Question about Briggs & Stratton Garden
I think my carb is staying full open as the govoner spring pulls one way but not the other. this is causing the flooding there for my engine is not starting ,any advice
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Briggs & Str... Master
  • 1,917 Answers
You need a carb rebuild kit sound like the needle valve is leaking inside it
Posted on Jun 24, 2014
3 Suggested Answers
  • 16 Answers
SOURCE: 12hp brigg & stratton engine
Sounds to me like the float needle valve in the carb is leaking. This will cause fuel to over flow out of carb, and will even get into the engine oil. Check to be sure that float is not got gas in it the can go bad. Also check float adjustment. Check needle and seat very carefully for dirt or wear. Just the slightest bit of dirt or wear can cause it to leak. Hope this helps.
Posted on Sep 18, 2010
rebuild carb.needle is not seating
Posted on Nov 04, 2010
I HAVE A TORO S-620 SNOWTHROWER.it was running fine but stalled and now pully rope won't release and won't start using electric start.any ideals as to why?
It may have stalled due to flooding and the pull starter wont work because the engine is hydrolocked. Take off the spark plug and see if the pull starter frees up. If it does than I think your electric start will work again as well. The cause of the hydrolocking may be a hung open float in the carb. Which maybe due to fuel gelling in the carb from long periods of sitting. So the Chem-Tool idea is a good one but I would also check the carb by having someone take the carb bowl off and looking for gelled fuel.
Feb 16, 2015 | Toro Garden
Motor starts good idiols high and stays there
rebuild carb with factory kit..,it sounds like its flooding. Or throttle is stuck wide open..,maybe a bad return spring is broke.
Dec 13, 2014 | Garden
Model 294777 type 0015-02 govoner springs diagram bridge&straton
To set a governor loose the nut that holds the arm pull it toward the carb then take a pair of pliars and turn the shaft counter clock wise while holding the arm toward the carb tighten the nut. good luck..
May 16, 2014 | Garden
Ford Ranger Carburetor Problem
Usually there is an electric heater on the side of the carb that opens the choke. You may want to check the heater to see if it has voltage and if it is working.
The linkage for the choke can get sticky or dirty and not work. Basic gravity and a spring opens the choke so the linkage must move freely.
Jan 04, 2013 | 1984 Ford Ranger
Runs for about 20 seconds then dies. will run at low idle but when you increase throttle it dies after a few seconds. already cleaned carb, just had it rebuilt last year. i noticed that when it dies the...
I would check the govoner spring, maybe it is worn out or isn't on correctly.
If this isn't the case I would check the fuel air mixture screws if your carburator has them, maybe it is getting too much fuel when the throttle is turned up.
Apr 21, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
1100 midnight special carb and gearbox settings Carbs flood and heavy on fuel When pulling away the gears slip between 1 st and second if the power is opened up, slowly pulling away under 2500 rpm seems...
do you have belt drive or chain? if you have chain and isnt adjusted and could be adjusted a little bit tighter you might see some improvement....oh and don't be wearing tennis shoes when you shift....wear boots....i"ll tend to give a more positive up-shift into second gear!
As far as carbs flooding....do you turn your fuel to the off position and check the fuel cap vent system....too much pressure in a full tank and an open petcock my cause those bowls to over-flow. drizziling fuel into the carbs. Wet plugs in the morning.....hit the kill switch and crank for 5 sec.with throttle wide open, then wait 10 sec put kill switch back to start and try again.....you might also have the wrong fuel pump installed!
Sep 13, 2009 | Yamaha XS 400 Special Motorcycles
My 1987 firebird keeps flooding out,why?
Several things can cause this but start by verify the choke pull off which is responsible for opening the choke plate after engine has started.It will recieve engine vaccum once started and open to allow air into the carb. This is a vacuum dash pot/pull-off externally mounted to the carb with a linkage arm to the choke plate.Without this opening,the engine will be starved for air and put you into a full rich condition. Another external device wchich can mysteriously cause rich conditions is the canister purge valve. It can introduce raw fuel and vapor on start up when failed.It is a black plastic valve near the carb with small and large vacuum tubes.
Jul 19, 2009 | 1987 Pontiac Firebird
MOWER WILL NOT RUN AT FULL POWER .
try empting the feul tank and put fresh feul in with a little dry gas treatment if that dont work try getting some carb cleaner in a spray can start mower and gingerly spay into carb trying not to over flood it keep spraying untill running smooth change CRANKCASE OIL and AIR FILTER.
Apr 25, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Stalling
likely you air to fuel ratio is too lean, runs mean and hot but under load dies. then floods the carb.
when it happens pull the plug ,
kill engine :
is there a lot of gas or none.
remove the filter and watch the action of the carb does it open and close easily is the filter clean.
try supplying it more gas turn the gas supply screw 1/2 CCW and see if it will stay running, if not add more.
( NOT the idle screw on the carb side w/spring )
By the way did a bit of water come out if not the clutch/pump may be binding or stuck with soap goop.back flush with hot water.
Apr 13, 2008 | Karcher 2500 PSI Pressure Washer
Garden Logo
29 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
