Question about KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher
I have the KitchenAid Superba dishwasher in stainless steel. I've noticed that my tupperware (especially) are never dry after a cleaning cycle. Even if I wait a couple of hours after to empty the dishwasher. Is there something I can do?
    Master:
    Sergeant:
  • 385 Answers
You might try using Jet Dry in your rinse aid dispenser, but plastic things tend to hold water and there isn't much you can do except try using Jet Dry.
Posted on Apr 09, 2011
Kitchenaid dishwasher wont stay closed
you might need a new Latch, Drawer (left Hand) part number 8194053 okay
Feb 07, 2013 | KitchenAid 23 in. KUDD01DPPA Stainless...
Kitchenaid dishwasher Kudio1il 24'stainless steel. Problem with control panel. Dishwasher will not start. Only NORMAL button, HI-Temp button, Energy Saver Dry button, and cancel button light up when...
I'm having similar problem.I uploaded video of my attempt to reset and problem that I have after.I've already tried replacing my board... but have the same problem. The board was a refurb... so not sure if the board sent was defective - or if the problem is the control panel or something else?? thoughts?https://www.box.com/shared/ef486b70331cd4462ed6
Oct 05, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
The "clean light" is flashing
Indicates control hasn't sensed a rise in water temp during heat cycle. Make sure you hear the water being circulated during wash cycle. If so the heater, control board, thermostats or wiring are most likely bad. If heater, therms, and wiring check good its usually the control. When fixed press Heat dry- Normal-heat dry-Normal or High temp- air dry-high temp- air dry to reset control.
Sep 25, 2011 | KitchenAid 24 in. KUDI02IRBS Stainless...
The clean light will not stop blinking so the normal cycle will not run
From another link, clean light flashes 7 times. Turn off breaker for dishwasher, wait 5 minutes, turn back on. with dishwasher door open, push high temp, energy save dry, high temp, energy save dry, then close door, open door, press cancel and then Normal wash cycle. Dishwasher Starts!!!!!! Save myself several hundred $. Was about to buy new one from Lowes!!!!!! Thanks everyone!
Feb 01, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kitchenaid superba dishwasher does not pump water through sprayarms. Water comes in and empties
Welcome to FixYa,
It may be a seized wash pump, worn wash impeller or simply a plugged up pump preventing a proper wash cycle.
The place to start for that is to pull the pump filter, spray arm and check for food deposit, broken glass, undesolved detergent and general water deposit built up in the sump well.
The key is to get in there and clean it all out, I`ve attached a link at the bottom that will show you how to go about it. It may not be your model, ( Most Whirlpool, Inglis, Kenmore, Kitchen-Aid, Jenn-Air ) but it is the same procedure.
When you`re finished run it through a test cycle and see how it goes.
Let me know how you make out and what you find.
macmarkus :)
http://www.youtube.com/watch?v=iRCCrEwrst8&NR=1
Aug 19, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
I want to replace the white door panel with stainless steel
Have you checked with www.applianceart.com? They have faux stainless and real stainless options. PLus a ton of other choices there.
Feb 21, 2010 | KitchenAid 34 in. KUDP01FLSS Stainless...
My dishwasher leaves crumbs and food particles stuck to everything in the top rack
Usually this problem is due to the fact that the dirty particle filled water isn't fully draining and the unit is trying to rinse the dishes with fouled water thus baking any leftover food particles during the dry cycle.
Make sure that all of the water is draining from the dishwasher after all drain cycles.
Usually poor draining is due to a blockage or partial blockage in the drain line,also the blockage can be at the drain pump itself or where the drain connects to the under sink drain
Dec 20, 2008 | KitchenAid Superba Architect KBCA06XPBS...
KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher Logo
238 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
