Question about Vicks Humidifiers
My vaporizer has stopped making steam. It's only a couple months old. Help!
    Brigadier General:
  • 4,736 Answers
It probably has a calcium and mineral deposit buildup, that has clogged the unit. Especially, if you're using well water to fill the tank.
To solve this problem, empty the tank of any water that may still be in it and mix a 50/50 solution of White Vinegar and Bottled Distilled Water. Fill the tank with the solution and let it sit for i hour. Then turn the unit ON and let it run, until it starts producing humidity. Once it does, wait 10 minutes and turn the unit OFF and empty any remaining solution from the tank. Refill the tank with Bottled Distilled Water and run the unit for 10 minutes. This will flush the system of the Vinegar and Water solution. It's best to empty the tank again and refill with Bottled Distilled Water and use the humidifier as you normally would. I would highly recommend using Bottled Distilled Water from now on. This will eliminate any future calcium and mineral buildup and having to flush the unit repeatedly.
Hope this helps you solve the problem. Please let me know.
Posted on Apr 09, 2011
How to stop humidifier from spitting out water
Humidifiers, depending on brand will spit out a little water as that is the Idea to get moisture into the air, but you can try not filing it so full, this one is steam so I would look into owners manual as to how to clean it , you may find that it has collected calcium deposits not allowing it to vaporize the water properly.
Mar 02, 2015 | Vicks Warm Steam Vaporizer 1.5 Gallon...
WHERE CAN I BUY VICKS WARM STEAM VAPORIZER
Problems in a Vicks Warm Steam Vaporizer comes when it is mis-handled or when we buy non-warranted products. It is the best solution to spend money on the branded and cheap vaporizers.
http://www.vaporizerchief.com
Cheap Vaporizers Herbal Vaporizers For Sale
Jan 21, 2014 | Vicks Warm Steam Vaporizer 1.5 Gallon...
We have a water softener and I think the water has too much salt and therefore, our Vicks vaporizer has too much steam. Any suggestion?
If your softener is working properly, you should never get any salt in your water. The salt is used only to reactivate the ionic media in your softener cartridge, and during the backflush cycle, all that salt is removed, down to PPM (Parts Per Million) levels.
In any case, even if you used salt water in your vaporizer, it would not increase the amount of steam that it produces. Salt water has a higher boiling point than fresh water. You would also notice salt buildup inside the tank as the water level goes down.
The Vicks Vaporizer works by using only heat to produce steam- the hotter it gets, the more steam it makes. The only practical way to get too much steam outside of a malfunction that causes your heating element to get abnormally hot would be if you live at a very high altitude where water boils at a lower temperature.
High humidity in your home will make it appear as if your vaporizer is making too much steam since the surrounding air will be less capable of absorbing it.
A slightly "off topic" note- if you chose the Vicks Vaporizer/humidifier and have children, you have made a wise decision. Because it produces water vapor by heating instead of ultrasonics, contaminants and minerals (such as salt, iron, calcium, etc.) remain in the tank and will not enter the vapor stream.
Mar 25, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
My vicks vaporizer is not blowing steam is it suppose to. rfinson30@yahoo.com
This vaporizer has two carbon electrodes covered by a 3in black cylinder with a couple of recessed phillips screws that take a narrow long shaft phillips screwdriver. Those two carbon electrodes are about 3/4 inches apart, and the water + a sprinkle of salt set up a resistive path between the electrodes that produces a boiling action on the water, thus steam.The electrolytes in the water, (calcium, iron, magnesium) eventually create a bridge between the electrodes, that allows the voltage to cross the electrodes without heating the water. You would have to take the cylinder off and scrape the built up electrolytes off of the carbon electrodes and reassemble the device, but you can buy another for about 15 bucks, but the same thing will happen again. If you try to use a little less or no salt on the next one it will last a lot longer.
Feb 03, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
My vaporizer is running however there is no steam coming from the machine. Ran all night and used no water does it need cleaned or should i just replace it. thank you
Well, let's consider what we have:
How old is the vaporizer?-- Could the heating coil be all limed up?
Lime-Away, or Vinegar might help clear the Calcium and mineral build up on the heating element-
Or there might be a bad connection?-- Do you have any lights lit?
Open it up, and tell us what you find-
Mack B
Jan 20, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
I bought our Vicks vaporizer and it worked great the first night we used it. We had added a pinch of salt and it steamed all night. Now my husband is sick and we cannot get it to work correctly. We added...
When you say you added apinch of salt I asked my wife and she says that is the measure that she uses. I doubt that you have to much salt but you can flush out your vaporizer with warm water while the unit is running. I would run two or three times for 1-2 hours each then remove element and rinse withe warm water.Also rinse out container and refill with warm water to fill line,make sure you don't overfill as this can cause the spitting. I would add about 1/4 cup of pure vinegar and let unit run. If you have hard water or high mineral content this should help to clean it.
I hope this helps you but if it doesn't I would return it as defective. Thank you
Dec 16, 2010 | Vicks Warm Steam Vaporizer 1.5 Gallon...
My vaporizer is barely putting out any steam...is there a way to clean this unit so that it will produce more steam? This is a Vicks 1.5 gal unit.
Is the water in your area soft? If so, add a few pinches of salt. Vaporizers boil the water by running electricity through it. If your water is too soft, no electricity and therefore no steam.
If you have hard water, and the unit must be cleaned, try soaking it in vinegar.
Dec 24, 2009 | Vicks Warm Steam Vaporizer 1.5 Gallon...
My vaporizer is making a spitting sound -
No salt, unless you had 0 steam - to stop water spit, throughly clean the water tank, just as clean as new. It will work like new if the tank is as clean as new! I dont know where the small particles of dirt come from, but trust me, I just went thru this with mine, it's got dirt in it!
Nov 19, 2008 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Vaporizer That Works?
Have you tried adding salt to the water in the vaporizer? Sometimes the water needs to minerals for the humidifier to work...I add sea salt to mine every time I fill it.
Oct 12, 2008 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Humidifiers Logo
448 people viewed this question
Top Vicks Humidifiers Experts
Paul Carew
Robert
Are you a Vicks Humidifier Expert? Answer questions, earn points and help others
