Question about Husqvarna Garden
I have just purchased a Husqvarna 128CD trimmer and it boggs down and you have to play with the trigger to keep it running when you are trying to cut. I have not even used the line that came with the trimmer.
    President:
  • Husqvarna Master
  • 1,545 Answers
This sounds like the carburetor is out of adjustment. I would first advise you to seek warranty related service at the service center the seller dictates to have the carburetor set properly.
Posted on Apr 09, 2011
Husqvarna
1. [Broken Throttle cable?] I would start by making sure that when you press trigger you see the throttle cable moving linkage on carb.
2. [Spark arrester clogged?] There is a small metal screen at muffler that is known for getting clogged with carbon deposits and will prevent air/exhaust from leaving engine properly, causing it to bogg down. Try removing it and test run, if that fixes it clean or replace spark arrester.
3. [Incorrect spark plug?] If spark plug was changed recently and is not the correct one for this model trimmer it can do that. Or, if spark plug is fouled(too much carbon built up/or incorrect gap).
4. [Bad carburetor?] if there has been water in fuel, or carb has stiff diaphram inside it will not run properly.
5. [Needs service?] if none of the above work you may have to take it in for repair.
Aug 18, 2014 | Husqvarna 323R 24.5cc 2 Stroke Gas Powered...
Is there a cut off switch
Yes, should be on the handle, most are toggle style switches.
Jul 03, 2014 | Husqvarna 128CD 28cc Gas Line Lawn Trimmer...
Replacing the Coil on a Husqvarna 128CD
I'll send you a link to the 'illustrated parts manual'. pretty straight forward, just unscrews to remove. timing gap should be 0.25 filer guage.
Aug 18, 2012 | Husqvarna 128CD 28cc Gas Line Lawn Trimmer...
Coil
Here is a link you the IPL, shows complete brakedown od machine.
Poulan pro weedeater 330 runs but no power. boggs downs when full trigger pull
remove the muffler and try it if ok open the muffler and clean out the carbon from the screen
Apr 06, 2012 | Poulan Garden
We're having trouble with our just-purchased Husqvarna 128CD trimmer - the tap head doesn't seem to work properly. When I tap the head, the line doesn't extend. On first use, the line became...
It is a fairly simple head, push the two ears in either side of the head, the black base will then come off, check the cord inside has not become trapped, check the blue button depresses ok, re assemble, run the machine at full revs and bump it down on the grass.
Jul 09, 2011 | Husqvarna Garden
I have a 128cd. The weedeater starts good but keeps stalling when switched to the full run position.
possibly a fuel starvation issue. check carb settings and possibly clean and replace diaphragms if needed.
Jan 25, 2011 | Husqvarna 28cc Gas Line Trimmer
How do i take the whole weed eater head off of my 128cd to add another type of head
You have to hold the dust cup with a wrench to keep the shaft from rotating.
Oct 29, 2010 | Husqvarna 28cc Gas Line Trimmer
Garden Logo
167 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
