Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
The engine just shut off. Then gas started boiling up through the air filter. Now it won't even turn over.
  • 3,740 Answers
Hi and wel;come to FixYa I am Kelly,
Something caused the float to stick in the DOWN position or the float broke. As far as the engine not turning over... remove the spark plug as the cylinder is probably full of gas. It will take sometime to purge the cylinder head. Do yourself a huge favor and check the oil level. Sometimes a leaking carb will completely fill the engine crank case with gas! (i.e gas in the oil)
I can help you with repairing this engine. I do need to know the ENGINE number so I can get you the manuals you need to make the repairs at home. SERVICE Manuals I will pass you a link for will have step by step and pictures FYI.
For now what you can do is remove the fuel float bowl cover and clean out any debris in that area. Also shut off the fuel and remove the main fuel line to the carb. When you clean with carb cleaner make sure to shoot carb cleaner UP into the float needle area to try and flush out any debris via the carb fuel mainfold connection that you disconnected. Then shoot carb cleaner from the fuel line connection down through the float needle seating area.
Depending on which float you have (Plastic or metal) there can be other causes for the fuel overflow. The plastic float assemblies are NOT ver hearty and are notorious for leaking between the float plate and the base of the carb. The metal type floats can fill will fuel if there is a pin hole in it and cause the float level to always stay low causing the carb to overflow. If you have a metal float assembly give it a jiggle while it is installed and feel for any fliuds inside the float itself.
If you have to do any dis-assembly or carb overhaul work the manuals I will get for you will help you do that. I can also provide you with a parts source. I just need that engine model and engine number to do that for you.
Thanks for choosing FixYa,
Kelly
Posted on Apr 09, 2011
Engine turns over about 3/4 of turn,won"t start,been running good,new batt,new plugs,new air filter
check and see if you have gas in the oil if you do rebuild carb if not replace starter is bad
Jul 12, 2014 | Garden
17 hp briggs stratton ohc
Clean or change air filter. Clean, gap or change spark plug. Empty gas tank add fresh gas with Stabil. When spark plug is removed pull rope several times to blow out cylinder. Spray starter fluid in spark plug hole before replacing spark plug. Clean outside of carb so choke works freely. Spray starter fluid into carb breather hole with air filter removed and try to start. if running replace air filter and cover. If no start disassemble carb and clean. If no start replace carb.
Jun 19, 2013 | Garden
Won't start not firing where do you spray intake starter fluid?
into the air intake where the air filter goes
Aug 14, 2012 | 1999 Audi A6
My 1985 grand Marquis won't start I can pour gas
Take the gas filter off. Should be located near the front of the carbeurator, take off the air cleaner and look for it, it takes 2 wrenches to take it off, a little gas may spill out but not much and replace it, however there is a strong possibility that he gas pump is out if the filter is fine. Hope this helps
Jul 11, 2012 | Cars & Trucks
Saw won't start without starting fluid.
Sounds like you have a compression problem. Starting fluid will fire at a much lower compression than a gas/oil mix so that's why it will start with it. When the motor is running you get a little more compression because the piston is coming up so fast. You should check the condition of your cylinder wall and piston & ring. If they are damaged at all you loose compression which directly affects starting and running power.
Mar 28, 2012 | McCulloch Garden
14" Mac Cat gas engine won't start. Changed spark
Check tank fuel filter. safe way, put hose on end of filter blow through hose, fuel should come out of filter easily.
Sep 04, 2011 | McCulloch Garden
19e412-0134-01 won't start. gas leaks out air
The float is stuck on the carb flooding the engine and leaking gas out of air filter. Remove the float bowl after the gas is turned of or drained. Thoroughly clean carb And bowl with carb cleaner. Reove the float {very carefully} if it is copper, shake it. If you here fuel in it then it is no good. If not then clean everything and reassemble. If it needs to be replaced, most small engine repair shops will have your parts.
Aug 28, 2011 | Porter Cable BSI550 W 5,500 Watt Generator...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
187 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
