull the red knob for choke.
  • The " Hot Start " Lever, used when the engine is hot. Pull the lever to lean the fuel mix when the engine has been running.
  • The de-compression lever, always used.
  • The throttle, used to prime the cylinder.
Don't kick, instead, push the kick lever downward. You will feel the back pressure as the piston is going upward on the compression stroke to the point the pressure is great enough that the kick lever "locks up". You are very close to TDC. NOW, pull in the de-compression lever. Push the kick lever a little bit more to get the piston past TDC. Now release the de-compression lever. Give the throttle a 1/4 turn then let it snap closed. A diaphragm in the carb gives a shot of gas when this is done. DO NOT do this multiple times because you will flood the engine. Leave the throttle closed when kicking. A flooded engine will often backfire. Now give a strong kick through the full sweep of the kick start lever. Quickly get your foot off the kick lever at the end of the kick to avoid any chance of "kickback" from the kick lever. This happens in the case of a misfire, aka > backfire. It can be very painful, and can even break a leg. I am serious about that. Repeat the process (but without the throttle priming), until the bike starts. Go ahead and give it another primer shot after the 5th kick attempt. A good battery, a clean spark plug, a clean carb and clean air filter will also aid in starting.
Sep 23, 2009 | 2005 Honda CRF 250 R
Poulan Pro 18 inch saw. Once the unit is warm it
start saw when cold and work it hard. if it stalls or quits remove spark plug and hook the plug wire to the plug and ground to the cyl head have switch on and pull the start rop briskly a few times or use a test plug. if there is no spark disconnect ign switch from from the ign wires and pull rope a few more times.spark?= replace ign switch,no spark until engine is cool,replace coil.
Sep 23, 2009 | Poulan Pro Chain Saw 46cc 20"
Honda Gxv160 55hp 55 Hp 25mm Dia Lawn Mower Engine Logo
3,086 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
