Question about Frigidaire FWS833A Top Load Washer
My washer started giving problems a few weeks ago not cutting off automatically after the final spin cycle.Presently it is not going into the final spin cycle. Within the last 2 months I changed 2 lid switches.
  • 1 more comment
  • wahkai44 Apr 10, 2011
    Hi Daniel,
    I took out the pump assembly today and it was clean. So I reinstalled the pump and tried the spin cycle again. When the machine is running on this cycle I am hearing a clicking sound which indicates to me that the spin cycle is trying to engage. Should the lid lock engage on the spin cycle? Because I noticed the lid lock is also not engaging. Your quick response will be appreciated.
    Winston
    The connection to the lid lock switch seems to be OK since when the lid is open the machine stops. The timer connection also seems to be OK
  • wahkai44 Apr 11, 2011
    Where is the timer motor located on the machine. How can I remove the timer knob. Is it a screw type knob or one that can just be pulled out?
  • 4,323 Answers
Hi
You'll have to check the drain pump assembly located inside the bottom front panel of the unit. Take it out and clean it completely to solve the issue. Hope this helps...please post back for further assistance.
Daniel
Posted on Apr 09, 2011
  • 1 more comment
  • Daniel Scott
    Daniel Scott Apr 10, 2011
    Please check the connection on the lid lock switch. Make
    sure it is not open circuit. If lid lock switch seems to be fine then check the
    connections to the timer on your washer.
    Please check the connection on the lid lock switch. Make sure it is not open circuit. If lid lock switch seems to be fine then check the connections to the timer on your washer.
  • Daniel Scott
    Daniel Scott Apr 11, 2011
    If the connections are fine and you hear the click from the control then it is the timer motor that is bad and should be replaced
  • Daniel Scott
    Please check this video, it will help you, its an example though:
My Maytag Neptune Front load washer walks in the spin cycle (MAH8700A*
I had this problem solved by changing this control board:
Whirlpool Part Number 34001494: CNTRL-ELEC I bought this from AMAZON for under $ 200, was able to change myself, good luck
May 26, 2014 | Maytag MAH8700A Front Load Washer
Washer won't go into spin cycle, stops after final rinse. When I try drain &rinse it still will not spin.
If the unit does not spin correctly, this is usually an indication that the unit can also not drain. The unit will not spin if it senses a blockage or issue with the drain lines and/or pump. Try to check the drain lines in the back of the unit for any issue, and then see if you have an access panel to get to the coin trap or drain pump itself. Often socks and debris will clog up in this area and cause your problems.
Dec 25, 2012 | Frigidaire ATF6000ES Front Load Washer
Front load washer stuck on final spin
What is the complete model number of your unit?
Dec 10, 2012 | Washing Machines
Maytag washer (model PAVT244AWW). Won't spin. Don't know how old it is or its history, as it came with a home we purchased in October. Several times it's "walked" during the spin cycle. About 6 weeks...
Its the clutch ,And it sounds like it time for a new washer,the clutch is expensive and washer are cheap try a second hand store that sale scratched or almost new machines
Jul 05, 2010 | Maytag PAV2300 Top Load Washer
HE2 front loadable washer doesn't move fm wash to rinse to drain
Sounds like the door lock. It will not advance to spin if it thinks the door is open. There is a instruction sheet inside the unit behind the lower panel. That will give the error codes for the flashing lights.
Sep 04, 2009 | Kenmore Elite 45986 Front Load Washer
I hae a Whirlpool LSR8233EQ1 Top loading washer.
If you can catch it running while in the spin cycle but not spinning ( put a butter knife or screwdriver in the lid switch hole ) and wiggle the timer knob . If it starts spinning during this process , the timer needs replaced . Sometimes though , when a washer does everything BUT spin and you hear the motor running , the transmission is the problem .
Aug 16, 2009 | Frigidaire ATF6000ES Front Load Washer
Model 110 washer will not go into a final high speed spin.
hi, i would suggest the timer/programmer is faultyas it is ok on the other cycles, the noises you have described may have caused some damage,
Feb 10, 2009 | Washing Machines
Please help
it is the timer or, it may be a short of some kind
Apr 19, 2008 | GE WDSR2080D Top Load Washer
Frigidaire FWS833A Top Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
