Question about Tricity Bendix AW1000W Front Load Washer
Machine wont start program and wash rince and spin and start buttons flashing when switched on .i have cleaned out filter
  • eddiegannon Apr 10, 2011
    The lights on the control board are flickering continously but just the start/pause light, wash, rinse and spin lights. The rest of rest of the lights on the control panel will go on if pushed but will not stay on.
  • eddiegannon Apr 11, 2011
    checked no stuck key and no signs of fuses blowing .Also although machine was purchased 3 years ago it has only been in use for one year because it was in a holiday home and never used would the control board be bad after such small usage
  • 4,323 Answers
Hi
If cleaning filter means that you have cleaned the drain filter from the bottom front of the unit then check the controls, if the lights on control come on and the control board is working fine then the motor should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Apr 09, 2011
  • Daniel Scott
    Daniel Scott Apr 10, 2011
    Please check that there is no stuck key in the control
    board. If not then control board has gone bad and needs to be replaced.
    Please check that there is no stuck key in the control board. If not then control board has gone bad and needs to be replaced.
  • Daniel Scott
    Daniel Scott Apr 11, 2011
    Keeping the washer idle after using it for one year is the
    main reason of its malfunction. If you have some expertise then only I recommend
    you to open it and check that there is no rusting in and around all the metal
    parts as after being wet and remain idle it is eminent that these got rusted. Hope this helps...please post back for further
    assistance.
    Daniel
    Keeping the washer idle after using it for one year is the main reason of its malfunction. If you have some expertise then only I recommend you to open it and check that there is no rusting in and around all the metal parts as after being wet and remain idle it is eminent that these got rusted. Hope this helps...please post back for further assistance.
    Daniel
AQUARIUS WF321
Capital letters make reading tedious............
Apr 05, 2013 | Hotpoint Washing Machines
The rince light is flashing. I have tried re-starting programme and all sorts of things but when it gets to the rinse it starts flashing.
It is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into. If this does not happen then the voltage at the inlet valve must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Jul 28, 2011 | Washing Machines
Hi our hotpoint wf541 starts its cycle as normal but doesnt spin and the mini load and reduce crease buttons flash as well as the on/off button, any ideas of how i can fix this thanks.
hi i had the same problem.
its either your filter is blocked or your pump is not working.
after switching the power off, remove the front bottom panel of the machine and unscrew the filter cap on the right behind that panel. check it's intact and clean iside, if not clean it out or replace it and that should fix it. be careful screwing the filter cap back in and make sure its on tight.
to check your pump is working you can pull out the machine and check that water is coming out of the hose by putting it on the pump out / drain cycle after pouring in some water for it to pump out.
Dec 08, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Unable to use ZJ1217, start/pause flashing
Are you able to open the door ?if so door interlock switch could be at fault
Oct 02, 2009 | Zanussi ZJ1217 Front Load Washer
Washing machine
did you reset the machine after you checked the filter? if not put the selector switch to any of the stop positions the switch on wait till the on/off light flashes rapidly , then switch off and try again.
Aug 16, 2008 | Indesit W 123 Front Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Tricity Bendix AW1000W Front Load Washer Logo
46 people viewed this question
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
