Question about Toshiba e-Studio163 Copier
Cannot print. cassette does not have size of paper windows xp
  • 132 Answers
Hi there, you will have to open the print driver, and set the paper size there.
Go start, settings, printers and faxes then double click on the Toshiba, that will open the print que.
Now click on printer, then click on properties, when the properties is open press on Printing Preferences, the paper paper tab on the top of the task bar of printing preference.
The auto cassette, the first cassette and the bypass must be set to the paper that your machine is set to.
Now apply the settings that you have made. Now go to advanced and then Printing Defaults click on Paper tab and change that paper size to the size that you entered for cassette one.
Run a test print and all your problems should be sorted out.
Posted on Apr 09, 2011
Error code - Different paper size is set. Check paper size
turn the dial on front of paper cassette to match paper size in the cassette
Mar 04, 2015 | Kyocera FS-2100DN Laser Printer - FS2100DN
My printer is i-sensys MF4150. It prints one page then stops the error light flashes red and message 'load correct paper cassette : ltr ' appears on the LCD screen.I print 1 page then I...
Dear
Pl. select the paper size ( as mentioned on the paper packet) on computer on click START-PRINTER AND FAXES(new window opened)-(right click on printer icon) PRINTING PREFERENCE(new window opened)-select PAPER -paper option (here the paper size to be selected- APPLY. This may set the paper size default.
Thanks.
Feb 03, 2015 | Office Equipment & Supplies
Trying to print a picture from the web on XP-810 epson on regular 8x11paper, printer tells me load paper on cassette 1 but cassette 1 only takes picture size not 8 x11. Cassette 2 is where the 8 x11 i
I Just right click on picture select save as. I now have a copy in my pictures. right click on picture select print, on the drop down window select paper size A 4 is 8X11 if it asks print to paper size click ok.
Oct 02, 2014 | Office Equipment & Supplies
Custem size paper are not creat
am using an Epson LX-300+II dot matrix printer in Windows XP. I am
trying to print checks that are tractor feed 8.0" x 3.66". I added the cusotm
paper size in the print server and it is saved correctly, however, when I try
to print, the print properties dialog does not show the paper size. In fact,
there are many paper sizes in the print manager that do not show up in the
list of available paper sizes.
Apr 13, 2010 | Epson LX-300+ II Matrix Printer
WHAT DOES LOAD CASSETTE PAPER CODE A4 ERROR ON A CANON MF3240 . WHAT DOES THIS MEAN? THANK YOU
I talked to tech support at Canon, and he explained that the document I was trying to print was originally scanned with an A4 paper size, and my printed is set to Letter paper size, thus producing the error code. A simple solution is to "uncheck" the box that says "choose paper source by PDF page size". It worked!!
Jan 18, 2010 | Canon Office Equipment & Supplies
Red alarm keep coming to my (Canon imageCLASS MF5770 Multifunction Printer) and display message: CHECK PAPER SIZE AND CHANGE PAPER SIZE CASSETTEL LTR. please guid me through steps. thanks!!
Chances are the paper size in the cassette doesn't match the paper size (or alignment) that you've tried to print. Verify the paper and alignment of the paper match what you're trying to print, and that the paper guides in the cassette are locked into position for the size and alignment you're working with.
Aug 05, 2009 | Canon imageCLASS MF5770 All-In-One Laser...
Toshiba e-studio 207 "local device communication error
On the host pc that connected to the MFP, check the paper size setting under the driver properties.
Apr 22, 2009 | Toshiba e-Studio 232 Black and White...
Print job will not print from the manually feed tray unless I select the Go button for it to process
Table 3-7. Paper Handling Menu
Item Values Explanation
ENVELOPE FEEDER
SIZE=COM10
For supported paper sizes
see page 1-12.
This item appears only when the
optional envelope feeder is installed.
Set the value to correspond with the
envelope size currently loaded in the
envelope feeder.
ENVELOPE FEEDER
TYPE=PLAIN
For supported paper types
see page 1-12.
envelope type currently loaded in the
envelope feeder.
TRAY 1 MODE=
FIRST
FIRST
CASSETTE
Determine how the printer will use
Tray 1.
FIRST: If paper is loaded in Tray 1,
the printer will pull paper from that
tray first.
CASSETTE: A paper size must be
assigned to Tray 1 using the
TRAY 1 SIZE option (the next item
in this menu when TRAY 1
MODE=CASSETTE). This allows Tray 1
to be used as a reserved tray.
TRAY 1 SIZE=
LETTER
see page 1-12.
This item appears only when TRAY 1
MODE= CASSETTE. Set the value to
correspond with the paper size
currently
Mar 12, 2008 | HP LaserJet 4350 Printer
Toshiba e-Studio163 Copier Logo
138 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
