Question about Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive
Head is stuck or i think it is dead - Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive
    Problem Solver:
  • 17 Answers
You may be able to get the data off of it. You'll need another computer with an IDE port and a hard disk big enough to take any data that you may be able to recover off of your old drive -- hook your dead hard disk up to it as slave ( you can see how to configure your drive as slave here )
Put the old disk in the freezer overnight and then put an ice pack on it (put a towel in between so it doesn't condensate and get the hard disk wet) to keep it cool while you try to get the data off of it.
Be sure NOT to touch the circuit board that is on the bottom of the old hard disk to anything metal or you might short it out. If the computer recognizes the old hard disk; you're in luck, copy the data off to the new computer's internal hard disk as fast as you can; your old drive may die completely at any time.
Posted on Apr 09, 2011
How to repair speedometer 95 sidekick
hey and oldie but goodie.
why not post the full symptoms. ????
Speedo dead, makes noise, bounces? what? stuck high? what?
odometer dead.
CEL glows running, the check engine light glows, running
and you insert the 1cent paper clip in the DLC connector and you get
code flashing. code 24, VSS dead?
http://www.fixkick.com/CEL/CEL.html
if yes, the cable has snapped. (fell off at either end)
if not VSS dead, then the speedo is dead
if both odometer and speed are dead and VSS are dead the
snapped cable, or cable fell off rear of speedo head.
if VSS is not bad. (no 24s)
and only speedo is dead but , odometer is good
then that means the actual speedo clock inside the head is bad.
to repair a dead speed/cluster, you replace the whole head
if real frisky then you do this.
suzuki even sells new clocks, but are very expensive
what i do is find a used head. and use that. (car-parts.com) or at fleabay.
sometimes i mix 3 heads to get one, good head.
that is all you can do, on old cars unless rich, and $200 head is pocket change.
http://www.fixkick.com/sensors/speedo/unsafe-at-any-speed.html
tell more get more, ask.
Oct 18, 2014 | 1995 Suzuki Sidekick
Wiring diagram of headlight
easy but are both dead , or dim or stuck in high?
DRL head lamps or not? Canada has those.
Daytime, running lamp option or mandated.
here is ours. (usa , no DRL) the wiring changes by COUNTRY
the most simple system in the world. the TRACK-KICK.
http://www.fixkick.com/power-elect/Head-lights-nonDRL1w.jpg
Aug 16, 2014 | 1994 Geo Tracker
I need an detailed image of a ignition system for a mitsubishi montero sport 2000 3.0 6 cylinders
details are only 2 places, the FSM, Factory serv. man.
and alldata.com
you can look any time. sure can.
enigine stalls, did you give at tuneup first the 60k mile column?
if not, why not now?>
STALLS 101 (can be very complex. 50+ causes , but a few tests)
  1. can you save the stall with a fast right foot, (all time top check and 100% free to do...??????)
  2. Did the lights go dead at the stall , radio , head lamps dim, yes, do test this stalls issues, with head lamps on and dash fan. It the still work at the stall , that means you have 12vdc power, the loss of which kills dead any EFI cars engine.
  3. The car 2000, year, and as such as dirt cheap scan tool fits the port (16pin) near knees. you get a tool easy, everyone here in USA can do this easy, and not doing so, misses the BOAT. you can see why it failed at that moment. EG: lost CMP/CKP sensors, see DTC error, like P0300s.gross misfire, etc. gee LOOK and do not work blind, why miss these key facts?
  4. Lost compression hot.? 1 or all 6 cyl.
  5. lost spark 1 or all 6? tests. DTC errors. manual checks tuneup time.
  6. Lost fueling and flooding, Spark tips show flooding easy, LOOK.
keep in mind, i dont have #1 info above, and is key to ALL this.
Hints:
the EFI works over time to prevent stalls, so the problem is serious
the stalls can be , lack of air, ISC stuck closed (fast foot tells you)
or the ECU sees and error and decides to cut fuel.
the ECU does that on all cars, for 2 thinks, it THINKS spark is bad or
the TPS is stuck at 4v. or more.
Stall scan be engine runs so bad, the ISC can not raise the idle more. and stalls, (EGR stuck open)
a scan tool can be had for 9 bucks. (fleabay)
Jun 18, 2014 | 2000 Mitsubishi Montero Sport
Over heating lost water once and its not head gasket or head what is it
This can be a few different things..
Thermostat stuck, Elect fan not working, leak in one of the coolant hoses/lines...
Does it only overheat while at a dead stop and cool down while driving? Or does it overheat no matter what?
Jul 01, 2011 | 2001 Ford Focus
Cools but constantly runs
you hit the nail on the head there,,,its the thermostat its dead!
change it they often stick in the on poshion when they stop working to save any food inside of the fridge
Jul 12, 2010 | Haier HSB03 Compact Refrigerator
What does the headset symbol on a nokia 6070 screen mean? I can make calls but the line goes dead after the connection is made
It means that there must be a head phone or something still inserted in your phone. the line goes dead because the phone thinks that head phones are in and transfer it throught the head phones
Dec 08, 2009 | Nokia 6070 Cellular Phone
Paper stuck under the print head container
pls clean ur drum with tissue paper or soft cloth and then try once
even after if the same thing happens change the drum or catridge
Sep 07, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Won't power up. Disk stuck inside. Can i open that tray to rescue my rental?
take a small flat head and pry the door open if not the only other way is to unscrew cover and manually push tray open
May 13, 2009 | Panasonic DVDS97S DVD Player
Timing belt broke on mazda 5
Think you have to put a flat bar across the back of the cam shafts same as the old ZETEC ford motors. Failing that are the vernier pullies marked with eithr O T or do they have a - or a . that line up with a position on the end of the cylinder head.
May 12, 2009 | 2002 Mazda Protege
Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive Logo
81 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
terminalcon
John Anderson
John Anderson
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
