Question about Galaxy Radios DX-979 40-Channels Base CB Radio
During the 5-10 minute warm-up of the cb its s meter pins and there is no receive untill you key the mike and then it goes back into normal receive mode untill it happens again this continues untill the radio has been on for about 10 minutes then the problemm seem to go away. the radio was bought from copper electronics 2 days ago a galaxy dx979
  • 3,018 Answers
I would recommend not doing anything and contacting Copper Electronics and have them arrange to have it shipped for a warranty repair. If you so much as open that radio they may decline the free repair you are entitled too. Copper Electronics are good folks. I do plenty of business with them. Contact them and tell them your issue and inform them the radio is only two days old and they will take care or you. For this radio they offer an alignment and tune for a small fee. Did they perform this on your radio before they shipped it? It would seem that something may be wrong with the PLL. Just to be sure make sure the power supply is sufficient and you have an SWR/Watt meter in line to make sure your radio does not suffer heat damage.
Regards,
Tony
Posted on Apr 10, 2011
Icom 7000 switches off when the mike is keyed up and then relay chatters
Check for shorts and opens on the antenna with a meter first.
Mar 31, 2013 | Radio Communications
Cobra 29XLR has no receive, no transmit, and meter light goes out when the mic is keyed.
If the PA works then the audio amp is fine. but normally when the one of the lights go out its a shorted capacitor.
Oct 22, 2011 | Cobra 29 LTD CB Radio
I have a 29 cobra crome edition, the provlem when i key up the mike, the meter will not move, i tried 3 different mikes but could not get it to work on either of them
  • Now I need to know do you have any receive? No receive is a good sign either the final or driver is bad. Plug an external speaker into the PA port on the back of the CB and hit the switch to PA. If you hear yourself out of the external speaker then your IC chip is good. If not the it is bad. Do them little tests there and I can further help you. I just can't proceed without them answers.
  • If you have any comments please feel free to leave them here.
  • hope this helps and thank you for using FixYa.
Regards, Tony
Aug 30, 2011 | Cobra 29 LTD CB Radio
Wend i key the radio some time my receive stay stock on s9 then i press the ptt again and go back to normal s3 why is that.
Either a dirty meter, erratic ground problems, high swr's
internally on the meter, put a few drops of wd40 on the pivot point...
Mar 03, 2011 | Galaxy Radios Microsystems DX94HP CB Radio
Cobra 29 ltd wont transmit until warmed up for a few minutes. audio is fine, just no power out the antenna jack and not showing any on the meter on the face of radio.
Take the cover off, then hook it back up,take a pencil with the eraser end,go around the circuit board pressing down while you are keyed up, and notice the meter, see if it goes up, sounds like you have a cold solder joint, take a ohm meter and check the finals, replace them useing heat sink compound,....enjoy..... hope this helps....
Mar 14, 2010 | Cobra 29 LTD CB Radio
Hello I have a 1997 Ford expedition Eddie Bauer with 233K mikes. Engine runs great. The problem: Whne I first start the vehical in summer or winter the windshield wipers will not work until the truck warms...
Hi MeTV,
I was expecting to hear, 'And the radio only plays the theme from the twilight zone'. I'm glad you're an Engineer.
Process of elimination then:
  • So temperature has nothing to do with it (Summer/Winter no diff).
  • Not a switch (Different locations)
  • Not a ground problem (Too consistent)
  • Not even same circuits.
Maybe it's not so much the engine warming up as the length of time.
What's left are Fusible links. Self resetting fuses that may (and I'm reaching here) be popping during startup. They take a few minutes to reset.
They are normally running through the firewall on the engine side. You will need a meter to check them. It has to be done while nothings working. They are regular wires with little barrel in line.
It's the only component that could be responsible
Mike
Dec 09, 2009 | 1997 Ford Expedition
Roadking 56 mike
cbtrick.com mic section
Aug 29, 2009 | Magnum DeltaForce CB Radio
Superstar 3900 with no USB or LSB on receive.
most likely been fiddled with and out of alignment. If you have a freq counter and a volt meter you could possibly fix it yourself. look at cbtricks.com for the aligment procedure.
Jun 13, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Lost channels in a galaxy 66v cb radio
as far as the transmit frequency changing while you have the mic keyed this is normal, the transmit frequency is a little different than the receive, as far as the lost channels go you need to check the galaxy website and check to see if thier is any fixes listed. if none is listed then you can send the tech's a e-mail and tell them your problem and they will advise you on what to do.
Aug 15, 2007 | Galaxy Radios DX-66V Base CB Radio
Galaxy Radios DX-979 40-Channels Base CB Radio Logo
78 people viewed this question
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
