Question about Texas Instruments TI-Nspire Graphic Calculator
I am going to be getting a tinspire and I was wondering how you switch from ti-nspire mode to the ti-84 mode?
  • 51 Answers
I am going to assume that you are buying the non-cas version as the Cas or computer algebra version of the nspire doesn't support the ti-nspire mode.
The tinspire will come with two key-boards. One will be the nspire keyboard, the other the ti-84 board. To switch between them there is a small toggle on the back of the calculator. Push the switch and the keyboard will pop out. Put the ti-84 keyboard in and then press the on button!
Cheers
Sine Wave
Posted on Apr 09, 2011
Testimonial: "Thanks for the help!"
My TI-nspire cx cas calculator says operating system not found. Install OS now. Can someone fix this problem?
Have the TiNspire Computer Link installed on your computer.
Download the OS from from education.ti.com
Connect your calculator to the computer with TINspire Computer Link. Run the software. It opens an explore type window. Under the TOOLS tab find Install OS. If it does not connect to the Internet, point the software to where you stored the downloaded OS.
Sep 29, 2015 | Texas Instruments TI-Nspire CX Graphing...
How do i install the ti-84 operating system to the ti nspire
You do not. The TINspire with TI-84 keyboard works as a TI-84 Silver edition. Its OS is update when the TINspire OS is updated. The Ti 84 OS's you find on the TI website are not for the TINspire with TI84 keyboard.
May 12, 2014 | Texas Instruments TI-Nspire Graphic...
Hi, I have a problem with ti-nspire cx cas, it doesn't charge via a usb cable.
Are you really talking about a TINspire CX or a TI NSpire. The TINspire CX (CAS or Not) comes with a rechargeable battery and an adapter/Charger. You plug the charger in an electric outlet and let it party charge. If the calculator battery fails to recharge then it must be defective. Any third party mini USB charger will recharge the battery.
The TINspire with touchpad (CAS or not) can use regular batteries or the optional rechargeable battery.
It is not necessary to connect the calculator to a computer to have it recharged.
As far as the calculator being recognized by the computer, you must install the communication software (TI computer Link Software for the older TINspire) or the TI Nspire teacher or student software for the CX. When you run the TINspire teacher or student software and then connect the calculator, you will have the opportunity to select it.
Aug 16, 2012 | Texas Instruments TI-Nspire Graphic...
Every time I launch the TI-nspire software, I get and error message saying that the system clock has been changed[C24]. Reset clock to current date and time, and contact TI if this error continues. How do...
You get that message if you own a license for the TINspire Software, and you installed it on one computer, but now you are trying to use it on another computer.Apparently a single license can only be installed and validated once with a TINspire and the computer. I have had the same problem and have not found a way to revoke the license on the old computer and revalidate it on the new computer.
Sep 04, 2011 | Texas Instruments TI-Nspire Graphic...
I am using Window XP. How to download software that includes a driver to my computer to use my TI-nspire CX ?
In the clamshell or the box the calculator came in, there is a CD. Use it to install the drivers and the TI Nspire Computer Link software. If it came with the TINspire CX student software you can install that too.
After that you can hook the calculator to the computer and run the TI Nspire Computer Link software or the Student/Teacher Software and it it will probe the USB port and find your calculator.
Aug 20, 2011 | Texas Instruments TI-Nspire Graphic...
Ti-84plus keypad for ti-nspire w/touchpad while in a+bi mode i enter the the problem (2-5i) / (1-6i). once i press "ENTER" i get a decimal. i want the answer in frac form, but when i press...
Here is screen capture of the calculation, performed on TINspire with TI 84 plus keyboard.To type in the imaginary unit use key sequence [2nd][dot], do not use [ALPHA][X^2] for the letter I.
k24674_90.jpg,
Jun 09, 2011 | Texas Instruments TI-84 Plus Calculator
How do you simplify a radical to get another radical instead of a decimal? For example how do you simplify radical 48 to get 4 radical 3 instead of 6.9282?
If you have a TiNspire CAS, you can check the Settings and make sure that the calculation mode is set to Exact.
In HOME press 5:Settings and Status > 2: Settings > 1:General >Tab>Tab>Tab>Tab Calculation Mode :Exact.
Unlike the TINspire CAS, the TINspire does not have an exact calculation mode. It just has Auto and Approximate. From the looks of it, you may not be able to use radicals, let alone simplify them. But I may be wrong.
Jan 23, 2011 | Texas Instruments TI-Nspire Graphic...
How do you simplify a radical to get another radical instead of a fraction?
If you have a TINspire CAS, you can check the Settings and make sure that the calculation mode is set to Exact.
I just got the TI-Nspire. I'd like to solve a problem with undefined variables using Negative Exponent and things like the Expanded Power Rule. The Nspire will not let me store "x" as a variable. How...
You need the TINspire CAS (Computer Algebra System) to do symbolic manipulations. The Blue TINspire (with TI 84 keyboard) can only perform numerical computations.
If you use variables, the calculator will assign the numerical value stored in the variable.
Aug 17, 2010 | Texas Instruments TI-Nspire Graphic...
Ti 84 nspire,replaced batteries and now it says "operating system not found,install OS" Of course my son has a finals exam tomorrow..help!!
Hi
A. Download the TINspire OS from education.ti.com
Use the Ti-Nspire computer link to reload the OS onto the calculator.
  1. Remove the Ti84 keyboard and insert the Ti-Nspire keyboard.
  2. Make sure the battery are good.
  3. Connect the TI-Nspire device (with the Nspire keypad) to the computer using the USB Standard A to Mini B cable
  4. Run the Ti-Nspire computer link software.
  5. The select device dialog should appear, and detect the device.
  6. With the mouse cursor, select the OS, drag it and drop it on the main window (file browser window) of the TI-Nspire computer link software.
  7. Alternatively, click the menu Tools and select Install OS. A Select file window opens.Use the browse button to point to the OS and click Open/OK
B Installing from another Ti-Nspire ( not a TI-Nspire CAS) if availabe)
  1. Connect the two devices using the USB Mini A to Mini B cable
  2. The end marked A should be inserted into the sending unit, while the end marked B should be inserted into the receiving unit.
  3. Both units must be turned ON
  4. On the sending unit, access the document chooser by pressing [Home](the house icon).
  5. Once in the document chooser, press [Menu] and choose 9:Send OS…
Hope it helps.
Thank you for rating the solution.
Dec 11, 2009 | Texas Instruments TI-84 Plus Calculator
Texas Instruments TI-Nspire Graphic Calculator Logo
248 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
