I AM UNABLE TO FIND LOCATION TO PLUG HEADPHONES IN ON THIS MODEL TV "DUAL DDLCD1905" REGARDS JOHN
2 Suggested Answers
SOURCE: I NEED TO RETUNE THE FREEVIEW ON MY DUAL DDLCD1905
If you havent already. Select DTV from the source menu.
then press the DVB button on the remote and choose system setting.
Select First Time Installation to reset all DTV channels
Posted on Jun 17, 2010
Trying to get hook up with AUVIO wireless headphones to SONY TV MODEL KDL-40W600B. If not AUVIO then my Beats pill. Goal to have TV sound in/on bed close to me. Beats pill Blootooth
Jean,
I take it the Auvio wireless headphone main base has both dual rca and optical in jacks? If so, what you need is a 3.5mm stereo male to 2 rca male cable. You will plug in the 3.5mm male plug into the green audio out/headphone jack port that should be on the back/left rear side of your TV. Then you will plug the dual rca plugs of the cable into the Auvio rca inputs. You can get the cables in various lengths so you can have the Auvio base in a good location. If you need a visual of the cable type: http://www.monoprice.com/product?c_id=102&cp_id=10218&cs_id=1021815&p_id=5598&seq=1&format=2
Hope this helps:)
Sep 13, 2015 | Sony Televison & Video
Trying to get new headphones to cancel speakers on tv
What kind of headphones and TV are you trying to make work as an combined pair? It sounds to me as though you have your head phones plugged into the speaker location on the TV which could be a small hole that shows a pic of speakers. Look on the TV for an 'mic' or 'pic of headphones' holes. If there is an plug in hole with either it states mic or shows a pic of headphones plug the headphones into that hole instead of where you have them plugged into now.
Another suggestion is to use MDI cords in which you may already be using aka white, red, yellow colored plugs. If those plugs are assembled in the slots incorrect that also could be the reason as to why the headphones turn down when you turn the volume to the TV down; which also would influence the TV volume its self to also disengage to go either louder or quieter. MDI cords should be plugged in the following pattern to be categorized as the following with each color following the next color; yellow, white, red. Now if you are using MDI cords presently do you have them plugged in front or back of the TV?
If the TV has hole ports in both front and back for MDI cords then reverse your plug ins. Example: If you have them plugged in the front instead switch all three to the back of the TV or vise versa.
Also another thing; since you are wanting to use headphones for your TV speakers instead of the TV speakers themselves usually plugging headphones in are controlled by TV volume buttons; however I am assuming that you are trying to state that when you plug headphones into the TV you still hear the volume in your ears and anyone in the TV room is also still hearing the TV even though headphones are plugged in, am I right?
With you wanting to cancel the speakers on the TV out only attempted to use TV volume for speakers and without it working means you have the MDI cord plugged into the audio which would cause the TV to power the volume for the headphones anyways. May I ask this; since I am a bit confused, alright are you wishing for the headphones to be able to be loud enough so the TV only powers them for volume when you use the TV?
I know that headphones being plugged into an TV should only keep their volume within the ear buds. Therefore I have never heard of headphones being able to be loud enough to power out room sound. Instead they power internal volume which would be within your ears. Headphones were meant to keep noise and volume from surrounding a room to block room noise out and to keep the sound for your/ an own persons only listening capability. So because of this I am confused as to how ear phones would have the ability to sound the room with audio.
I can understand that if what you are trying to say is that the speakers on the TV still output volume even with head phones plugged in which would be an issue, since head phones are to capture the volume and noise from the unit in which plays aloud- to actually silence it instead- for the individual whom requires or presumes to have themselves to be the only listener.
Jan 02, 2014 | JVC 900MHz Wireless Stereo Headphones with...
Where do you plug in the headphones?
You can plug in headphones but you need an adapter. Also, not all headphones will work well with this TV. You should get headphones with in-line volume control. Then connect the headphone 3.5 mm M to a 3.5 mm F to dual RCA (1/4") M/M adapter. An example is http://www.sears.com/shc/s/p_10153_12605_05711931000P?sid=IDx01192011x000001&srccode=cii_17588969&cpncode=22-191604286-2 .
Then use the TV audio menu to turn off the TV speakers and enable the external speakers. Note the TV volume control will not effect the headphone volume.
I hope this helps.
Dec 23, 2011 | Mitsubishi WS-48311 48" Rear Projection...
When i plug headphone jack into the headphone socket on t.v, the volume on t.v does not mute. I cannot get any sound through headphones either?
Hi mowl, my name is John. Welcome to FixYa. Make sure that your are putting the right headphone jack into the jack plug. Some plugs are different than others. Look at the manual and it will tell you what kind you need. Don,t have a manual, you can download it here, its free. www.manualsonline.com . You will need your make and model. Thanks for choosing FixYa......John
Dec 07, 2010 | Televison & Video
I need a dvd player of a DDLCD1905 MODEL as our one is not working if you have one how much does it cost, thanks karen.
did you manage to get one if so can you please tell me where form as i also need one just the dvd player. contact me on riaz_fir@yahoo.co.uk
Nov 02, 2010 | Televison & Video
How can I hook up a nintendo wii through my
Hi, There should be an av button.
do you not have spare connections on your tv?
This is your best way, unless you want to record what you are playing.
Which model do you have?
I will try and help
Regards - Anthony
Feb 08, 2010 | Philips Magnavox DVD/VCR Dual Player
I NEED TO RETUNE THE FREEVIEW ON MY DUAL DDLCD1905 TV
Sep 30, 2009 | Televison & Video
How to plug in the tv card with my motherboard?beacose wenn i plug in the blue jack in my PC just listen sound from my headphones???sorry for my bad english
when you have the TV card installed, you need a TV cable like that of CAT-V cable to be connected with your Cable TV and then attached to the port at the TV Card.
Regards!
Jul 25, 2009 | Prolink PV-BT878P+ w/FM RC
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
Electro Med Services...
