Question about Acer AL1916W 19" LCD Monitor
Cant get my monitor to come on dont know where to press to switch it on can you please help
Hi my problem is that without to do anything the monitor is sawing the operations about the screen and cant stop because the monitor dont respond my orders. please if anyone knows how to fix this,give...
It sound like your auto display setup menu is appearing on the monitor. If so, it probably says to press 1 or 2 to stop the display. If this is the case, then the #1 and #2 it is referring to are the buttons on the monitor-not your keyboard. If you look closely at the monitor controls, you will see that at least 2 of them are numbered.
Let me know if this is the correct problem.
Nov 05, 2011 | Hitachi CML175SXW 17" LCD Monitor
I want to use the scanner on my mp600, but my black #5 cartridge is out and I cant get off that display screen to scan to my computer. I dont want to print, just scan and save. Please help
After the printer decides the cartridge is empty it will start giving you warnings. Eventually it will give you a message to press the Stop/Reset switch for approx. 5 seconds to disable ink level monitoring on the empty cartridge. Ink level monitoring will be re enabled if a new OEM Canon cartridge is installed.
Hope this helps, thank you for posting. Have a nice day.
Jul 01, 2011 | Canon PIXMA MP600 all-In-One InkJet...
Cant get monitor to turn on. Have tried different outlets. The green light is working on the battery pack.
Press Fn F4 when computer is on.
Hope this helps ^^. Please dont forget to rate, Thanks
Mar 02, 2010 | ViewSonic VG700b 17" LCD Monitor
Hp pavillion dv2000 dont turn up
First thing to do is try to see if your external output will work. If you have an extra monitor around, plug it into the VGA port on the side. You can press the Fn button and the button for LCD (usually F7 orF8) to toggle between the LCD display and the VGA or both. Let me know if you can get the VGA to work
Jun 24, 2009 | HP Pavilion dv6000z Notebook
Ibm E54 monitor width problem
1.To replace TIP122 and it's related transisters (A733,C945) tracing TIP122 pins
2.Change Flyback caps
3.Open OSD select ZOOM Option and press 20 sec OPEN SERVICE MODE decrease the Width option &save it
4.Switch off the monitor
IF these solution was usefull pl appreciates rating
Nov 19, 2008 | IBM E54 15" CRT Monitor
My laptop mt3422 will power on but dont show nathing on scean
Please try to remove the battery and use the ac power only it it will still do the same thing.
Please try to use an external monitor to see if it will display what is supposed to be showing on the screen of your laptop. If it works with the external monitor, please try to press on the hot key combination for switching the display. If everything did not work, it is a hardware problem. Please let me know it any of these helped. Thank you.
Sep 30, 2008 | Computers & Internet
Problem with controler
The problem is defective keys/switches of front key PCB.You need to replace this key PCB or Individual keys.
Normally Benq Offers a 3 yr warranty Try contacting BenQ.
Please rate the solution and provide feedback.
Samir
May 15, 2008 | BenQ FP731 17" LCD Monitor
Please help..very important..dont know wat to do
place the monitor away from the wall by 10Cm. and no telephones or modems or wireless near.
May 04, 2008 | Computers & Internet
RECTIFYING MONITOR PROBLEM
sir,
i am having the problem of displaying the like following given in my monitor always and i cant see the anything displaying on the center .i dont know,how to rectify it.please give solutions to rectifying that.
Nov 21, 2007 | Samsung SyncMaster 720N Monitor
Problem with Control Panel
It sounds like theres a front panel button that has become intermittant and making contact all by itself. Sometimes when you clean the screen, the cleaner will drip down between the crt face aqnd the cabinet and make the switch in front go bad. Im not sure if this is the case in your problem but its a start. If you didnt spill anything or drip anything into the front panel then your maicroprocessor could be causeing the problem, or the 5 volts that feed the micro could be noisy ie, bad filter capacitor in the power supply. Now as im sure your aware of the hi voltage inside these sets? Its best if you dont have the training to get a pro to assist you as this hi voltage can hang around inside the set even if its unplugged. Good Luck
Jul 03, 2006 | SAMTRON 55V 15" CRT Monitor
Acer AL1916W 19" LCD Monitor Logo
408 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
