Question about Ovens
I have a Weber Q 3000. How do you clean the gas pipes and orfaces themselves? Do they come apart? I thought I'd ask before I started unscrewing things. The reason I ask is that the centre gas pipe flames tend to get lower from the outside to the centre. I have cleaned each hole but this hasn't solved the problem. I want to know if I can soak the pipes in very hot soapy water this will clean any juices and fats that have dripped down off the meats etc.
Master_Tech
  • 770 Answers
SOURCE: Clean between door window panels
Sorry this is the only way to clean in there but if you take the door completely off and set it on a drop cloth Then take it apart it makes it a little easier
Posted on Jan 26, 2008
barkencoa
  • 3463 Answers
SOURCE: how to clean my oven
There are numerous products specifically produced for interior cleaning of ovens.
There are those that you spray on, and others that you use a brush to paint on..
The important thing to remember is that you do not put any on the oven liners at the sides,or let it get onto the paint work or the rubber seals ,It is also o/k to use it on the oven door glass. Instructions for use on all these products is to be found on the product packaging.
Plz rate my solution.
Thanks.
Posted on Jan 15, 2009
  • 38 Answers
SOURCE: Oven Caught Fire!!
Remove oven racks and look for two screws in the back on the bottom. Remove screws and lift out oven bottom. Do not use self clean.
Posted on Mar 17, 2009
SOURCE: I have a gas oven. The flame burns yellow and
I am not sure. However, people in our area of sc, have had burner problems because a local utility added propane to their natural gas because they got it a bargain. guy
Posted on Jun 12, 2009
Maytag317
  • 1136 Answers
SOURCE: Need to clean liquid drip from inside of door whirlpool built-in
Hi, The screws in the bottom edge of the door will need to be removed. The dor handles screws usually help hold the upper part of the door together. There might be screws on each side. Makes sure the door is laying on a flat surface and be gentle with the glass pieces. They are very fragile.
I am sending you a picture of the door pieces and how they line up inside the frame.
Please let me know if I can assist you further.
Vic
Posted on Jul 12, 2009
How do I remove and take apart the oven door to clean the glass from inside
tip door open part way and see if it lifts off the hinges lay on large table top or the floor and unscrew the screws around all edges separate the 2 halves carefully as to not break glass. reverse procedure to replace it . .
Feb 29, 2016 | Ovens
If you turn oven on, the igniter doesnt work, and sometimes igniter will work once but still won't light oven - we have to now press igniter button to get it to light. Gas does come out. I have cleane
And your point...kidding...i guess your igniter switch isn't sending a signal,or thermocouple is bad.Does it shut off and on while baking etc.if it does thermocouple is ok.Igniter end by flame may need cleaned,try that,but carefully,don't want to damage it.small brass brush,won't make sparks,not a good thing when your head is in an oven,don't use a lighter to see either,flashlight is fine.Just shut the gas to stove off,that will relieve the pressure in gas line .the shut off is usually to the side or behind stove..turn handle sideways to pipe,in line with pipe is the on position..If all this doesn't work,you probably need to replace the sending unit that sends signal to igniter..Or have a repairman do it.check up other sites on computer also about problem,that way you'll have an idea whats going,so repairman dosen't rip you off.
Nov 25, 2012 | Ovens
The blodge oven isnot releas of gas
chek the pipe line and the small part the pin gas realeas >>use by the small niddle to clean
Jan 19, 2011 | Blodgett DFG-100 Gas Single Oven
I cant clean my glass on my stove where do i take it apart. i tryed the 3 screws on top put i still cant take it out ( the glass part)
put the door down, and unscrew all the screws inside the oven door. Be prepared for the door to come apart as you come to the last few screws.
Nov 18, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
I have a whirlpool gas oven Model sf385peew 0 and iam changing it from gas to propane how do you adjust the flame and also do we have to do anything to the stove we bought the conversion kit but it dont...
turn the gass off
find the gas valve on the back wall
unscrew the top
and replace the top with the part from the kit
if you have orrifices you will need to replace those
they go straight down the center of the burner
Oct 03, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
I cannot remove the oven light cover in my Whirlpool gas range.
Put on a rubber 'serving' glove or dish washing glove and it will give you some traction to grip the glass to turn it
Sep 23, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
I have an electric Maytag stove/oven but don't know how to use the self cleaning feature. What do I do?
Dear cooper1914,
There are two types of Ovens that clean themselves.
1) A Self-Cleaning Oven which usually gets locked 1st then set on Self-Clean.
2) A Continuous-Cleaning Oven which is constantly cleaning
Some people prefer the old fashion clean by hand with degreasers but I prefer Self-Clean or Continuous-Clean as there is no need for harsh potent cleaners!
If you have a Self-Cleaning or Continuous-Clean Oven Do Not Clean With Cleaners as it will ruin the flavor of your oven!
Click on the following link for more info @ http://www.essortment.com/all/cleanoven_rbad.htm
Maytag Customer Support Manuals @ http://www.maytag.com/support/manuals_literature.jsp
jackiaria
Tuesday 02-24-2009 11:13am EST (USA)
Feb 24, 2009 | Maytag CWG3600A Gas Single Oven
How can I remove oven door so that I can replace the broken glass
I just took my oven door off and took it apart to clean the glass inside. I don't have a maytag but they probably all work alike. Just open the door like you are going to broil something and just lift it up. It should slide right off. Shouldn't have to unscrew anything. Hope this helps. Arlene
Nov 15, 2008 | Kenmore 33169 Gas Single Oven
Jan 26, 2008 | Whirlpool GBD277PD Electric Double Oven
Ovens Logo
89 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
