Question about Samsung SCX-4300 Monochrome Laser Multifunction Printer
Paper stuck and jammed - Samsung SCX-4300 Monochrome Laser Multifunction Printer
    Scholar:
  • 111 Answers
Open the front and bac cover and remove the paper then try if it work, if not remofe the drum from the front and assure that there is no rest of paper in it, refit the drum and start your printer. Make sure you do not stick paper right away from the package in to it you have to turn the pages over so they do not stick to each other then insert them to your printer, after the printer should work.
Posted on Apr 10, 2011
IBM 1332 printer error #241 Paper jam
Fixing a printer paper jam
When working with any printer it's inevitable that you'll encounter a paper jam. Below are the steps you'll want to follow when this occurs.
  1. Turn off the printer.
  2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.*
  3. Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.*
  4. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.*
  5. Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issues and we suggest contacting the printer manufacturer for additional assistance and/or repair.
* To manually remove paper pull on the paper with both hands being careful not to tear the paper while pulling it. If you're unable to get to an edge of the paper that allows you to pull it you may need to manually rotate the gears that feed the paper through the printer.
Preventing a printer paper jam
As mentioned earlier it is inevitable that you will encounter at least one paper jam during the life of your printer. However, if you're encountering frequent paper jams following the below steps can help prevent paper jams from occurring.
  • If your printer has a paper tray do not fill the tray to capacity. If you're encountering frequent paper jams reduce the amount of paper you place in the tray each time it is filled.
  • Make sure you or the tray feeding the paper into the printer is aligned properly and/or the slider used to hold the paper in place in the tray is snug with the paper. Many printers have sliders that allow different types and sizes of paper to be fed into the printer. If the slider is not properly positioned it can cause paper jams.
  • Use standard office paper; folded paper, paper with labels, and specialty paper such as hard bound paper can often cause paper jams. If you're uncertain with what type of paper you should use with your printer your printer documentation will list the types of paper compatible with your printer.
  • Do not mix the types of paper you're feeding into the printer at one time. If you need to change the type of paper or size of paper being used removed any other paper currently in the printer before inserting the new paper.
  • Examine the printer for any previous stuck paper in the printer. Previous paper jams, torn paper, printing labels or other foreign objects in the printer can cause reoccurring printer jams.
Oct 04, 2010 | IBM Infoprint 1332 Laser Printer
Help i have a paper jam!
Jul 20, 2010 | Epson Stylus NX300 All-In-One InkJet...
I have a Epson stylus CX9400fax a piece of paper is jammed way inside the machine, I can't even see it to try and get it out! I've tried turing the machine on/off numerous time (still not expelling the...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
Jun 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Stylus CX9400 Photo Printer: paper jammed inside printer...
May 18, 2010 | Epson Stylus CX9400 Photo Printer
Paper jam message no paper jam cartridge gets stuck HP 6310 all in one
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Jan 11, 2010 | HP Officejet 6310 All-In-One InkJet...
Paper jam
The way you describe your error, it seems that there is still some residual paper stuck inside the printer that may cause subsequent paper to be mis-aligned.
Jan 07, 2010 | Lexmark X5150 All-In-One InkJet Printer
It say paper jam and ther is no paper jam
Dec 31, 2009 | Samsung SF-335T Plain Paper Inkjet Fax
PAPER JAM PRINTER SAYS PAPER JAM IN INPUT TRAYS BUT PAPER DOES NOT SEEM TO BE JAMMING
Dec 11, 2009 | HP LaserJet 4050 Printer
Jammed paper the jam is obvious when trying to slide paper drawer in. Jammed Paper is not visible Lifting movable parts does not expose paper
Dec 07, 2009 | HP Photosmart C7280 Laser Printer
Paper keeps getting stuck
see if the paper sensor are jam or if the machine have paper jam.
Jun 18, 2009 | Canon Office Equipment & Supplies
Samsung SCX-4300 Monochrome Laser Multifunction Printer Logo
52 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
