How do I remove the Encoder strip on a designjet 500 24"
    Genius:
  • 1,089 Answers
1. Remove the left hand cover
2. Remove the right hand cover
3. Remove 1 T15 screw that secures the Encoder strip to the left encoder holder
4. Release the Encoder strip from the left hand side
5. Release the Encoder strip from the Service station holder on the right side
6. Remove the Encoder strip from the printer
Posted on Apr 10, 2011
Designjet T 770 error 87:10
Actually it has to do with a "dirty' encoder strip. The carriage cannot read the strip due to a coating of ink-over spray from time. My suggestion it to call in a Service professional who is familiar in cleaning Wide Format printers. Other areas also are in need of cleaning, lubrication as well. Timing is "Everything" on these babies 60752e95-9503-4f40-8e0c-e67a2ad6b300.jpg
Jan 21, 2014 | HP DESIGNJET T770 Printer
When i was replace the trailing cable my plotter writing the system error:86:01 how to solve
86:01 fatal error code resetable with power cycle- error is down to encoder not reading/ blockage on media path - encoder strip missing
1. clean and clear accuride rails ( long silver bar )
2. Clean or replace encoder strip
3. clean or replace encoder sensor
if all else fails contact Belmonte.co.uk for fast response
Jan 02, 2013 | HP DESIGNJET 800 42IN 1200DPI 96MB PAR USB...
My Hp z6100 carriage jamms in the middle along the encoder strip during printing and gives me error 86:01. I have tried cleaning the encoder strip and still having the same problem
Maybe u need another encoder strip If u dammaged the strip while cleaning.I've cleaned mine only once with water and a soft a wet clout.Cleaning must be verry gently
Jul 29, 2011 | HP Designjet Z6100 InkJet Printer
My plotter is saying that there is an error, number 87:10 What is this, and what can i do do? Its a HP Designjet T610.
The printer is having a problem finding the Scan-axis encoder reading.
Start by upgrading the firmware. Go to www.hp.com. Go to Support and Drivers.
Enter your printer model, select your operating system, select firmware.
Follow the directions.
If that doesn't fix the problem, clean the encoder strip( the flat metal strip that runs the length of the printer).
If the problem persists, someone trained on DesignJets is going to have to look at it.
Hopefully, the firmware will fix the problem.
Mar 23, 2011 | HP Designjet T1100ps Printer
HP designjet t1100ps error 21:13
This is a service station error indicating that the printer could not move the pirnthead mechanism over the service station. First check to see if there is anything in the carriage path such as a piece of paper blocking the carriage. If there is not then it is likely a bad service station that will require replacement. Always try powering pirnter off then on to see if it was temporary error.
Mar 21, 2011 | HP Designjet T1100ps Printer
87:10 error in HP plotter 1110
There is a problem finding the Scan-Axis encoder reading.
1st thing to do is upgrade the firmware (www.hp.com)
Try cleaning the Encoder Strip.
If that fails the encoder strip will have to be replaced.
Mar 03, 2011 | HP Designjet T1100ps Printer
Printhead path error type 2
The cause of the error is because the carriage is not moving normally. This could be caused by a number of things. Unplug the printer while the carriage is moving in print area of the printer. Open the top cover and manually push the carriage to its limits left and right. Listen and feel for any obstruction and correct anything that is in the way.
Check the condition of the carriage belt. If there are rubber crumbs under the belt, replace the belt.
Clean the encoder strip with a soft cloth and warm water. Use canned air to blow out the encoder sensor under the carriage (aim the air tube parallel to the encoder strip on both sides and give it a blast. The sensor is on the bottom of the carriage in the middle).
If the tube assembly has been changed, be sure the tubes are routed correctly. Remove and throw away the screws on the rear door behind the ink supply station.
Get the manual here: www.lpscomputer.com/ec/manuals.htm and parts here: http://www.lpscomputer.com/c-654-designjet-1050c-1055cm.aspx
Feb 12, 2010 | HP DesignJet 1050c plus InkJet Printer
How do I replace the carriage drive belt on designjet 500
there is nothing easy about this problem. you need torx 8,9,10, and 15 drivers. remove the right cover, remove the service station without breaking it, remove the right frame that holds the service station,release the belt tensioner, remove the encoder strip, remove the display, disconnect the trailing cables, remove the belt, remove the carriage assembly, replace the belt, reverse the process. please be discouraged about this process. this is not an easy repair. if you can find someone someone who is certified on this repair it should take them 60-90 minutes. you can look up the cost of the belt at HP Parts Store. there are only 2 models 24" or 42". my recommendation would be to find an authorized hp dealer. ask them for a quote, the pricing should vary between $300-400. if you can find it cheaper i would be highly suspect and if you've had this printer for awhile then spend the money. make sure they clean and lubricate the rail assembly. good luck!
Aug 11, 2009 | HP DESIGNJET 500 InkJet Plotter Printer
Carriage belt replacement
Use the carriage replacement procedure in the service manual. Download here: www.lpscomputer.com/ec/manuals.htm
Aug 10, 2009 | HP DesignJet 500ps (42 in.) InkJet Printer
Hp designjet 1050 problem
Oiled the slider rods and ensure there was no debris or damage in the printhead path.
You may also want to check the quality of the encoder strip *CAREFUL! IT IS VERY SHARP* and the belt that moves the carriage.
Nov 14, 2008 | HP DesignJet 1050c InkJet Printer
381 people viewed this question
k24674
