Question about LG LS-K2430HL Heat Cool Mini Split Air Conditioner
My LG LSN182HE will not turn on using remote or the one button. I check fuses and breaker and they are fine. Power is coming into the inside unit but nothing happens when I push the power button. I turned it on AC mode and it started running. When I went back into the room later the unit was off.
    Guru:
  • 1,833 Answers
You should check the condition of capacitor, there may be a small transformer inside the unit, check it for 24vac. If your problem still exists then you can contact with LG technical support at http://www.lg.com/my/general/contact-us.jsp.
Posted on Apr 09, 2011
I have an Harmon Kardon AVR 85 and the power will not come on. The batteries are good in the remote, I have unplugged and plugged the unit back in, but the red light stays on and will not power up. How...
First of all, if you have just been powering up with the remote, try pushing the actual button on the unit. From owning a HK receiver, I found out that if the power switch is out, it will not turn on from the remote. Duh moment when I discovered this.
It also might be an internal fuse or circuit breaker that is shorted or tripped. If there is not an outside breaker or fuse, send this to a repair person. Sometimes there are capacitors in the power amp circuit that can hold a lot of voltage for a good length of time. You could get shocked. So, you might want to let the repairman handle this. Otherwise check for an outside breaker or fuse, and replace if needed.
You can also check Harmon Kardon's site for customer support.
Feb 19, 2011 | Harman Kardon AVR 85
I changed a light fixture in the washroom and It seems that there was a line in the connection box that also serves the wall air conditioner in the bedroom. After checking all the lamo connections again...
Hello Check the wite connections again with a flashlight and see if a wire end broke or is loose.Check the curcit breaker panel box to see if they are all on.How did you turn off power to work on the lamp?The problem is there ,some units require 220volts power.The unit will use the breaker for protection,Did something short out(sparks) at the fixture?
Aug 31, 2010 | LG LS-L1210CL Mini Split Air Conditioner
AMCOR 24,000 BTU split system. Worked fine two years, then today it had no power. Checked circuit breaker, it had popped. Reset CB and went to inside unit - would not turn on or off with remote or hard...
I had this same problem. I disconnected the thermostat wire out side at the condenser and reconnected it and it started working. A couple days later it blew the breaker again this time I found the bus where the L1, L2. GR wire connect at the condenser had melted. I wire nutted all 3 wires instead of the using the bus everything is working right again. Hope this helps.
Tim
Aug 09, 2010 | AmcorAire UCHW-H24AF2 Split System Air...
My LG AC doesnt have power when u turned it on. Power plug-in is
You should start by checking the breakers for the unit ( both the inside and outside unit). Then look for any fuses that may be blown. There is also a force on button somewhere on the side of the indoor unit. After you make sure it has power use that button to try and start it and make sure everything runs. Let me know what you come up with.
May 03, 2010 | LG Art Cool LA121CNP wall/window Air...
I have a Sharp portable room air conditioner model CV-P10NC. The power plug RESET button and TEST button will not click in order to check out the power plug as the unit will not turn on. They did test O.K....
the fused9G.F.C.I.) cord you speak of is probably the G.F.C.I. built onto these units by design, can you or someone you know get access inside the unit and :Hot-Wire" the units cord and,bypass the power cord ( Just To Test the Unit)and see if it stays operational then replace bad unit cord if this is it.
Sep 12, 2009 | Heating & Cooling
No power to the boiler--- breakers are all fine
What type of unit do you have, need details, if it is a split system there will be a pc board inside inside / outside or both units, on the board will be a glass fuse, turn power off at switchboard before removing covers.
Nov 12, 2008 | Heating & Cooling
No cooling after power out, indicator lights pattern not in manual
The Mitsubishi units have to be reset by turning off the indoor units by switching the remote or thermostat to off. Then turn off the breaker to the outside unit(s). After 30 seconds,turn on the breaker and then you can turn on the remote for cool. If no lights come on on the inside units, most likely you have blown a fuse soldered on the main PC board. At this point, call your technician. A goos tech will be able to wire in an in-line fuse holder so if it should happen again, you can easily replace the fuse. If you do see a light or two come on at the indoor unit but the outdoor unit does not start after 3 or 4 minutes, sounds like you will need to call a technician. Most likely you have a blown fuse on the main PC board of the outside unit. It is not an easy one to replace. Good Luck!
Aug 31, 2007 | Mitsubishi MSH09TW Air Conditioner
LG LS-K2430HL Heat Cool Mini Split Air Conditioner Logo
113 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
