Question about Yamaha RXV665BL Receiver
Yamaha RXV -657, the amplifier switches off on its own within few seconds of switching on. how to fix?
  • 436 Answers
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on. Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Posted on Apr 29, 2011
Yamaha home theatre system RXV 350 amplifier
Check it without speaker connection. If the set does not go to protection mode, check all the speakers by connecting one by one at a time and switch the set ON; to find the faulty speaker. If the set goes to protection mode even no speaker connected, check and replace damaged components at its audio output section circuit. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 07, 2014 | Yamaha RXV-350 Receiver
Unit goes into protection after a few seconds. Yamaha amp model no RXV 350
Disconnect all the speaker connections, and just switch the set ON. Even now the set goes to protection mode, the fault will be with its audio output section circuit. If it does not go to protection mode without speaker connections, check all the speakers. Connect on by one at a time; and switch ON the set; thus you can get the faulty speaker box. http://electronicshelponline.blogspot.com/
Oct 07, 2014 | Audio Players & Recorders
Yamaha 2067 power off tips
You probably blew the output(s) Take it to the service shop.
Jul 10, 2014 | Audio Players & Recorders
DSP-A2 After switching on, within few seconds switch off
What do the two have to do with each other. I beleive the DSP is acompliched with a chip.
Jun 16, 2014 | Yamaha Audio Players & Recorders
RXV 871 not switching On
unplug for 10 minutes and try again. If not depress power button to get into set up mode and ck settings , if all else fails reset to factory defaults. P.S. "ck batteries in remote first"
Apr 21, 2014 | Yamaha RX-V871 - 7.1 Home Theater Receiver
YAMAHA RXV 350 Right Speaker not Working
The amplifier for this channel is NOT working.
Feb 09, 2012 | Yamaha RXV-350 Receiver
Just bought a used yamaha receiver model RXv793 do not know how to hook it up.
First do not panic by seeing all sockets in the back side of the receiver.You can connect 5 speakers and one subwoofer on the speaker A switch and maybe a second pair of stereo speakers on the B switch.All the speaker sockets have red and black terminals, so do all speakers. Just get decent cables ( You can buy a whole connection Kit if you want ) and connect the corresponding outlets to you speakers.If you have a powered subwoofer connect the subwoofer input to a socket labeled Subwoofer pre out on the RXV. You will need a RCA to RCA cable for that Next you will need a coaxial or Optic fiber cable to connect a DVD player digitally. The back of the DVD player will have a socket marked coaxial out, and so does the RXV's backside. Just link them .
Turn on the system everything should work. If you are not getting DVD sound there is small button on the RXV front panel called Digital input -- set it to auto ( keep pressing the button and it will scroll through various modes). Also remember to switch on speaker A on the front panel.
Mar 09, 2011 | Yamaha RX-V793
Hi my amp when i switch it on within 3 seconds it automatically switches off?
HI...
That's the protect circuit kicking in.
The rec'r will require service. Either a couple of power supply capacitors have gone bad or one of the power amp modules has quit.
Nov 02, 2010 | Yamaha DSP-AX1 10-Channel Amplifier
Yamaha RXV665BL Receiver Logo
89 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
