Question about Kenmore 64882 Electric Dryer
We need to change the drive belt. How do you take the dryer apart to change it?
  • Kenmore Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley or a faulty motor.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place, some seals are furnished with the cement to glue it in place.
Note: This method works for most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the screws that hold the filter housing.
Then remove the top of the dryer.
Note: Some of the tops tilt backwards and do not have to be removed completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
Note:The way the belt goes back on is, as the belt comes off the drum has to be doubled (pushed together to form a loop) and goes under the idler pulley then to the motor.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
This is a FREE answer, Please rate me
Posted on Apr 09, 2011
Testimonial: "Thank you very much for your solution. It was very helpful to us. We have the dryer apart and are waiting on the belt we ordered to come in. Thanks "
3 Suggested Answers
  • 686 Answers
SOURCE: Drive belt on Tumble dryer
YOU NEED TO POST YOUR MODEL NUMBER AND THE MAKE
Posted on Apr 10, 2009
  • 15 Answers
SOURCE: changing dryer belt
The drive belt goes around the drum near the rear. It does not use a special groove; it just runs on the surface of the drum. You will need to remove the drum to gain access to the broken belt, motor, and idler/tensioner pulley. It will make more sense when you remove the drum and view the motor pulley and belt tensioner. With a helper, install the new belt around the motor pulley and under the tensioner, then fit it around the drum little by little as you reinstall the drum. Make sure the drum is positioned properly on its rear support wheels, then manually support the front end and rotate the drum slowly by hand. It should rotate freely and the belt should start to track straight as it realigns itself on the drum. If it tracks well, reinstall the front panel, door, top, etc., and check operation.
Posted on Jun 27, 2010
Heat is blowing out but the drum is not spining
You broughtke the belt of drum wont turn you might take the dryer apart to make sure the idler pulley is spinning free also. They sometimes get tight and burn the belt up.
Apr 10, 2015 | Avanti D110 Electric Portable Dryer
Tip
My dryer drum will not turn...."how to change your dryer belt"
There are many styles and different models of dryers but the one thing they all have in common is the dryer has a belt that turns the drum.In the procedure below we will show you how to take apart your dryer,change your belt,and show you the correct threading of your belt. Here is a typical Kenmore dryer idler pulley(it has a plastic wheel on it) motor/pulley (the pulley is attached to the backside of the motor) and the belt configuration.Note the picture below.
Each different model dryer also has a different lint trap location. This location will have a bearing on how your dryer is taken apart and how to change your belt.
Note the location of your lint trap and choose the correct video on how to take your dryer apart. There are two different locations,on top,and in the door.
This video will show you how to take apart your dryer and change your belt if the lint trap is on top of your dryerhttp://www.youtube.com/watch?v=CFnXwmUb4f4
lint trap on top
This video will show you how to take apart your dryer and change your belt if the lint trap is inside of your door. http://www.youtube.com/watch?v=rtATa0a28bE
lint trap in door
This video will show you how to take your dryer apart and change your belt with the control panel in the front side panel rhttp://www.youtube.com/watch?v=zpUqCrLaI7g
control panel in front
This video will show you how to take apart your Maytag L shaped dryer and change your belt.
http://www.repairclinic.com/PartDetail/Belt-Drive/1246110?modelNumber=LDE8424ACE#repairHelpVideoTabs
L shaped dryer
If you happen to run into an issue with your belt and pulley configuration all the diagrams are here click on the linkhttp://www.repairclinic.com/Dryer-Belt-Diagrams
If this has helped you please consider giving us a 4 thumbs up on our rating.This procedure has saved you a minimum of $125.00
Thanks in Advance and Thank You for using Fixya!
on Mar 21, 2011 | Dryers
Change dryer belt
Thank you for your post, Amanda II!
Based off the information you have provided you need assistance in taking off your belt on your Frigidaire dryer. I was unable to locate any instructions on how to remove the belt or replace it. This is not a simple DIY job. I would recommend having a professional technician come out and disassemble your dryer for proper installation of the belt. They will have the appropriate tools to taking apart your dryer. I hope this is helpful to some degree. -Matt
Jan 22, 2015 | Frigidaire Dryers
Haier dryer RDE/RDG 350AW
Replace the drive belt must have slipped off maybe loose from use.
It does say in manual to store and move in an upright position.
Sorry don't have a reapir manual but crack it open, and either fix the belt if it has slipped off its tension pulley or you will need to replace the belt just did my LG dryer last weekend a 4 out of 10 difficulty,,,about 1and half job....belt costy me $25.00 hope this helps some.
Jul 23, 2014 | Haier Dryers
Dryer has no heat
I have one of those Kenmore "Laundry Center" stacked washer/dryer units. It comes built that way - it is not two units stacked on top of one another (if there is such a thing).
My guess is that it is at least 13-14 years old now (it came with the house I bought) and about 3-4 years ago, it also stopped heating. The dryer would run for a couple of hours and all of the clothes would still be damp and the air in the dryer was not warm or hot.
I searched online and found that the usual cause is the heating element wire was probably burned out if the dryer was otherwise running all right. I found some repair instructions online and the procedures to take the dryer apart (can't recall where - just Google it).
The heating element is like a long coiled resistance wire, similar to what you would see in a toaster but heavier duty. It is strung in a circle behind the dryer drum tub to heat the air that enters the dryer.
If you've ever looked into a toaster when toasting, you'll notice that that thin resistance wire glows red hot which generates the heat. Now imagine that thin wire being red hot and the dryer tumbling, causing constant vibration. It's amazing that the heater resistance wire doesn't break more often!
A pretty handy DIY-er can take the dryer apart and replace the heater wire, but the challenge is getting the stacked unit out in the open somewhere where you can work on it. You need a fair bit of room.
My advice would be to also buy the drum belt replacement kit to also replace that at the same time. If you're going to go to the trouble of taking the dryer apart to replace the heater wire, you might as well replace the drive belt and associated felt pad, etc. at the same time. You DON'T want to have to take the dryer apart again a little later to change that part when it breaks. (It's like a timing belt on your car - if you're doing major work on your car and have the engine apart and it's "about time" to replace the timing belt per the manufacturer's maintenance schedule, might as well do it a the same time to save on repeating the labor again.)
Apr 05, 2014 | Kenmore 98702 Stacked Washer/Dryer
Need diagram of belt installation for dryer DV218AEW
Hi mcpitts...
Click on the link to find your model number link http://www.repairclinic.com/Appliance-Parts
Here is the process for taking your dryer apart mentioned above.
You will need to decide which video fits your machine appearance.
Please take time to rate me
Aug 10, 2011 | Samsung DV218AEW Electric Dryer
Its hot but wont spin
Hi, read about your problem. Problem is is that the drum drive belt either came off or is broken. You will have to take the dryer apart, after unplugging it. Top comes off first, then the front. Changing the belt is not easy but it can be done. Hope this helps
Jan 19, 2011 | Hotpoint Dryers
Whirlpool gas dryer turns on drum spins exhaust is clear and blows air but it wont ignite
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor  and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor  and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here  + new25.gifExpanded repair helps for a common "Even Heat" dryer
Mar 30, 2009 | Whirlpool LGR8648L Gas Dryer
Fitting new belt to Hotpoint9320w tumble dryer
Put belt around spindle then pull pulleys apart and rest onto belt.
I am assuming that the spring which holds the pulleys together is still in place.
Please post back if any further assistance needed.
Thankyou for using Fixya.
Jan 29, 2009 | Hotpoint TDL14 Electric Dryer
Kenmore 64882 Electric Dryer Logo
91 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
