If the card is new, make sure you have the card installed properly in a PCIe x16 slot properly. It should hook on on end and you may have to push in on yjr tab that hits your case as it goes in. Go to device manager and click on "sounds audio and game controllers" and see if you see your card. Right clcik on it and you should see "disable". If oyu see "enable" click on that and exit. If you have had prior cards, make sure you have uninstalled all prior software. Prior to downloading software for new card. If none of this helps you, and/or you have just installed Windows 7,I would try to uninstall software and reinstall from your installation cd. After that, you can download graphics driver and Catalyst Control from here:
http://support.amd.com/us/Pages/AMDSupportHub.aspx
Your info is enetered except for your o/s. If you download you driver from here, you have to do a custom uninstall of driver and catalyst, then a custom install of new driver and catalyst. Make sure you restart after unistalls and installs.
The Turn Signal Indicator
The Sidemarker Lamp
The Sideview Mirror (Pontiac Thunder only)
The turn signal switch also sends a separate on-off signal to the Daytime Running Lamps (DRL) control module, which relays the signal to the appropriate front turn signal. The front turn signals are grounded at G101 and G102. The rear turn signals are grounded at G401. The sidemarker lamps are grounded through the corresponding front parklamp.
The sideview mirror turn signals are a bank of LEDs placed behind the mirror glass.
The hazard lamps operate on battery voltage. The HAZARD fuse supplies battery voltage to the turn signal switch. When the hazard switch is pressed, the turn signal switch sends battery voltage to the hazard lamp/turn signal flasher, which sends an on-off signal to the turn signal switch. The turn signal switch send the on-off signal to all the turn signal lamps, causing all the lamps to flash including both IPC turn signal indicators. The hazard lamp/turn signal flasher is grounded at G200.
When the parklamps are ON, the sidemarker lamps receive voltage from the park lamp supply voltage circuit and illuminate. The sidemarker lamp is grounded through the corresponding rear turn signal. When the turn signal switch is place in the left or right hand position, the rear turn signal illuminates and the sidemarker lamp will loose its ground, causing the sidemarker lamp to turn off when the turn signals are on and to illuminate again when the turn signal is off.
Which blub an socket did you replace ? check the other blub ? The switch and or the flasher module can cause this problem .
Replace the turn signal switch. Refer to Multifunction, Turn Signal, and Hazard Switch Replacement - On Vehicle in Steering Wheel and Column.
Did you complete the replacement?
Which
