My computer starts up but then switches itself off after about 15 secs, both the psu and processor fans seem to be working ok, can you help please ? thanks
  • 903 Answers
Does it restart when it shuts off, or just stays off? If it restarts, then shuts down, then restarts again, it's likely a bad power supply unit.
Posted on Apr 09, 2011
My hp_compaq_8200_elite_convertible_minitow PSU is functional but the motherboard is not start
On some models, an unplugged Processor fan will prevent the motherboard from starting. Check your fan connections. How have you determined that the PSU is functional? Is the PSU fan starting?
Apr 15, 2014 | HP Compaq 8200 Elite Convertible Minitower...
When i turn on my pc all seems well for about 5 secs then the heatsync fan and the tower fan stop moving and at that point my video card fan starts spinning 5 times faster what would cause this
Following are the reasons for overheating, just take care of these things::
1. Stop Overclocking your CPU
2. Make sure your Heat Sink is placed properly above the processor
3. Clean the Processor fan, Heat Sink and other peripherals
4. Use High Speed fans
5. Use CPU Heat Sink Paste in the processor
6. Make sure your dint restrict the speed of CPU fan.
7. Use Additional Cooling Units
If such problems occurs due to internal errors then i would suggest to perform a full computer scan with pc optimization tool like PCFresher for an instant fix.
Feb 18, 2013 | Compaq Presario CQ5110F (NP185AA ABA) PC...
My computer starts and then automatically stops after a clicking or ticking sound all my power cables will work but nothing appears on the screen and my fan stops working?help me out please?
I m no expert but it sounds like you need a new motherboard or at least your PSU. I had a similar problem and used the opportunity to have my techo genius up grade the mother board and a fresh PSU and upgraded to windows7 and everything works like a dream and much more power!!!!!
Jan 15, 2012 | Intel Computers & Internet
The power led of my compact desktop is green lighted and it is not starting the psu is ok and even the cpu fan is not working
use other processor, their might be a possible cause that your processor was been busted due to your cpu fan is not working.
Even the psu is working but if it is not enough to supply a power to your system their is also a big chance that you cannot achieve display on your system, so better to try first other psu before purchasing a parts.
hope it helps thanks.
Sep 09, 2011 | Compaq Evo D510 Minitower (Open Box)...
When i turn on my computer, processor fan starts ok , I get bip, but system doesn't start, no single message or simbol on the screen. I removed the cover and shaked processor fan, after it starts and whole...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
dont forget to vote
hope this helps
Feb 02, 2011 | ASUS P4P800-X Pentium Motherboard
Yesterday when i switched on my PC...some spark comes near cpu fan...then my ups is working properly and other accessories are working properly, but cpu alone not starting....there is no sound in...
Take a look closely at ur mobo, tell us where the spark came from? look also at the underside that may have touch the casing, check also the power connection from the PSU(Power Supply Unit) to the board connector!
Nov 11, 2010 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
PC SHUT down
three things i find to cause this,
one, the power supply is bad,
two, the power connector is lose or not push in
three, the heat sink on the processor has come off. This will cause the cpu to over heat and self shut off.
to test the power supply, pull the connector off the mother board and short the green wire to any black wire with a paper clip, this will switch on the power and see if it stays on.
if you need to replace it, you cannot use a regular atx power supply. E machines have a different pin out.
Aug 12, 2009 | Dell E151FPp 15" Flat Panel LCD Monitor
Connecting my PSU to my Motherboard
The bare essentials to start a computer are PSU, Motherboard, CPU, RAM and Video.
Its possible the PSU arrived DOA. Though I've only had 2 DOA PSU's in the 15 years I've been building custom computers.
Hope this helps.
Mary
May 21, 2009 | ASUS P5QC Motherboard - Intel P45, Socket...
PC Not booting up
HI
Please change the smps your cpu and check it..
i'm sure it will work..
Nov 19, 2008 | Computers & Internet
Asus P5GD1-FMS 775 Intel 915GExp. need help..
v i i i
P5GD1-FM specifications summary
(continued on the next page)
CPU
Chipset
Front Side Bus
Memory
Expansion slots
Storage
High Definition
Audio
LAN
USB
IEEE 1394
BIOS features
Rear panel
LGA775 socket for Intel® Pentium® 4/Celeron processor
Compatible with Intel® Performance Universal FMB 2005
processors
Supports Intel® Hyper-Threading Technology
Northbridge: Intel® 915P Memory and Controller Hub (MCH)
Southbridge: Intel® 82801FB ICH6
800/533 MHz
4 x 184-pin DIMM sockets support unbufferred non-ECC
400/333 MHz DDR memory modules
1 x PCI Express x16 slot for discrete graphics card
3 x PCI slots
Intel® ICH6 Southbridge supports:
- 2 x Ultra ATA 100/66/33 hard disk drives
- 4 x Serial ATA hard disk drives
Realtek® ALC861 8-channel CODEC with Jack-sensing
and Universal Audio Jack (UAJ®) technology
1 x Optical S/PDIF out port
Realtek® RTL8101L LAN controller
Supports up to 8 USB 2.0 ports
T1 controller supports:
- 2 x IEEE 1394a ports
4 MB FWH, AMI BIOS, Green, PnP, DMI2.0, WfM2.0,
ACPI 2.0a, SM BIOS 2.3
1 x Serial port
1 x IEEE 1394a port
1 x LAN (RJ-45) port
4 x USB 2.0 ports
8-channel audio ports
Nov 24, 2007 | Computers & Internet
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
