Question about Microsoft Xbox 360 Console
Disc draw will not open - Microsoft Xbox 360 Console
  • 643 Answers
Manually eject the disc tray
  1. Disconnect the power cord and any other cables connected to the console.
  2. Uncoil a paper clip.
  3. Position the console horizontally, as you would position a DVD player.
  4. Find the yellow sticker behind the vents on the left side of the console.
  5. Insert the straight end of the paper clip into the eject hole which is located just above the yellow sticker (as shown in the picture below).
  6. The disc tray should pop out slightly. Pull the tray out the rest of the way with your fingers.
Note If a disc is in the tray, make sure that it is not sticky and does not have a label that might prevent the tray from opening again in the future.
If you cannot get the disc tray to open, please see the following article: 906936 The disc drive of your Xbox 360 console does not open
uparrow.gifBack to the top Original Xbox 360 console: How to manually eject the disc trayFirst you need to remove your console's faceplate. Here's how:
  1. Unplug the power disc draw will not open - pscabledisconnect.jpghe back of your console.
  2. Position your console horizontally, as you would position a DVD player.
  3. While holding your console firmly, push the faceplate away from the console with your thumbs.
    pullfrontplatedisc draw will not open - paperclip.jpgss=
  1. Uncoil a paper clip.
  2. If your console has holes below the right side of the disc drive, insert the straigdisc draw will not open - manualeject01.jpger clip into the hole as shown in the picture below.
    If your console does not have the holes pictured below, skip to step 5.
  3. Push the paper clip until you feel some resistance (approximately 1" or 2.5 cm into the hole).
  4. If you're successful, the disc tray will pop out slightly. Pull the tray out the rest of the way with your fingers and skipdisc draw will not open - ejectmecholeleft.jpgdisc tray does not open, try the next step.
  5. Find the two holes below the left side of the disc drive, and insert the paper clip into the first hole on the left.
    ejectmecholeleft.jpgPush the paper clip until you feel some resistance (approximately 1" or 2.5 cm into the hole).
    Note Make sure you are pushing the gear mechanism and not the metal plate.
  6. If you're successful, the disc tray will pop out slightly. Pull the tray out the rest of the way with your fingers and skip to step 9.
  7. If the disc drive is still stuck closed, insert the paper clip into the adjacent hole (to the right) and push again. If you're successful, the disc tray will pop out slightly.
  8. Now plug the power cord into the back of the console. Press the eject button to open and cdisc draw will not open - stickerdisc.jpge. If the disc drive works properly, reattach the console faceplate.
If you cannot get the disc ddisc draw will not open - uparrow.gifn, please see the following article: 906936 The disc drive of your Xbox 360 console does not open
uparrow.gifBack to the top Xbox SupportPlease visit the following website for information about how to contact Xbox Support: support.xbox.com/pages/contact-us.aspx
Posted on May 02, 2011
SOURCE:
Blue Ray disc draw error mess.
Go here and update your firmware with a USB thumb drive ......…. http://www.samsung.com/us/support/owners/product/BD-D5300/ZA
Jun 11, 2013 | Televison & Video
Will not open
try belt (disc draw)
Aug 19, 2012 | RSQ NEO-E500 DVD Player
Cd player drawer will not stay engaged when a disc is inserted
By not engaged i'm assuming you mean that the disc draw closes then opens again almost immediatley. This would indicate that the disc draw limit switch is not being activated by the draw or the switch has failed.
This is usualy a small sub-miniature micro switch activated by the draw itself, Sometimes a very light spray of switch cleaner into the micro switch will effect a cure. The switch gets a fairly hard life so it is more advisable to replace the switch.
Mar 16, 2010 | Sony Audio Players & Recorders
I have a kenwood compact hi-fi system xd-751 the 3
I have a Kenwood hi-fi system XD Series. the three disc draw won't open or play discs. The table shudders when on...can anyone please find a repairer in the adelaide district.
Dec 04, 2009 | Kenwood Audio Players & Recorders
I have a dimensionsC521 that has swallowed my cd disc. It is an awkward cd slide since the cd does not stand upright and so I usually tilt the tower over so it doesn't slip out. Now it slipped out and the...
I suspect this is more a mechanical problem than a power or software problem
I suggest powering down your PC,
Laying it down so the CD draw is flat,
Fashioning yourself a home made cd draw ejector device (otherwise known as a straightened paper clip),
Pressing the paper clip quite firmly into the tiny hole next to the CD Draw (it should unlock and open slightly)
Carefully and gently pulling the CD Draw out just enough to see inside and find out where the disc has got to
Physically maneouvering your whole PC to get the disc back onto the tray where it should be
Then you can either manually pull the CD Draw out and remove the disc or start the PC while it's laid down flat and see if the CD Drive auto closes and begins to spin now the disc is properly seated
If your PC doesn't have the tiny hole on the front of the Drive or if the CD Disc cannot be seen at all or cannot be persuaded back onto the tray then it's time to start opening up your PC case and removing the CD Drive for more attention
- NOTE if your PC is still under warranty Opening the Case may invalidate that warranty, check this before you proceed -
Treat Everything Gently and Good Luck!
Sep 16, 2009 | Dell Dimension C521 PC Desktop
Philips dvdr 3480 disc draw refuses to open
Illustration:
This usually happens when you close the drawer with no disc in it. There is a strong magnet inside the DVD-drive that keeps the spinning disc in the correct position. But when the drive is empty, the magnet is connected to tough to its counterpart (no disc in between) and the worn out motor and/or transmission (belt) is not able to pull them apart in order to open the disc tray.
How to fix - "brute-force-attack":
Press OPEN and give the disc draw a couple of decent slaps (or snap at the tray cover with your forefinger) until it opens. Repeat procedure, if motor stops before drawer is open.
How to fix - "high-tech-approach":
Disconnect power chord. Locate the slot provided at the bottom of the device, near the smaller, left clip holding the front panel. Insert a screwdriver into it at the far right (when viewing from the front), so you can push a small white plastic-lever-thingy (can be seen thru the slot) to the far left. Now the tray is partly opened and can be pulled out completely.
Future outlook:
Don't you never ever close your old machine with no disc in the tray - or just start over again...
Jul 26, 2009 | Philips Televison & Video
Pioneer Comp Disc Player PD-101 5R . MI 7507855 ME. MFD Sep 1992
remove the jacket of the player and open the draw
Jun 20, 2009 | Computers & Internet
My player says it cannot read disc
run the cleaner Dusc maybe the lense is dirty.
plz rate this post as good as u can so we can help others
Feb 08, 2009 | Lite On LVW-5005 DVD Recorder
I have a disk that I put in my old computer, just got a new computer and can't get it in---why?
hi adpelle
is the disc stuck in a cd /dvd drive draw ?
(if so there a small pin hole on the cd / dvd unit you can push a paper clip into it to open the draw .
it's on the left under the draw this will eject the disc in side )
if not disc in draw can you post back more details of this disc and what the problem is .
reagrds
riz.
Apr 16, 2008 | Computers & Internet
Microsoft Xbox 360 Console Logo
319 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Ekse
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
